    I love seeing self-designed parts on peoples builds. Are you going to send the 3D file to a machine shop or are you going to give them a dimensioned print? If machining it from a block of alum is too pricey then I would have it quoted as 2 separate laser burnouts (plate) that get welded together and ground flat.
    • JeffJ
      JeffJ
      Jeff
      Custom parts are awsome!
      If you are looking for a place to make it let me know. Send me a file and I'll send you a price
      1976 530i e12
      1990 325ix e30
      1992 325i e36
      1995 740il e38
      2001 330xi e46
      ^More to come :)
      • The Full BananaT
        The Full BananaT
        The Full Banana
        Yeah, this was fun to do. Definitely the most complex/crucial part I've designed before. The thought is to send the 3D file, but if that doesn't work I can supply dimensioned drawings. I'm planning on having it machined out of one chunk. Material isn't cheap, but that's why eBay exists 😎
        Thanks, I'll send you a message! I don't yet have a plan for getting this machined.
        • JeffJ
          JeffJ
          Jeff
          Can't wait to check it out. I have a supplier for material I work with so material may not be as expensive as you think.
          1976 530i e12
          1990 325ix e30
          1992 325i e36
          1995 740il e38
          2001 330xi e46
          ^More to come :)
            I also have capabilities to turn this around quickly as well, and I'm sure no one can beat my prices. But I understand Jeff got first dibs. Just putting this out there if he might not have time etc.
            • The Full BananaT
              The Full BananaT
              The Full Banana
              ...I got the transmission adapter plate! Very relieved to have this done. Jeff did an awesome job. I highly recommend him.
              I threw a bunch of money at a proper pressure plate. It's a Sachs 707. I'll use this with a single mass flywheel from a Volvo 850 and the same organic e34 M5 clutch disc I used previously. Here's hoping it's not terrible to drive, but holds all the power I'll ever need.
              I found a pilot bearing to suit the 5 cyl crank and getrag 265.
              Pulled the old engine wiring out and labeled some things so I don't forget. I need to find a good place to mount the megasquirt shortly.
                The adapter is a beauty!
                  Gosh dang that's a really neat piece
                  • The Full BananaT
                    The Full BananaT
                    The Full Banana
                    crossposting from my thread in volvo-la-la-land. apologies if anything doesn't make sense.
                    I've been trying to keep good forward momentum with this project. It seems like I've gotten a lot done recently, but these pictures make it seem otherwise somehow...
                    I got a proper Tilton throwout bearing--so far it seems really nice. I need to drill and tap mounting holes for this and then space it out to the right position (~.75" of spacer if I recall correctly, but I need to triple check the measurements)
                    Today, a fuel rail came together, thanks to heavy intervention from a couple friends. I wanted a bolt-on fuel rail without too much internal restriction, and provisions for a 6AN feed fitting on the firewall end, a 1/8" NPT bung for a pressure transducer on the other end, and a FPR mounted on the rail between runners 1 and 2...
                    This is what we ended up with:
                    It's an S70 rail that has less internal restriction than the 850 rail, which we milled to accept the 850 FPR, and countersunk to fit beneath the factory injector retainer. We drilled out the original brass end cap and then milled an aluminum 1/8" NPT bung that was then welded in. My friend also welded a 6AN male bung to the firewall end of the rail. Additionally, I decided to take advantage of the extra port in the manifold (what was intended for the factory feed line) to also install a pulse dampener... if that actually does anything. A lot of fiddling, but I'm very pleased with it.
                    Let's see... what else. Cams and valve cover are installed, and the engine is timed. Zach powdercoated a bunch of stuff for me and it came out fantastic (which is now all dusty in the pictures). Wiring has also started.
                    I also have a great little bulkhead connector for the engine wiring at the firewall. I'm currently using 47 of 55 pins. A large chunk of megasquirt wiring inside the car is in progress.
                    I did buy a new stainless heater hose connector plate dingus that will get rid of that rusty eyesore...
                    Engine mounts brackets are in with new Yoshifab HD rubber engine mounts. As it turns out, these mounts are shorter than factory 240 mounts, so I had to compensate by adding spacers to get them to the 50mm total height I need. My friend milled these spacers as well.
                    In the process of getting the engine to fit, I had to pull it out a couple times to clearance the webbing on the oil pan until it was pretty flush with the oil transfer tube pocket.
                    Next step? I really need to buy my turbo. Also, throttle body linkage needs to get sorted out.
                    and then everything else.
                      So you will have a return loop fuel setup? I just had my fuel pump electronic module fail on my P2 and discovered the complexity of the non return system...
                      • The Full BananaT
                        The Full BananaT
                        The Full Banana
                        Yep, using a standard return loop setup. Sticking with what I know works.
                          Neat firewall connector
                          Im not exactly a fan of mashing a bundle of wires through the firewall so this works well
                          • The Full BananaT
                            The Full BananaT
                            The Full Banana
                            It'll be convenient for my 4 minute F1 pit crew engine removals.
                            • The Full BananaT
                              The Full BananaT
                              The Full Banana
                              Drew up another little part tonight. A tab to weld on to the clutch pedal to aid in converting it from cable to hydraulic operation.
                              Screen%2BShot%2B2016-05-17%2Bat%2B11.29.
                                So you need a clutch master for that Tilton TOB unit, which acts as a slave. Why are there two hydraulic ports on the tilton unit? I would have expected just 1
                                  One for bleeding, at least thats how it is on my evo
                                  • The Full BananaT
                                    The Full BananaT
                                    The Full Banana
                                    Correct, one is for bleeding, the other connects to the master.
                                      Do you run a hard line out the side of the bellhousing to bleed it then?
                                      • The Full BananaT
                                        The Full BananaT
                                        The Full Banana
                                        Yep, im bending up stainless hard lines that will connect to bulkhead AN fittings in the bellhousing wall.
                                        • The Full BananaT
                                          The Full BananaT
                                          The Full Banana
                                          More things:
                                          Fancy stainless heater hose fittings showed up, so I replaced the crusty original fittings.
                                          I used 3/16" stainless with tube sleeves and nuts from McMaster, and bent up some hardlines for the hydraulic release bearing. They exit the bellhousing through 3an bulkhead fittings.
                                          20t versus gtx3067r (this is with the wrong turbine housing that I had to send back)
                                          Ford GT500 60lb injectors with spacers
                                          Intake manifold is all welded up, ready for powdercoat.
                                          Clutch pedal lengthened and new bracket welded on for the hydraulic master.
                                          Transmission is ready to go in now. Bearing setup is complete (fingers crossed...), adapter is good to go, and all seals are replaced.
                                          In the process of replacing my wiper motor, it became apparent that the source of a leak into the cabin was a missing seal. I found a PCV grommet at O'Reilly that fit (which was so tight that I had to press in) and I finished it off with some fresh butyl around the base. This was strangely gratifying to fix.
                                          NOS 240 turbo coolant bottle installed on a powdercoated bracket I had laying around
                                          Volvo 260 clutch master cylinder installed. I used a m12x1.0 banjo bolt and fitting that then connects to a 3an braided stainless line. I will end up routing this a bit more cleanly with a bent hardline.
                                          My brother came down and helped me get the engine side of the bulkhead wiring harness connector fully terminated. You can also see the feed on the fuel rail--this will allow me to use the same fuel line I had made for the b21f manifold.
                                          And a nice sealed Bussmann fuse and relay box to keep things simple for the Megasquirt wiring.
                                          I'm behind "schedule" but I decided I would rather take a little more time and get the details just how I want them.
                                          Turbine housing and exhaust manifold are out for ceramic coating right now... pretty excited to get those back from Count Snapula 😄
