  4. '88 E30
'88 E30
savebigmoney
    Instafamous!
    Lol
      So nothing new is going on. I dropped the fenders off to get fixed so I had to drive the car like an asshole ccd3948a62be6343736794b783db60bf.jpg
      Then noticed I have an awesome coolant leak somewhere. Assuming it's coming out of the region where the heater core hoses meet with the firewall. It's either those connections or the flange on the back of the head. The coolant that is leaking is super clean, so I'm hopeful that it's just something stupid like a 37 cent hose clamp (god damn you menards)
      In other news I moved
      Setup some shelves and a workbench
      (Got shorted on hardware) God damn you twice menards.08b49d8c9d7098b6fc5835a1c8038d9e.jpg
      Garage still needs organizing. But it's super convenient that my car decides to leak after I get the work area setup. It must miss jack stands or something
        I spy Royal Purple. Pour that crap down the drain.
          Not mine home slicer
            Well about the coolant leak. It only seemed to happen when the car was turned off after it was warm. It was dripping coolant near the trans brace (either it ran down the trans/firewall/whatever)
            I looked at all the connections that were easily visible and saw zero signs of coolant leakage. I know the compression is awesome on the motor from when I bought it and the motor itself shows no obvious signs of a failing HG.
            Cooling system is 100% all new parts and the temp stays right around 195-205 on the tstat housing via temp gun. The coolant has no oil and the oil has no coolant in one another. I can let the car idle for years and it doesn't overheat etc, etc etc
            Last night I took the strut bar off and removed some crap to get at the heater core hoses. I was able to significantly tighten one and sort of tighten another. However I could not see any visible signs that coolant was leaking from them (car had been sitting for about a week though)
            So after I tightened them I went and drove it around, got it to temp, let it idle in a parking lot while I checked out everything under and in the car.
            No signs of the leak apart from a few slight drips (from coolant that was already there hopefully). Heater core firewall hose area was also dry
            I went for a beat run, came back and shut the car off, let it sit, same sort of residue few drop scenario.
            Then I thought maybe it's the heater core. Carpet was dry as a bone. I tried for leaks while using the heat and with the heat off. Nothing seemed to make a difference.
            Got annoyed took car home parked it and can't find any leaks
            TL;DR if my fucking heater core leaks I'm going to gut this stupid thing.
            In other news my fenders will be done tomorrow
              Get some UV coolant dye from carquest, I think they had the best prices on the bottles and uv flashlights.
                I was considering this. But probably won't do it. Simply because I don't want to see a glow around the heater box area. Gonna get out this weekend and drive the car some more to see if the leak has stopped after I tightened some stuff
                  Also got the fenders back today. Also will be calling them about the fenders so they can re-fix their "work"
                  -bubbles in clear
                  -black overspray on the red
                  -didn't paint the bottom of the fender correctly to match my black rockers
                  -didn't install the trim
                  -some of the paint looks to already be cracked from shrinking
                  -hooray
                    People suck
                      -bubbles in clear
                      -hooray
                      Where was the "work" done?
                        I had one brand new oem fender. And my passenger side was in good shape, just needed paint and a dent pulled.
                        I called today and they said I can bring them back in. Conveniently they are only open when I work. So it'll probably be another week before I can get them back
                          At that point the dents sound nice...
                            That sucks... I have to say, you've had some shitty luck lately. Hope they make things right!
                              Yeah dude- not the best luck it seems lol. I called and talked to them, they told me to bring them back as soon as I could. It sounds like they will make it right, or worse idk
                                Well the coolant leak has seemed to stop. I guess that hose clamp was the culprit. Coolant must've been running down the firewall and then somehow making its way to the trans brace area
                                  After going back and forth with this body shop 3 times (they repainted it again and again) I finally got my fenders back. The black on the bottom of the fender was not painted high enough (it's about 1/4" low) but I am just absolutely done with fucking around with this place. I'm just going to get some truck bed liner and fix it myself. Also when I was installing the drivers side fender the clear cracked where it ran and bunched up under neath the headlight where the fender attaches to the valence. You should be able to twist the painted surface a decent amount before cracking occurs. But not when they use shit clear and shoot thin coats to save money. This winter I want to start fixing some body rust on my car and get it more respectable looking as right now I'm one more rust spot away from drift missle status. Plus it will be a good chance to learn some body work. After fixing the rust and crap I may eventually wrap the car because I'm so sick of fucking paint
                                    Plastidip boyyeee!!!!
                                      No Dave. Just sick of red
                                        I need to buy tires. I was thinking Bridgestone RE71r. I have heard good things. My 5(?) year old nittos with 3 auto crosses on them and unknown mileage and 4 winters are dead. Just looking for a good auto cross tire that can pull some occasional street use as well. (Don't drive my car much). If anyone has input for 205/50-15s I'm all ears. FWIW I've driven hankook rs3's & they were good (on a Miata) but they don't offer a 205/50 as far as I know?
                                          What about the Dunlop Direzza Star Spec?  I've heard a lot of good things about them.  I know Jordan ran them and loved them.  I'm sure he can chime in with personal experience.
