I've never seen a bass guitar With live wells, so makes sense that your question was confusing. Carry on!
Been working on little things the past two days.
I "rebuilt" the throttle pedal assembly. Everything is brand new besides the lever itself. My old pedal return spring was snapped and not doing anything. I don't recall the pedal ever feeling bad so I was surprised to see that.
Old
New
I also got pads for the brake and clutch pedals
The steering column is also back in the car now. I placed an order for the fuel lines above the tank and need to start wire wheeling and undercoating the tank area under the car.
I have been really busy planning a GTG and what not lately but figured I would post some pictures of a few things to keep things lively in here
If you can't buy it, make it (new one is stainless)
I cleaned and painted the rear bumper carrier as well as the mounting brackets (and installed OEM hardware)
Finally scored a missing piece of the puzzle:
Racing Dynamics Non M lip
Unfortunately I wasn unaware that the lip is slightly different between the two non M bumper styles so I will have to make some reliefs in the top of the lip to fit around parts of the bumper vents. The good thing is that the lip isn't perfect and needs some fixing anyways.
You can see the small semi-circle reliefs now that are for fitting around the vertical slats in the wide slat style non m bumper. Those will be filled in as well.
I've always liked the racing dynamics lip. Nice find!
