The E46 M3 Journal
Chasing some issues. Corrected the no-start first crank issue by replacing the DME and injector relays. Not sure with one did the trick but it seems to like it and fires right up.
For the 175 & 174 codes I replaced the crank case breather. The light stayed off longer than normal (35 miles) then popped on after red lining 2 & 3rd.
What the heck!?
Ordered this guy. This should fix it! #famouslastwords #donttellmeitisthevanos
My glue job is pretty ugly but it seems to be in there tight. I can't imagine how sloppy of a welder I would be after giving this a go.
Light came back on. Taking it to concours and having a smoke test done and taking it from there.
This is ridiculous. Hopefully it is a vacuum leak. Might need a new MAF if cleaning doesn't work.
Cleaned the MAF and rotated it outside of the usual spot I place it in. 100 miles later no engine light.
Need to pass emissions. Does the dmv scanner just look to see if the secondary air pump is working? Might have to plug it in to pass.
Also, it seems that emissions requires the A/C refrigerant to be charged. Why?
Yeah same with any Fast Track. I eliminated the secondary air injection pump on my saabaru, disabled those codes in the CEL file of the ecu and forced all to be "ready". Took it to Fast Track, they plugged it in and 2 minutes later printed out everything was good.
Car is running like a champ! Waiting on TTFS to send over the tune license then I can log some miles, get a new tune, pass emissions!!
While I'm patiently waiting for the tune from Frank Smith I directed my attention to some other items.
The passenger door has been extremely hard to open. So took care of that. It's like butter now.
The door card was rattling so hard I thought the speaker was blown but found out it needed some new plastic mounting pins with a rubber washer on them. Also added some weather stripping to tighten things up in there. It helped a ton but isn't perfect.
The tweeter by the passenger door handle had a broken connector so I got a new tweeter. Plugged it in but it is still not working. I'll have to look into this more.
Ordered a couple goodies for the rear suspension. Rear ball joints for the upper and lower and some SPC control arms.
Rear ball joints.
Haven't seen those in a while.
Glad it all seems to be behaving for you now. You deserve a few years of problem free e46 m3 ownership after what you have put into this thing
Seeing someone I know experiencing gremlins on a newer bmw and resolve them makes me feel a little better about the thought of owning something newer than an Isetta
The passenger door handle is like butter now! So nice it makes my drivers door feel like I'm starting a rusty lawn mower.
The tweeter works but only after I jerk the car to the right while driving and slowly bring it back to center. WTF. It sounds great when it works.
The cherry on top is that I passed emissions!! This whole process has been exactly a year in the making. In the end I have a fully gone through M3 (minus engine internals) with almost all new parts bolted to it. It is running strong! Beyond glad I didn't give up on it and sell it to tsweers89. #nah
I'll go through the rear suspension in the next week or two and it should be totally mechanically sound.
Things I want to do:
-New windshield
-New steering wheel
-Paint Hood
-New floor mats
-New interior rubber coated pieces.
Did you replace the door latch to fix the issue of having to yank super hard on the door handle? I'm just curious as my girlfriend's e46 coupe is getting to be that way and adjustment of the outside door handles has done very little to help.
The door latch is what did the trick.
Sucks when the free fix doesn't do the trick!
It's pretty easy to do. Keep in mind the reverse torx bolt is REVERSE threaded.
10 days of off and on daily driving:
- SMG codes
-NONE
- ENGINE codes
-Code 38 (Lambda sensor heating before cat)
I'm going to clear adaptations and see how it goes. I'm pretty happy to just be dealing with this one code.
One pre cat O2 sensor (the one I extended the wires on) isn't talking. Need to re-do the connections and get some spark plug heat wrap to protect the connections against the heat.
Still driving it regardless.
