  3. BMW Discussion
  4. What's up with the e46 plugs backing out
6 Posts 4 Posters 0 Views 1 Watching
  • Delias95D
    Delias95D
    Delias95
    Just bought an e46 guy thought leaky manifold I decided to check plugs one was loose. Replaces all plugs. Sounds normal now. Just concerned it may happen again or curious on insight
      Sounds like they weren't properly torqued to begin with. Oddly enough, I just had a spark plug blow out on my daily driver Honda about a week ago. Previous owner had replaced the plugs about 10k miles ago. Found another that was backing out too. Glad you found it before damage was done, I wasn't so lucky. Mine took the remaining threads out of the head and destroyed a coil pack. Ended up needing to get the head helicoiled.
        never just trust the work someone else has done on your car. trust AND verify.
        • Delias95D
          Delias95D
          Delias95
          Ouchhh!!!
          • Delias95D
            Delias95D
            Delias95
            CR
            I can live by that.
              Like above, spark plugs must ALWAYS be torqued and it's a good practice to put anti seize on the plugs when they're going in.  If they're properly torqued then you won't have this problem.
