pistonse30
    wasnt m3 said:
    HPF is also out of business.
    Well thats sad.  I didn't know that.
      The s54 is awesome but is it really a more reliable engine to boost than and s5x/m5x?
      • T
        T
        tsweers89
        Max psi sage 1 kit with e85 550ish whp. Anything above that need a built motor. Now if that would fit in a e30 chassis with s54 I have no idea. Would most likely have to be all custom.
          DrLeadFoot said:
          My thought process is having a more reliable 500 to 600 horsepower set up instead of maxing out the s52 platform.
          I can't imagine that 600 is maxing it out, especially how you have it built.
          You can push an m52 to 600hp on a stock bottom end (upper limit from what I understand)
          Rebuilding and boosting a completely different motor seems like way more time and money again to potentially have the same headaches.
          Beyond that I don't know your inventory of motors etc. to have input lol.
          Glad to see that the garage is being used again!
            Step 1) Buy e36
            Step 2) Remove current engine
            Step 3) Install s54
            Step 4) Smokey burnouts
            Step 5)  Take over the world...
            latest?cb=20121123224529
              Finally starting on removing the motor. Just got the intake manifold off and cleaned up the garage a little bit. 33254efea6bc0e333c7cae8aa6f79b6e.jpg
                "The journey to 1000 hp begins with a single manifold removal"
                  Anytime you need to do something on these motors it's basically "welp, better remove the intake and we'll see from there"
                    MLS and O rings are used quite frequently in the import world, most domestic guys think you are crazy doing so, but results don't lie. I would have you block decked, and still do the surface prep like you did with the wd40. Going to a larger stud (1/2") is a great idea, especially with the larger 87mm bore you are using, but if a goal of 5-600whp is all you want, I wouldn't waste my time. I would go with a simple MLS gasket and mirror finish on block and head. As far as re using your old rods, I would absolutely do so. They have unlimited life for the most part, and can almost always be fixed. I would be willing to bet you don't even need to get them honed or resized, simply swap out bearings. As far as pistons go, check for skirt wear and make sure your PTW is still in spec, mainly deviation between cylinders. I'm willing to bet they are just fine. Because of the crappy tuning youve had in the past, I would be inclined to hone your block and get new rings, depending on how the bores look. Lastly, because your block and head will be decked/milled, I would look into adjustable cam gears so you can degree your cams in. Pick a head gasket that maintains proper quench of around .035-.050, but don't buy that until your block is back from being decked so you can measure from the top of the piston at TDC.
                    that should be all?
                    Looking great though!
                      Going to take the trans out first before pulling the engine. Trying to be kind to this e30 instead of ripping it out.
                      #H3GON3
                      I was going to pull the motor but I am going to quit while I'm ahead. I'll get the motor out this weekend.
                        very confused why you did that. It should take around 2 hours to pull the engine/trans together. Do you have a load leveler/friend to help?
                          I was wondering the same thing.
                            May have a little to do with garage height. I prefer to shark my powertrain out as a unit but definitely requires the right chain/hoist configuration and occasionally some ceiling height.
                              I wanted to see how difficult it was to take out the trans. It took about 1 hour and I was taking my time.
                              Height is an issue as have to have my garage door open to make room for the hoist.
                              Excited to see what is going on in the engine!
                                All gold!
                                  Pic for future reference.
                                  Got the motor 99% ready to be pulled. Now I just have to find a place to put it!
                                    I think Snap's got an engine stand for sale
                                      Not anymore[emoji12]
                                        His level of interest peaked and he arrived at my house with some funds.
                                          All is quiet on the western front. My porch is 70% refurbished doe!
