<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[What's up with the e46 plugs backing out]]></title><description><![CDATA[<p dir="auto">Just bought an e46 guy thought leaky manifold I decided to check plugs one was loose. Replaces all plugs. Sounds normal now. Just concerned it may happen again or curious on insight</p>
]]></description><link>https://wibimmers.com/topic/4569/what-s-up-with-the-e46-plugs-backing-out</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:01:56 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/4569.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 19 Oct 2016 22:37:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to What's up with the e46 plugs backing out on Mon, 24 Oct 2016 13:02:40 GMT]]></title><description><![CDATA[<p dir="auto">Like above, spark plugs must ALWAYS be torqued and it's a good practice to put anti seize on the plugs when they're going in.  If they're properly torqued then you won't have this problem.</p>
]]></description><link>https://wibimmers.com/post/73239</link><guid isPermaLink="true">https://wibimmers.com/post/73239</guid><dc:creator><![CDATA[patsbimmer1]]></dc:creator><pubDate>Mon, 24 Oct 2016 13:02:40 GMT</pubDate></item><item><title><![CDATA[Reply to What's up with the e46 plugs backing out on Thu, 20 Oct 2016 12:34:55 GMT]]></title><description><![CDATA[<p dir="auto">CR</p>
<p dir="auto"><strong><a href="/post/73135">straight6pwr said:</a></strong></p>
<p dir="auto">never just trust the work someone else has done on your car. trust AND verify.</p>
<p dir="auto">I can live by that.</p>
]]></description><link>https://wibimmers.com/post/73145</link><guid isPermaLink="true">https://wibimmers.com/post/73145</guid><dc:creator><![CDATA[Delias95]]></dc:creator><pubDate>Thu, 20 Oct 2016 12:34:55 GMT</pubDate></item><item><title><![CDATA[Reply to What's up with the e46 plugs backing out on Thu, 20 Oct 2016 12:34:08 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/73132">wasnt m3 said:</a></strong></p>
<p dir="auto">Sounds like they weren't properly torqued to begin with. Oddly enough, I just had a spark plug blow out on my daily driver Honda about a week ago. Previous owner had replaced the plugs about 10k miles ago. Found another that was backing out too. Glad you found it before damage was done, I wasn't so lucky. Mine took the remaining threads out of the head and destroyed a coil pack. Ended up needing to get the head helicoiled.</p>
<p dir="auto">Ouchhh!!!</p>
]]></description><link>https://wibimmers.com/post/73144</link><guid isPermaLink="true">https://wibimmers.com/post/73144</guid><dc:creator><![CDATA[Delias95]]></dc:creator><pubDate>Thu, 20 Oct 2016 12:34:08 GMT</pubDate></item><item><title><![CDATA[Reply to What's up with the e46 plugs backing out on Thu, 20 Oct 2016 01:41:37 GMT]]></title><description><![CDATA[<p dir="auto">never just trust the work someone else has done on your car. trust AND verify.</p>
]]></description><link>https://wibimmers.com/post/73135</link><guid isPermaLink="true">https://wibimmers.com/post/73135</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Thu, 20 Oct 2016 01:41:37 GMT</pubDate></item><item><title><![CDATA[Reply to What's up with the e46 plugs backing out on Thu, 20 Oct 2016 00:57:01 GMT]]></title><description><![CDATA[<p dir="auto">Sounds like they weren't properly torqued to begin with. Oddly enough, I just had a spark plug blow out on my daily driver Honda about a week ago. Previous owner had replaced the plugs about 10k miles ago. Found another that was backing out too. Glad you found it before damage was done, I wasn't so lucky. Mine took the remaining threads out of the head and destroyed a coil pack. Ended up needing to get the head helicoiled.</p>
]]></description><link>https://wibimmers.com/post/73132</link><guid isPermaLink="true">https://wibimmers.com/post/73132</guid><dc:creator><![CDATA[wasnt m3]]></dc:creator><pubDate>Thu, 20 Oct 2016 00:57:01 GMT</pubDate></item></channel></rss>
