    I've gotten into a soldering kick lately and decided to revamp my dim tail lights. The old incandescent bulbs just don't cut it, especially since the e21 doesn't have a third brake light either. So, I started making my own led panels out of led strip lights. I will be doing the turn signals, brake lights and tail lights. The reverse lights don't work anyways right now (probably should look into that with the e30 trans swap connectors and such) so I'll deal with those another time.
    Soldering started
    Led panel installed without lens
    Led panel installed WITH lens.
    Should be nice and bring now! I finished up all the soldering for both turn signals, 2 out of 4 brake lights (2 per side) and the tail lights. I will be trying out a 100 ohm resistor to see if that lowers the light output for the tail lights so they aren't as bring as the brake lights. I ordered more red strip lights to finish up the remaining 2 brake lights as well as an led flasher that will plug into the stock location. Eliminating the fast blinking normally caused by leds. Hoping to have these done for the Oct 15th cruise.
      Preventing mayhem like this!
        Im am totally digging the quik-latch in the roundel. Brilliant.
          Tail lights are done except one brake light on each side. Waiting on more strips lights to come in mail. The individual leds in the brake light show up more in the camera then they do in person, just an fyi.
            Now I should know when you are braking next time I'm behind you lmao. Didn't want to call you out on the way to veloce I figured you knew, and you did.
              Its all good. Snap called me out on the previous cruise and I just forgot about it. I found that the brake light switch wire was pulled very taught, which was causing it to intermittently pull away from the switch. I fixed that wire and now did these LEDs, so I am hoping it should stay A-OK now.
                Messed around with some cheap red digital gauges to match the volt gauge I installed in my tach. Took them apart and made my own face plate decals to hide what I didn't want shown. Going for the simple look. Put them back together and you'd never know I messed with them once lit up. :)
                Waiting on the oil temp gauge to arrive so I can give it the same treatment. Then I'll just have to figure out something for the wideband to match these. Hhmmmm.
                  Got the last 2 gauges in the mail and put my custom touches to them. So all 4 are done and ready to install.
                    I had finished my led taillights and front turn signals in time for the cruise and also ordered some led license plate bulbs too, but clearly I didn't make the cruise, lol. Figured I would install the license plate bulbs and see how everything going looks. I'm digging it!
                    Taillights on
                    Taillights and brakes
                    Brakes on
                    I also got an led bulb for the trunk light too and figured out why it never worked. +12v wire was removed from inside the trunk lid. Ran a new one from battery and done.
                      Where did you order the LED panels for the taillights and How much did they cost ? I would totally be interested in doing something like that and would want to know your process. 😄
                        I actually made the led panels myself using strip lights. It was a heck of a lot cheaper than buying the panels themselves and also aided in keeping them the same brightness and color. You can see partly how I did it a few posts up. Or just click this link and it will take you to the post. 😁
                          Led trunk light, yay!!
                            love the orange paint idea and the emblem pin idea was genius.  you could even paint the roundel colors over the new pin and it would completely disappear
                              Crazy how a little piece of rubber can make the doors open and close so much nicer and easier!!!
                                Bassboy3313 said:
                                Crazy how a little piece of rubber can make a difference
                                Same thing applies to having kids
                                  • JeffJ
                                    JeffJ
                                    Jeff
                                    Do you think he meant to do that or was it an accident?
                                    1976 530i e12
                                    1990 325ix e30
                                    1992 325i e36
                                    1995 740il e38
                                    2001 330xi e46
                                    ^More to come :)
                                      Looks intentional to me. " Stupid arm"  (sets it down and moves along)
                                        So fresh and so clean, clean!
                                          Can't tell on my phone right now, any camber and toe adjustments ??
