  4. Lifted E30 V2
Lifted E30 V2
    lmao@kiddie pools and rubbermaid anything. walmart flares ftw.
      Got some more work done last night!
      Put some new plugs in, which clearly needed to be done... Replaced the Mighty Power Core plugs with some Bosch units.
      IMG20161012201647317HDR
      Got the power steering pump back on, connected the heater core hoses, put the fuel lines one, did some coolant hoses and other various bits.
      I added oil and gave it a crank to get some oil flowing through then plugged the fuel pump fuse in to see if my work payed off right away.
      VID20161012220149317
      The heart transplant was successful! It felt pretty great to get that on the first try!
      The car never wants to idle, it didn't last year, it didn't in the winter, it didn't in the summer. I tried a different ICV at one point with no luck, and now I just have a sharpie stuck into the ICV hose so that there is no vacuum leak, but I would really like it to actually idle. The motor is from an 87 325e which I believe had a separate control unit for the ICV, so I'm wondering if that is bad? Something to look into!
      I also made a bit of a sketch for my fender flare idea. I had the idea in my head, and it looked okay there, but it looks a lot better than expected on paper! I could only find a sketch of a lowered e30 and I didn't feel like messing with it that much, so it is just to demonstrate the flare idea . It is kind of what GMC/Chevy (?) use for their flares, the square style fender cutouts. I am going to see if I can find some measurements for the size of what comes off those trucks and see if I can just use a trimmed set. I suppose a junkyard browse wouldn't hurt either, as I think jeeps may use a similar style.
      3000197781082aba5ca98o
        Bassboy3313 said:
        I am interested in this Evo diff hanger idea you speak of for when install my e30 rear end on the e21. Also, I have a bunch of random m20 parts BNIB if you want them. Radiator rubber mounts, shifter parts, misc seals, etc.
        Just asked him and he said it was a stock Evo 8 front engine mount
          I see it now.
          I assume he bolted or welded this Evo 8 mount to the frame of the car and then made his own mount plate to bolt between the diff cover and this mount. Pretty slick.
            I am curious to see what you use. I have had the thought of just using truck flares or something similar on my E36 but I cant find anything that I wont have to cut into 6 parts to make it fit. I was thinking small trucks like an S10 or ranger, also suzuki samurai would be a good one. I only managed to go to one yard to look and came up empty handed. 😦
              I have a few ideas in mind, but a junkyard run will let me confirm some dimensions and maybe pick something up that will work.
              You are going on an e36, so the sizing is a bit different but I'll keep an eye out.
              I'm not opposed to cutting stuff apart for this, so that does open up my options a bit.
                Same. I like getting creative with parts from other cars. Let me know if you find something worthwhile.
                  Your secondary diff mount drawn up, my friend! Jut have to determine how long the 3 bolt spacers need to be to offset the mount the correct distance from the cover.
                    Did you have a diff cover laying next to you? That was quick if those are true dimensions!
                    I am thinking I should go dual ear in both e30's, so I will be using the lifted one as the test bed for parts.
                      Yes I did. I had an e30 diff cover in the car, so during my lunch break I grabbed it, scanned it into the computer and drew it up quick.
                        I wish we had a small scale 3d scanner at work. We use a scanner to scan paper mills through multiple scans and targets which is really cool and useful for work, but we have no use for a smaller scanner ;/
                          I just used a regular office scanner to scan the bolt pattern on the diff cover, lol
                            Ha, I have totally done that with things before!
                              I am annoyed.
                              I just typed out a whole update and instead of switching tabs I closed the tab. The last saved draft was a response to something else.
                              Well, update later I guess!
                                I am annoyed.
                                Google chrome: ctrl+shift+t
                                Reopens previously closed tabs
                                  Correct, but it pulled up a response that I didn't send for another thread.
                                    It better be a good one since you missed the cruise for it😛
                                      Aka pornhub
                                        Very late compared to when I said it would happen, but oh well!
                                        I got some new shocks in the E V2, and these ones appear to have a bit more stroke than the old ones!
                                        While installing the new shocks I was also switching over to vert springs and e46 control arms.
                                        Getting the control arms ground down enough was fun, so was using some ratchet straps and 2x4's to get the CAB's on lol.
                                        IMG20161016104617489HDR
                                        I got the cheapest shocks available, and as it turns out they don't have enough dampening. They seem to be a lot better than the old ones, but not quite what I need them to be. I will address this issue later.
                                        A blurry picture of the arm set up, and you can't really tell from the photo but it pushed the hub out 10mm
                                        So now the tire is actually sitting outside of the flare. This is with a 10mm spacer, which is required for the tire to not hit the spring perch. I may actually be going with bigger spacers soon because the tires are VERY close to the spring perch.
                                        I also need to find longer tie rod ends, as moving the knuckle out 10mm was more than the current tie rod setup can accommodate. I think I will go e90 inner and e36 outer, but am unsure what boot I can use for this setup. If anyone could measure the rough diameter of an e90 steering rack where the boot attaches that would be excellent. I can also be the boot diameter, just so I have some idea as to what I need!
                                        IMG20161016172605172HDR
                                        So with that being noted, I got some flares that I think will work alright and shall be trying to fit those as time permits.
                                        You may be wondering why that tire is all cut up, and I shall share with you. The seam and pinch weld area of the wheel well proved to be a bit of an issue on the last shell and the tire found itself hitting it plenty. This was very evident once I looked up under there!
                                        IMG20161015124439481IMG20161015124431878
                                        I will grind down this area on the new chassis, and probably weld the seam to ensure that it doesn't split. This should prevent any further tire wear..... though it only happened on the side that lacked the vert springs.
                                        This new build is way more legitimate than the last already, as what is being done to one side is being done to the other lol.
                                        I played around a bit with the rear travel potential for the car, and found that with the current flares and offsets that I am able to shove the wheel way up into the chassis, and still rotate the wheel.
                                        I also found that at full droop I am very close the rocker panel!
                                        If the springs would allow it (which they wont) I could get about 13" of travel out of the rear. I am not sure what true travel is, but I should measure the springs to find out!
                                        I have been struggling to fit the strut top spacers in the car, and even putting the vert springs in the strut assemblies made getting the knuckle onto the control arm difficult. I have started thinking more about spacing the front subframe down, and adding the spacers to the strut assemblies. I know some v8 guys run subframe spacers to get more clearance for "things" and I may just do the same, but for much different reasons.
                                        I think bringing the front subframe down 1" would be excellent, and I would then get rear subframe bushings made to match, and create a new subframe support plate under the bushings. I think I could make a heavily offset diff bushing and still use the same chassis mounting point for it, and the shocks should have a long enough extended length to comply with the increased distance in the rear.
                                        This would certainly be a reasonable undertaking, but I am questioning if it would be worth all the time and money for 1 - 1.5" of lift. I am leaning towards it being worthwhile, as even 1" of lift is adding about 10% more height. This would also clear up some of my tire rubbing issues when turning.
                                        The only question that I have about subframe spacing is what I need to do with the front control arm bushings, can I leave them in stock position?
                                        The geometry on this suspension is going to be wildly f*ed by the time I am done with this....
                                          I didn't take any pictures of it yet, but I swapped the E cluster into the car, and also put the tan door cards from the previous car into this one. It is very colorful in there now!
