    Going through and doing all of the seals on an m42 does take long as long as you aren't repainting absolutely everything...lol
    I probably won't be going as in depth as you have haha. Just planning to fix some leaks and repaint a lot of the major stuff so it looks nicer. I'm mostly planning to work on the engine bay, since it'll be easier to pull the wiper linkage and fix the cowl damage, run new brake lines to delete the ABS pump, and generally clean up the whole thing since it's pretty nasty.
      Be careful, my car is a shell because it made sense to "do it all at once"...
        That's definitely a concern of mine, but I'm ok with this turning into a longer term project. I've been planning this car in my head for a number of years and over the last few months decided that now is as good a time as ever to get started on it.
          It's a good feeling when you get shit squared away and have the time to do what you want to your "fun" car
            but an e30 stuck in a garage is an e30 not being driven! its needs to be a balance, for sure.
              For the last year the car has been a wrecked e30 which is definitely worse than an in-progress e30! I'm hoping to have it back on the road, at least for a little while, next summer. The initial plan was have it ready the minute the snow melts but I think, with pulling the engine, I'll say mid to late summer is a goal.
                When I re did mine over the last two winters I missed a few of the larger events I really wanted to go. I convinced myself that doing it right the first time would be worth it. When the stars aligned and I got to autox at road America on good tires it all made sense. That one event was worth it, the car felt awesome. Especially knowing you had done it all yourself. Even if it's going to be a daily cruiser or weekend warrior. Just knowing that you did it right the first time is great
                  Been making some minor progress, worked on Wednesday but cut it short because it was 15 degrees in the garage...Got the rear section of the exhaust out (crappy muffler was welded to the hangers, what a PITA to get off) popped out the o2 sensor, about to drop the mid-section when I decided I liked not having hypothermia.
                  Also started tearing down the front struts to clean and repaint
                  They already have VAC sway bar mount reinforcments welded on, and on closer inspection I found a nice surprise:
                  I didn't notice them initially because they are a bit crusty and blend in really well, but there are a pair of fixed camber plates attached to the strut mounts that I had no idea were there. I love little surprises like these. They seem pretty simple to swap in and out, so it will be interesting to see what they do to the handling once the car is back on the road.
                    Thats cool! It looks like something from when the car was still somewhat new. 😄
                      its going be hard to remove those hex key bolts from the rust!
                        Kroil
                        Heat
                        Swear
                        Kroil
                        Heat
                        Swear
                        Kroil
                        Heat
                        Swear
                        Try ratchet
                        Starts to strip
                        Try again
                        It loosens
                        Try again
                        IT STRIPS
                        DRILL IT OUT
                        THROW PLATES IN TRASH
                        rethink life
                          That was my thoughts at first too, but if you look closely they are actually welded to the plate around the edges. The strut tops had the original studs punched out and then the camber plate installs through the resulting holes. There are some rusty nyloc nuts on the back that I can hopefully get off without too much trouble. Worst case scenario, I snap a screw and carry out the last two lines of Kaiser's post...
                            Haven't been following this thread too closely, but reading the last couple pages, it looks like you're on the right track. Good to see you're saving the car. Wish I would have had the time and resources to do something with mine after I crashed it.
                              Inductive tools work wonders!  I've used this one personally and for anyone who spends any large amount of time working on old or rusty cars this is a lifesaver!
                                Well thats interesting. I have never seen such a thing.
                                  Those are incredible! I got to use one when I was replacing the control arms on my e36. They seem to be quite expensive but the ability to heat nuts and bolts without heating everything around it is probably worth it. Maybe some day...
                                    works better than a torch?
                                    • andyhundleyA
                                      andyhundleyA
                                      andyhundley
                                      Those flame less torches are great.
                                        Heats as well without melting everything around it!
                                          Continued work on removing the old core support, got the two upper and one lower connection points cut out and roughly cleaned up:
                                          Also started dropping the front suspension, got the front struts removed after work today. I'll will be swapping the billies and vogtlands over to the M3 strut housings once I get them all cleaned up. Don't worry about the stress on those rubber brake lines, they're being replaced and I just wanted them out of the way.
                                          I installed a momo hub and a bolt pattern adapter from Crowder's (Highly recommended for all your steering wheel adapter and spacer needs, its well made and the black textured finish hides it nicely since I didn't want shiny aluminum visible) in preparation for a new wheel that should be arriving next week.
