  4. '88 E30
'88 E30
savebigmoney
    I'll upload some raw files eventually, I just wanted to make something as i remembered I can edit stuff on my computer
      6a24cee51cc3fd9eea63614e3cf14245.jpgcaf591fdba6cd67d3ba367f46f1564d7.jpg0db3f63302e83e14fc7ee9404fceccdb.jpg
      Little bit less body roll this year
        Entertaining video. Looked like some good driving too!
        • i_love_carsI
          i_love_carsI
          i_love_cars
          awesome mitch, glad to see the car held up as well after all the work you put into it leading up to this 😁
          2007 Z4MR
          2003 E39 M5
          2002 E46 M3
          2021 X5 40i
            Thanks guys! I want to try and hit as many auto X that I can and maybe even head to a track soonish. I have a ton to learn but it's exciting to get out and safely push yourself with others who enjoy it just as much as you do
              This is exactly my mentality. I plan on getting comfortable autocrossing with the E30 (have never done it). And I've been straight line racing the 135i. It's nice to safely learn while having fun. Eventually I'd like to do a lapping day with either car, not sure which I'd want to use. E30 is less risky, 135i is a lot more powerful.
                FWIW I've learned more about my car/driving in the 2 auto X events I've ever done than I have learned in all my years of driving.
                And that's only 16 total runs lol
                Run em both and see what you like more
                  Instafamous!
                    Instafamous!
                    Lol
                      So nothing new is going on. I dropped the fenders off to get fixed so I had to drive the car like an asshole ccd3948a62be6343736794b783db60bf.jpg
                      Then noticed I have an awesome coolant leak somewhere. Assuming it's coming out of the region where the heater core hoses meet with the firewall. It's either those connections or the flange on the back of the head. The coolant that is leaking is super clean, so I'm hopeful that it's just something stupid like a 37 cent hose clamp (god damn you menards)
                      In other news I moved
                      Setup some shelves and a workbench
                      (Got shorted on hardware) God damn you twice menards.08b49d8c9d7098b6fc5835a1c8038d9e.jpg
                      Garage still needs organizing. But it's super convenient that my car decides to leak after I get the work area setup. It must miss jack stands or something
                        I spy Royal Purple. Pour that crap down the drain.
                          Not mine home slicer
                            Well about the coolant leak. It only seemed to happen when the car was turned off after it was warm. It was dripping coolant near the trans brace (either it ran down the trans/firewall/whatever)
                            I looked at all the connections that were easily visible and saw zero signs of coolant leakage. I know the compression is awesome on the motor from when I bought it and the motor itself shows no obvious signs of a failing HG.
                            Cooling system is 100% all new parts and the temp stays right around 195-205 on the tstat housing via temp gun. The coolant has no oil and the oil has no coolant in one another. I can let the car idle for years and it doesn't overheat etc, etc etc
                            Last night I took the strut bar off and removed some crap to get at the heater core hoses. I was able to significantly tighten one and sort of tighten another. However I could not see any visible signs that coolant was leaking from them (car had been sitting for about a week though)
                            So after I tightened them I went and drove it around, got it to temp, let it idle in a parking lot while I checked out everything under and in the car.
                            No signs of the leak apart from a few slight drips (from coolant that was already there hopefully). Heater core firewall hose area was also dry
                            I went for a beat run, came back and shut the car off, let it sit, same sort of residue few drop scenario.
                            Then I thought maybe it's the heater core. Carpet was dry as a bone. I tried for leaks while using the heat and with the heat off. Nothing seemed to make a difference.
                            Got annoyed took car home parked it and can't find any leaks
                            TL;DR if my fucking heater core leaks I'm going to gut this stupid thing.
                            In other news my fenders will be done tomorrow
                              Get some UV coolant dye from carquest, I think they had the best prices on the bottles and uv flashlights.
                                I was considering this. But probably won't do it. Simply because I don't want to see a glow around the heater box area. Gonna get out this weekend and drive the car some more to see if the leak has stopped after I tightened some stuff
                                  Also got the fenders back today. Also will be calling them about the fenders so they can re-fix their "work"
                                  -bubbles in clear
                                  -black overspray on the red
                                  -didn't paint the bottom of the fender correctly to match my black rockers
                                  -didn't install the trim
                                  -some of the paint looks to already be cracked from shrinking
                                  -hooray
                                    People suck
                                      -bubbles in clear
                                      -hooray
                                      Where was the "work" done?
                                        I had one brand new oem fender. And my passenger side was in good shape, just needed paint and a dent pulled.
                                        I called today and they said I can bring them back in. Conveniently they are only open when I work. So it'll probably be another week before I can get them back
                                          At that point the dents sound nice...
