    Crazy how a little piece of rubber can make the doors open and close so much nicer and easier!!!
      Bassboy3313 said:
      Crazy how a little piece of rubber can make a difference
      Same thing applies to having kids
        • JeffJ
          JeffJ
          Jeff
          Do you think he meant to do that or was it an accident?
          1976 530i e12
          1990 325ix e30
          1992 325i e36
          1995 740il e38
          2001 330xi e46
          ^More to come :)
            Looks intentional to me. " Stupid arm"  (sets it down and moves along)
              So fresh and so clean, clean!
                Can't tell on my phone right now, any camber and toe adjustments ??
                  Where did you go for that since it is obviously larger than your oven?
                    I didn't think of it before it got coated.
                      Zach (rampelsauce) did it for me. He does great work.
                        Picked up a set of single headlight grilles and buckets from great britain to hide the intercooler piping better.
                        These use the 7" round lights you find on other 80s cars, so I picked up a set of 7" H4 e codes and threw some lamin-x on them to match the blacked out grill.
                        I will also be doing the relay wiring upgrade to them as well.
                        Today I also removed the rear end on the car in preparation for the custom e30 rear end setup I had made for it. Kind of a bear to do by yourself, but I managed.
                          love the single headlight conversions on e21s, nice choice. also, feel free to bug me for an extra set of hands if you want to! i do understand the desire to accomplish things on your own though.
                            I will definitely keep that in mind when the new one needs to go back in. Now THAT would be a challenge by myself for sure.
                              also, have you changed your coolant lately? your doors says last time it was done was 1987.
                                Yup! It was changed all over the freeway the day of the fall cruise. :)
                                  Been busy disassembling the rear end and selling off parts I don't need anymore. Including selling my e21 3.91 lsd for $700. O_______O Never thought it was worth that much until I looked up a few that have recently been sold. Threw it out there and instantly got a seller. I can't complain about that, lol.
                                  I removed the half shafts and looked at the one that had disconnected. 2 of the mounting bolts to the hub axle were sheared off and the rest seemed to have backed out some how. After I get my new half shafts for the e30 diff install, I will definitely be torquing to spec again, but this time using all the threadlocker I can. Time to remove the trailing arms from the old subframe, painting them and installing them onto the new modified. Along with the sway bar and poly bushings all around.
                                  I am also in the process of making a secondary diff mount for the new unit going in. @Jeff is helping me out on the machining for that. Along with that, I just converted my Lincoln Weld Pak welder over to MIG instead of flux core since I have a ton of welding to do this winter. I am excited to use it once I get the solenoid and regulator installed.
                                    You will be so happy with the mig instead of flux core.
                                    • JeffJ
                                      JeffJ
                                      Jeff
                                      Mig is way better to weld with much cleaner.
                                      1976 530i e12
                                      1990 325ix e30
                                      1992 325i e36
                                      1995 740il e38
                                      2001 330xi e46
                                      ^More to come :)
                                        Yeah I'm excited. I did get damn good with the flux core, but MIG will be much nicer especially for sheet metal work.
                                          holy crap 700 for a used diff? is it 2002 guys picking the e21 stuff up?
