  4. The E46 M3 Journal
The E46 M3 Journal
e46m3
    Front suspension installed as well as the Turner sway bar! Gonna need an alignment.
      So its probably going to handle pretty well or something
        That's what all the Internets say...
        I was able to get all this done today due to having my wife ( business partner) and associate outside with me. They had the laptops running and I was dictating emails and working on follow up for 7 hours. Between the 3 of us we got a ton done, be it work and bimmer!
          Slanging bolts
            The great wonders of technology lol. Gonna start tracking this with the fresh suspension goodies?
              vng704 said:
              DrLeadFoot said:
              Dunno if you have already but consider getting the reinforcements for the rear spring perch from rogue engineering. Can try garagistic at a lower price. http://www.rogueengineering.com/Rogue-Engineering-Rear-Spring-Perch-Reinforcement-E46_p_124.html
              Ordered
                Ehhhh. My track is the freeway, on & off ramps of South Eastern Wisconsin.
                  This is almost as nerve-racking as doing a dyno.
                    Dyno is very frightening actually.
                    what are we going to do to celebrate the impending successful SMG repair?
                      SMG seems to be working perfectly!
                      Now chasing codes 174 and 175. Pre-cat O2 rich codes. After sitting all night it does not start on the first crank. Turn off key and retry and it starts. Leaky injectors?
                      I can't remember if I swapped over all injectors from the old motor or just the #6 injector.
                      Celebrate? Might buy me an engine stand!
                        Engine stand
                        im just over here rofling my mfao  :D
                          Chasing some issues. Corrected the no-start first crank issue by replacing the DME and injector relays. Not sure with one did the trick but it seems to like it and fires right up.
                          For the 175 & 174 codes I replaced the crank case breather. The light stayed off longer than normal (35 miles) then popped on after red lining 2 & 3rd.
                          What the heck!?
                            Ordered this guy. This should fix it! #famouslastwords #donttellmeitisthevanos
                              My glue job is pretty ugly but it seems to be in there tight. I can't imagine how sloppy of a welder I would be after giving this a go.
                                Light came back on. Taking it to concours and having a smoke test done and taking it from there.
                                  I really cant think of anything else you could possibly replace on this engine [emoji16]
                                    This is ridiculous. Hopefully it is a vacuum leak. Might need a new MAF if cleaning doesn't work.
                                      Cleaned the MAF and rotated it outside of the usual spot I place it in. 100 miles later no engine light.
                                      Need to pass emissions. Does the dmv scanner just look to see if the secondary air pump is working? Might have to plug it in to pass.
                                      Also, it seems that emissions requires the A/C refrigerant to be charged. Why?
                                        When I took cars to emissions for Concours I went to Russ Darrow on 76th and good hope. The guys just plugged in the computer and if all the codes checked out it passed.
                                          Yeah same with any Fast Track. I eliminated the secondary air injection pump on my saabaru, disabled those codes in the CEL file of the ecu and forced all to be "ready". Took it to Fast Track, they plugged it in and 2 minutes later printed out everything was good.
