  4. TehRaydarlover's AWD lover
156 Posts 15 Posters 0 Views 1 Watching
    Yay for progress!
      nice writeup on the t-case rebuilt. I had no idea they were chain driven!
      also, i spy alpina goodness.
      • TehRaydarloverT
        TehRaydarloverT
        TehRaydarlover
        Thanks!
        Yep! Special ones too! 17x8.5 front 17x9.5 rear from an e34 b10 biturbo.
          will your 5x120 hub modifications let you run low offset wheels, or do you have fender mods in mind?
            Oh if only you knew haha
            • TehRaydarloverT
              TehRaydarloverT
              TehRaydarlover
              The 135i hubs in the front are actually going to hurt me to the tune of 10mm. The z4 hubs in the rear are about 2.5mm wider than stock, but the rear wont be an issue. I do have some fender mods in the works, as Earl eluded to lol. Even then I think it might be a squeeze up front. I might have to pull a few tricks out of my a$$ but it'll fit!
              When I finally get some time away from work I'll get the bearing and hubs pressed in. Then I can do some test fitting :]
                Impressive work, thorough documentation, you are a saint to ixers
                  Is the 135 front hub/bearing a bolt on unit? Or are you also working some magic with that?
                  Does it widen the track by 10mm, or reduce it by 10mm?
                  • TehRaydarloverT
                    TehRaydarloverT
                    TehRaydarlover
                    Yep! The 1 series uses the same wheel bearing in the rear as an e30, and the ix uses the same bearing in the front as in the rear. BMW is kind of dumb though, the front and rear wheel bearings have different oem part numbers yet the FAG/SKF part number is the same, idk why the different OEM p/ns.
                    There are two different 1er hubs, one with a larger offset than the other, I have the shorter hubs. They have a 10mm/side wider track than a stock ix front hub. The wider track kind of sucks because fender clearance is already an issue for a stock ix, always have to run high offset wheels. I guess this is the best I can do without machining my own hubs. I'm kind of scared to test fit my wheels lol.
                    • TehRaydarloverT
                      TehRaydarloverT
                      TehRaydarlover
                      Drove the Tail of the Dragon today. It was pretty fun. Can say the Buick Regal RS I had for a rental car handled better than expected lol. Should be big time lolz to see the pictures once they post them.
                        Tail of the Dragon photos......
                            • TehRaydarloverT
                              TehRaydarloverT
                              TehRaydarlover
                              Dat post count tho
                              • TehRaydarloverT
                                TehRaydarloverT
                                TehRaydarlover
                                Dat post count tho
                                • TehRaydarloverT
                                  TehRaydarloverT
                                  TehRaydarlover
                                  lol we need a some clean up on isle E30
                                    Yard sale
