726 Posts 28 Posters 9.6k Views 2 Watching
    WOW.  Opened this thread expecting comments about this pile of shit car I bought, instead died laughing at you two. Thanks for making my morning.
    Daggerty said:
    I have a wing that I have been holding onto for like 5 years and will probably never use.
    http://m.ebay.com/itm/JDM-57-GT-Style-Adjustable-Bracket-Down-Force-Spoiler-Wing-ABS-Black-/191513523886?nav=SEARCH
    its similar to this one, you can just have it. It is very large.
    YES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Where and when can I come get it. I'm already in my car just waiting to drive to your house. I need to start making uprights STAT!
    i_love_cars said:
    Just left the Look What I Found thread from watching bad photos. Now I come here and see this shit.
    Why is everyone being so offensive to my visual senses with other people's horrible car modification ideas?! I feel that this forum is no longer a safe space for me and my mental well-being is at stake.
    I'm suing.
    Image result for that's just your opinion man
    Also, in further news, my drift stick came. It was half out of the packaging and the anodizing is scratched and banged up. Looks like it already knows the type of car its getting installed into 😎. I was able to use a thread finder at work and confirmed that the fittings for the cylinder are 3/8-24 for an inverted flare and 7/16-20 for a flare tube fitting. To my dismay, the auto parts store had neither. Guess I will have to use my internets explorer to find these such items.
    On top of that, I also bought some allen key set screws for the two open holes on the timing cover. sealed them up and reassembled water pump. Boom, no more leaks, no more loud bearing noise, no more mis-matched bolts, and no more weeping. Drove it around the block, did some drifto's, parked it back inside, life is good. Now onto wangs, tint, and drift sticks.
    • i_love_carsI
      i_love_carsI
      i_love_cars
      Your thread is great - I was really commenting on the wonky looking cars that were being ripped on in Page 2  😁
      2007 Z4MR
      2003 E39 M5
      2002 E46 M3
      2021 X5 40i
        I'm glad that people here are capable of having a nice morning sparring!
        Good to know that you finally got the leaking fixed!
          Like I said man. Those threads are a pain in the ass. Give Pegasus a call?
            Yup. Gonna go tomorrow before 1pm when they close I think. I might have to use a AN adapter to the 7/16 because WHY ARE THEY DIFFERENT SIZES!?!?!
            Also this is the drift stick I got. it was $34 shipped. I already plan on making a new handle. I opted for this because it was cheap, I didn't have to mess with the pivots when making a new handle, and it has a lock for a parking brake.
            Image result for HYDRO E BRAKE
              British fittings maybe? Idk
                From looking at the Pegasus website, it seams like they will have what I need. I just need to make time to get there.
                  UPDATE. I drove the car to work.
                  EDIT!  I tried to drive the car to work.
                  I got about half way and the watertemps started going to about 220ish. Boiling coolant spewed from the unsealed overflow and on to the windshield (luckily on the side that has a windshield wiper😎) I turned back around and put it back in the garage after pulling over every 5 mins to let it cool off. 😐 Neat experience.
                  ( I cant believe I haven't given up on this turd yet)
                  Tonight I plan on installing a new upper coolant house as the one on there is a shitty flex-fit, a new thermostat and gasket, and attempting to properly bleed the coolant system.
                  OH! and thanks to @Daggerty I have a massive rear wing to install now. I just need to build some uprights. 😎
                    I know the feeling of overheating and pulling over multiple times to let it cool down from my experiences this past weekend.
                      Yeah its not a whole lot of fun. Good thing I had thumb drift to play on my phone while I waited.
                        Well I discovered what my problem is last night. I sure am learning a lot about these here Ferd motors.
                        I got a new t-stat, gasket, and a new upper coolant hose I chopped up from a ford explorer to replace the shitty flex-fit one. I tried to bleed the system with the front right in the air and the cap as the highest point. It burped for awhile then suddenly tons of coolant poured out. Almost a whole gallon worth. Really weird. So then I shut the car down and topped it off again and let it bleed some more. This time I put the cap on when it started pouring out. Coolant gauge was reading a steady 180 at idle. I decided to go around the block and see what would happen. Here's where I noticed something odd. If I was on the throttle, temps would rise to 230 and continue but at idle they would slowly come back down.
                        Any guesses on what would cause this........
                        Okay fine I already know the answer. Since this motor has been around so long, components and accessories need to shift from the left to the right of the motor, depending on the car and the belt style. For example, a 1992 mustang 302 would have a serpentine belt spinning most of the same components in the same direction, where as a 1977 Ford F150 302 would use a V belt and have some of the same components mounted in different locations, and possibly have them spinning in the other direction.
                        Moral of the story? I have a counter-clockwise spinning water pump spinning clockwise. As exciting as this is, I might not have to swap it out. I can simply install a power steering pump that is not on the car and make the belt go under the pulley rather than over, flipping the direction in which it is turning. UGhhh isnt learning fun?
                          Here is a visual for you guys to understand what I'm talking about
                          What I have now
                          And what it needs to look like with the PS pump added
                            Also, on the more aesthetic side of things, as I patiently await my red window tint, I started to think about rear window louvers. Now there's a few threads out there on other forums about E36's with louvers and it just doesn't exist. And from what I gathered, the whole world will burn if I make it happen.
                            Well I guess I just want to make the world burn.
                            So if you guys have any leads on your brothers, or your cousins cousin, or your uncles Larry's bitching mustang that's been sitting in his yard with a set of window louvers hes willing to sell, send me in his direction. I want a set. I found a few on C-list, but im not 100% they are going to fit with my dimensions. I also have my eye on some of those roof visors that people put on civics. I figured maybe I could take 5 or 6 of those things and layer them giving the effect of louvers. Any ideas here are welcome as I want to keep this cheap, even if it meant I have to start making fiberglass molds.
                            Pics of said louvers:
                            AST10532-1.jpg0001917bmw-e28-e12-rear-window-louver.jpegacCFfn4.jpgimage-620569016.jpg
                              I had a friend in California who is close friends with the guy that does louvres for 350/370z's and other newer cars. He had my friends m3 to make louvres and the shape of the rear window wasn't working for him to built a set that fit right
                                Thats good to know, any pics of said car and louvers? I want some!!
                                  The guy I got my fiberglass hood and group 2 airdam from in Portugal now makes louvers for the e21. $250 + shipping. Probably nowhere near the shape you need and most likely more than you want to spend. Figured I would mention it anyways.
                                    The guy never made them because the shape of the rear window didn't allow for him to make it look right. Take a peek at the compound curves of the rear window and you'll see what I'm talking about=)
                                      Dont bring rain to my party. I think I can make it happen. NO MATTER WHAT. So many ppl hating it, or saying it isnt possible is making me want to make it a reality more and more. as a matter of fact, I just finished photoshopping it now.
                                        I'm all for it but I was just letting you know my story lol
                                          I apologize, I miss read that, as I have read 982345 posts from other sites and the negativity got to me. Im Sorry 😦
