    So you will have a return loop fuel setup? I just had my fuel pump electronic module fail on my P2 and discovered the complexity of the non return system...
    • The Full BananaT
      The Full BananaT
      The Full Banana
      Yep, using a standard return loop setup. Sticking with what I know works.
        Neat firewall connector
        Im not exactly a fan of mashing a bundle of wires through the firewall so this works well
        • The Full BananaT
          The Full BananaT
          The Full Banana
          It'll be convenient for my 4 minute F1 pit crew engine removals.
          • The Full BananaT
            The Full BananaT
            The Full Banana
            Drew up another little part tonight. A tab to weld on to the clutch pedal to aid in converting it from cable to hydraulic operation.
            Screen%2BShot%2B2016-05-17%2Bat%2B11.29.
              So you need a clutch master for that Tilton TOB unit, which acts as a slave. Why are there two hydraulic ports on the tilton unit? I would have expected just 1
                One for bleeding, at least thats how it is on my evo
                • The Full BananaT
                  The Full BananaT
                  The Full Banana
                  Correct, one is for bleeding, the other connects to the master.
                    Do you run a hard line out the side of the bellhousing to bleed it then?
                    • The Full BananaT
                      The Full BananaT
                      The Full Banana
                      Yep, im bending up stainless hard lines that will connect to bulkhead AN fittings in the bellhousing wall.
                      • The Full BananaT
                        The Full BananaT
                        The Full Banana
                        More things:
                        Fancy stainless heater hose fittings showed up, so I replaced the crusty original fittings.
                        I used 3/16" stainless with tube sleeves and nuts from McMaster, and bent up some hardlines for the hydraulic release bearing. They exit the bellhousing through 3an bulkhead fittings.
                        20t versus gtx3067r (this is with the wrong turbine housing that I had to send back)
                        Ford GT500 60lb injectors with spacers
                        Intake manifold is all welded up, ready for powdercoat.
                        Clutch pedal lengthened and new bracket welded on for the hydraulic master.
                        Transmission is ready to go in now. Bearing setup is complete (fingers crossed...), adapter is good to go, and all seals are replaced.
                        In the process of replacing my wiper motor, it became apparent that the source of a leak into the cabin was a missing seal. I found a PCV grommet at O'Reilly that fit (which was so tight that I had to press in) and I finished it off with some fresh butyl around the base. This was strangely gratifying to fix.
                        NOS 240 turbo coolant bottle installed on a powdercoated bracket I had laying around
                        Volvo 260 clutch master cylinder installed. I used a m12x1.0 banjo bolt and fitting that then connects to a 3an braided stainless line. I will end up routing this a bit more cleanly with a bent hardline.
                        My brother came down and helped me get the engine side of the bulkhead wiring harness connector fully terminated. You can also see the feed on the fuel rail--this will allow me to use the same fuel line I had made for the b21f manifold.
                        And a nice sealed Bussmann fuse and relay box to keep things simple for the Megasquirt wiring.
                        I'm behind "schedule" but I decided I would rather take a little more time and get the details just how I want them.
                        Turbine housing and exhaust manifold are out for ceramic coating right now... pretty excited to get those back from Count Snapula 😄
                        • The Full BananaT
                          The Full BananaT
                          The Full Banana
                          Intake manifold back from powdercoat
                          IAC bung and bracket for mounting the valve itself
                          I had a ton of help from two friends that came in from Kansas City and LA last weekend to visit. We managed to get the charge pipes and water pipe finished up, the downpipe started, and bunch of other miscellaneous things done. Also had a transformer nearby grenade while we were under the car attempting to install the transmission. That was fun.
                          Some miscellaneous pictures of the aftermath:
                          Hot-side charge pipe
                          Turbo and exhaust manifold both ceramic coated and installed
                          Cold-side intercooler pipe with IAC and IAT bungs
                          Flywheel, m5 clutch, 707 pressure plate installed
                          Lower heater hose installed. 960 heater hose cut in half connecting to factory fitting turned 90 degrees using a 3/8 NPT 90* elbow
                          Current state: wires everywhere
                          Today I'm working on getting the transmission in (I had to ditch the straight bulkhead fittings and replace them with 90 degree fittings to clear the tunnel) and then perhaps tonight I'll spend more time on the engine wiring harness. I've done a fair bit of work planning it out, but there's more I need to figure out and learn before I dive too deep into it. This part is not a strength of mine.
                          Overall, I'm really happy with how this is all coming together. I really can't wait to drive it.
                            Phenomenal!
                            • The Full BananaT
                              The Full BananaT
                              The Full Banana
                              Well, Snap has already beat me by a mile in the race to a running, driving car, but here's where this is at:
                              A couple pictures of things as I left them in the garage tonight. There's a bunch of other things going on (namely the engine wiring harness) but are the things you can actually tell what is going on.
                              Most of the bits are on the intake now. You can also see the banjo bolt on the far end of the plenum... that's one the factory Volvo bolts that has a check valve built in for use with PCV.
                              I decided I wanted to try making vacuum lines out of 3/16" stainless tubing.
                              Serpentine belt and associated bits are installed.
                              The oil cooler, thermostat, lines, and associated bracketry is all made/modified and installed now. I'm pretty happy with how this all worked out. Eat your heart out, Snap.
                                Did you bend the stainless lines by hand? Ya for progress.
                                • The Full BananaT
                                  The Full BananaT
                                  The Full Banana
                                  I used a cheap little bending tool from Harbor Freight. It works fairly well. The hardest part of the whole thing is getting a decent flare on the tubing.
                                    Looking amazing!!!
                                      Love how you are using lots of OE volvo stuff.
                                      I am jealous of your oil cooler but I think thats just about the smallest oil filter I ever did see!
                                      Cute lil guy
                                      • The Full BananaT
                                        The Full BananaT
                                        The Full Banana
                                        I've been working on this a lot, except when it's over 90 degrees in the garage because forget that. Yesterday afternoon I got the car back down on the ground for the first time since February. I drove it 8 feet back and forward, and then decided that I needed to wash it.
                                        It's clean again, phew.
                                        For extra content to offset my lazy post, here are a couple other details:
                                        Stainless hardlines that control the wastegate, and a bracket to secure them (the plastic bit will be replaced with something aluminum or stainless)
                                        Crankcase ventilation system is all plumbed as well (although I will be replacing these hoses with some Aeroquip hose when I get around to it). Two valve cover vents and the factory oil separator box outlet are plumbed into the ProVent, which returns to the intake pipe via a silicone hose underneath the front of the engine. The ProVent drains back into the oil pan through a fitting next to the dipstick.
                                        I bought a 28mm drop swaybar. This was necessary to clear my oil pan, and is the largest swaybar available for this car.
                                        And here's the harness connector finished off with some raychem 4:1 shrink and a 90 degree shrink boot.
                                        I've left out about 95% of things, so this seems like a good place to end this post. Next up is getting the car running well on megasquirt.
                                          That looks so good with the engine turned the right way...
