  3. BMW Discussion
  4. e30 m20 engine removal help needed - Madison
18 Posts 9 Posters 181 Views 1 Watching
    removing any engine from an e30 isn't science. just disconnect everything to the best of your ability, start lifting the engine slowly, and if something is still holding it in place, disconnect that too! something is always forgotten at first.
    quick list, and someone please add anything I missed
    this is not a step by step, this is assuming you do all the appropriate things like drain coolant, depressurize fuel lines, disconnect the battery, etc etc before disconnecting things
    disconnect trans at guibo
    remove trans shifter cable, trans wire harness
    remove trans crossmember from car & trans (support with jack or jackstand)
    disconnect exhaust at downpipes
    disconnect radiator hoses
    disconnect heater hoses at back of engine
    disconnect engine wire harness
    disconnect power steering lines at pump
    disconnect ac lines at ? can't remember best place
    remove airbox/afm
    disconnect fuel lines where they go from rubber to hardline (near firewall?)
    disconnect throttle/cruise cables (thanks german baked goods)
    pull radiator and remove hood.
      Throttle cable/cruise if equipped
        Use the hoist to test the tensile strength of anything you may have forgotten to disconnect
          A load leveler helps tremendously so you can angle the engine as you pull it out. Chris possibly has one already attached to his hoist if you go that route. Don't quote me on that tho. I cant even count any more how many times I have pulled or installed an m20 engine by now.
            knew i forgot something!
              I tend to be good at forgetting about the slave cylinder hydraulic line.
              Though you probably already  have that taken care of it you were planning on just pulling the trans
              • C
                C
                cpandrewschmidt
                thanks all for the tips, feel free to keep them coming!
                  i think he has an auto, hence 5-speed swap, but i could be wrong.
                  • C
                    C
                    cpandrewschmidt
                    Well folks, that's a transmission out!!!!  I definitely think it was pinched being the last bolt.  Put a few others in and tightened down and then put the jack under and lifted a half inch to take the pressure off.  Came off no problem then.  Phew, what a relief.  I'll let you all know when the swap is done an hopefully drive able!  Thanks again for all the offers for help, especially Chris.
                      sweet! Glad you were able to get it out.
                        yeah thats much better than pulling the motor!
