726 Posts 28 Posters 0 Views 1 Watching
    Well I discovered what my problem is last night. I sure am learning a lot about these here Ferd motors.
    I got a new t-stat, gasket, and a new upper coolant hose I chopped up from a ford explorer to replace the shitty flex-fit one. I tried to bleed the system with the front right in the air and the cap as the highest point. It burped for awhile then suddenly tons of coolant poured out. Almost a whole gallon worth. Really weird. So then I shut the car down and topped it off again and let it bleed some more. This time I put the cap on when it started pouring out. Coolant gauge was reading a steady 180 at idle. I decided to go around the block and see what would happen. Here's where I noticed something odd. If I was on the throttle, temps would rise to 230 and continue but at idle they would slowly come back down.
    Any guesses on what would cause this........
    Okay fine I already know the answer. Since this motor has been around so long, components and accessories need to shift from the left to the right of the motor, depending on the car and the belt style. For example, a 1992 mustang 302 would have a serpentine belt spinning most of the same components in the same direction, where as a 1977 Ford F150 302 would use a V belt and have some of the same components mounted in different locations, and possibly have them spinning in the other direction.
    Moral of the story? I have a counter-clockwise spinning water pump spinning clockwise. As exciting as this is, I might not have to swap it out. I can simply install a power steering pump that is not on the car and make the belt go under the pulley rather than over, flipping the direction in which it is turning. UGhhh isnt learning fun?
      Here is a visual for you guys to understand what I'm talking about
      What I have now
      And what it needs to look like with the PS pump added
        Also, on the more aesthetic side of things, as I patiently await my red window tint, I started to think about rear window louvers. Now there's a few threads out there on other forums about E36's with louvers and it just doesn't exist. And from what I gathered, the whole world will burn if I make it happen.
        Well I guess I just want to make the world burn.
        So if you guys have any leads on your brothers, or your cousins cousin, or your uncles Larry's bitching mustang that's been sitting in his yard with a set of window louvers hes willing to sell, send me in his direction. I want a set. I found a few on C-list, but im not 100% they are going to fit with my dimensions. I also have my eye on some of those roof visors that people put on civics. I figured maybe I could take 5 or 6 of those things and layer them giving the effect of louvers. Any ideas here are welcome as I want to keep this cheap, even if it meant I have to start making fiberglass molds.
        Pics of said louvers:
        AST10532-1.jpg0001917bmw-e28-e12-rear-window-louver.jpegacCFfn4.jpgimage-620569016.jpg
          I had a friend in California who is close friends with the guy that does louvres for 350/370z's and other newer cars. He had my friends m3 to make louvres and the shape of the rear window wasn't working for him to built a set that fit right
            Thats good to know, any pics of said car and louvers? I want some!!
              The guy I got my fiberglass hood and group 2 airdam from in Portugal now makes louvers for the e21. $250 + shipping. Probably nowhere near the shape you need and most likely more than you want to spend. Figured I would mention it anyways.
                The guy never made them because the shape of the rear window didn't allow for him to make it look right. Take a peek at the compound curves of the rear window and you'll see what I'm talking about=)
                  Dont bring rain to my party. I think I can make it happen. NO MATTER WHAT. So many ppl hating it, or saying it isnt possible is making me want to make it a reality more and more. as a matter of fact, I just finished photoshopping it now.
                    I'm all for it but I was just letting you know my story lol
                      I apologize, I miss read that, as I have read 982345 posts from other sites and the negativity got to me. Im Sorry 😦
                        Okay, so more progress on the water pump/ power steering issue. When I got the car the guy gave me a bunch of random parts and boxes he had sitting in his garage that went with the car. In one of those boxes was two of what I believe to be late 90's V6 vulcan Ford explorer power steering pumps. Since looking for any information about this Ford 302 motor is a nightmare because of 394853 different styles of everything, I just decided one of these pumps will have to do. I grabbed some various material I had laying around to mock up brackets to hold the pump in place. From here I plan on making something a little more acceptable in CAD and machining it. This is what I cam up with so far:
                        High quality, I know. But its serving its purpose for a good mock up. I don't really have to worry about adjustability as there is a heim joint on the alternator to adjust the slack in the belt.
                          I started making mock-up risers for mounting the Rear wing from @Daggerty. I dont exactly know if im 100% sold on the wing yet. Something about it just isnt what I envisioned. I think mostly its because of mounting brackets to secure it on the decklid. I think the uprights need to be mounted behind the car somewhere, and the car needs flares or something. The wing just might be a little premature at this point. hmmmm....
                          On another note, I am finishing the power steering brackets today and should have that installed tonight. I also started looking into paint treatments and photoshoppped some to make the car look more ratty. I think I might be using some red paint carelessly tonight....
                            What happened to the futuristic aspect versus just being ratty?
                              Its going to happen. I need to add LEDs with 3D printing a bunch of random parts to add structure behind misc panels. Structure like so:
                              tumblroc1kg1ei2H1t4spjzo11280.jpgtumblrodia0uv6z91qiw9xho11280.jpgtumblroeo1d4SHs01sabmk9o11280.jpg
                              Behind panels and such like these:
                              khyzyl-saleem-e92m3-final-lr-web.jpgkhyzyl-saleem-c63finallow.jpgkhyzyl-saleem-hakosukafinal.jpg
                                Buy a box of Franzia and call it paint night
                                  The whole mix of flat and gloss black with red just doesn't sound futuristic to me. Are you sanding through the paint down to metal and primer in spots to give it the weathered look that KHYZYL SALEEM usually goes for? I think sanding off all of the paint down to bare brushed metal and clearing it like the hood of your civic would really give you that futuristic look. With the red windows it would really pop since I've seen quite a few future concepts with colored "glass"
                                  khyzyl-saleem-mx5finallow.jpg?1443926962
                                    Trellis frame from the husky/Ducati style bikes
                                      You Just gave me a really awesome idea. Yes, sand down to bare metal, clear the areas with RED tinted clear. Kind of like the hood of my civic, but the whole car!
                                        That would actually be awesome. It would almost be an anodized look of sorts.
                                        For reference of a stripped bare e36: http://www.stanceworks.com/forums/showthread.php?t=77886
                                          I just happened across that thing last week. Pretty cool looking car.
