  4. ILC's 1991 318 S50 track rat
158 Posts 19 Posters 0 Views 1 Watching
    i_love_cars said:
    Yesterday I ordered a CCA grill badge because I think E30s should just have those. I also ordered a set of hyper silver Apex ARC-8 wheels and new Direzza tires. The car won't make a full locking turn right now and rubs badly because the prior owner mistakenly bought 235/45 tires instead of 235/40, so they are wayyyy too tall. Plus I don't really like the E36 rims that are on the car. Good news is that I have brand new Rival tires from the Miata that I never installed, so Big Bear is letting me return those for a full credit towards the Direzzas, which makes the tires basically a wash. Big Bear also has a buyer for my E36 wheels, and after selling the Avanti wheels I had for the Miata, everything is basically a wash.
    I'm hoping everything fits, but still not sure. The E36 wheels are 7.5" with 41 offset and 12mm spacers around, and I have about 1" clearance between the strut and the top of the wheel when it is cambered in on the ground. I had to pick up 17x8.5 et40 from Apex, so I'm hoping they will still fit, but I ordered a set of 15mm spacers just in case. Still may be a little close but keeping my fingers crossed. Everything is getting fitted next week on Thursday.
    Nice. Check out www.willtheyfit.com for tire fitment needs.
    I did a new vs. old for you. First one is without spacers on the new wheels, second one is with the 15mm spacers.
    • i_love_carsI
      i_love_carsI
      i_love_cars
      awesome! looks like i won't even need spacers, or at worst a small one.
      2007 Z4MR
      2003 E39 M5
      2002 E46 M3
      2021 X5 40i
        According to the WDMV plate lookup, "SHTFCK" is available!
        This!  So much this!  It has to happen!
          Or RDRCKT... I check and it's available.
          • i_love_carsI
            i_love_carsI
            i_love_cars
            yup, did some math and took some measurements - looks like the rears will clear with no spacer at all as I have like 1.5" between the strut and the wheel, and it only adds 1.7mm of poke.
            The fronts will still require a spacer because the strut is closer to the wheel. It's got probably 3/4" or a bit more, so likely re-use the existing 12mm which would give about .46" closer to the strut and about .5" more poke which should work out given the tire will stretch a bit and be lower profile.
            2007 Z4MR
            2003 E39 M5
            2002 E46 M3
            2021 X5 40i
              You could also add a German twist to it
              ROTRCKT
              • i_love_carsI
                i_love_carsI
                i_love_cars
                RED ROKT would be alright. Double standard with south park and also the fact that it's a pretty fast street car that's red.
                Sidebar: 135 will be on the dyno next week on Wednesday morning
                2007 Z4MR
                2003 E39 M5
                2002 E46 M3
                2021 X5 40i
                  Am I the only one thinking of the gross type of red rocket? You know, that thing that happens when a male dog gets excited?
                  Which dyno are you getting on? I'm excited to see the numbers.
                  • i_love_carsI
                    i_love_carsI
                    i_love_cars
                    yea that's why i said "it's a double standard with South Park" because they did an episode on that one time, LOL.
                    I'm not actually getting that plate. I may not get any vanity plate if i can't think of something i really like.
                    I'll be up on LMT's dyno 😁  Should be a good day. immediately following that I'll be getting the new tires mounted on the Apex wheels for the E30, so i can go home and put htem on.
                    2007 Z4MR
                    2003 E39 M5
                    2002 E46 M3
                    2021 X5 40i
                      Ahh... I don't watch South Park. Glad we're all on the same page though 😆
                      If you put down monstrous numbers, I might have to pay them a visit for my car. Any guesses?
                      • i_love_carsI
                        i_love_carsI
                        i_love_cars
                        Hard to say for sure. The car isn't fully tuned yet but it is running smoothly enough that I think it's worth getting an initial dyno pull.
                        From all the dyno results I have seen on N55 pure stg2, targeting 21 psi on E50 has resulted in anywhere from 480-500. People running meth put down slightly better numbers ~530.
                        I would be happy to see 475 because that would show a gain of over 100 whp going from stock turbo to Pure. I'm more concerned with the gain than the raw number. Helps me validate the money I spent 😁
                        2007 Z4MR
                        2003 E39 M5
                        2002 E46 M3
                        2021 X5 40i
                          Double entendre, dual meaning.  Most definitely meant it as a dog boner and the fact that his car is red.  I went for the triple entendre with ROT RCKT since ROT is German for red, dog boners and he has a red car.  It was meant as more of a joke.
                            Side note, I had to explain to my boss what a red rocket is today and now he won't stop saying it.
                            • bk335B
                              bk335B
                              bk335
                              I know LMT is certainly not a heartbreaker. A FBO (no inlets) N54 335i on a E60 Wedge tune (~21psi peak) put down 450whp in 3rd gear, should be around 460whp in 4th gear (dyno operator couldn't figure out the kickdown I guess, idk haven't tried a 6AT e90). Meanwhile I put down 391awhp with minimal mods, stock dp's, stock fmic on 18psi with a few gallons e85 to prevent timing correction from high iat.
                              Anyways, I vote for SHTFCK
                              Slowest N54 in Wisconsin.
                                They've changed the calibration on the dyno relatively recently to sae correction, for whatever it's worth.
                                  This is my favorite t shirt in existence.
                                    Just checking in to ask how much you love it more than the miaturd
                                    And mainly checking in to ask how your plate submission forms went at the DMV.
                                    Because SHTFCK
                                    • i_love_carsI
                                      i_love_carsI
                                      i_love_cars
                                      New wheels are on. I could not possibly be any happier with how they look. Fitment is really good with 12mm spacers all around. I think I am going to drop to a 10mm just for peace of mind but right now I can get a full lock on the wheel again with no rub and driving over normal bumps so far is no problem.
                                      2007 Z4MR
                                      2003 E39 M5
                                      2002 E46 M3
                                      2021 X5 40i
                                      • The Full BananaT
                                        The Full BananaT
                                        The Full Banana
                                        Looks really good!
                                          i_love_cars said:
                                          Parking like a true BMW owner.
