  4. '88 E30
'88 E30
savebigmoney
    Well after no movement on the tracking, I got them to refund my money. A hollow victory because now I have my money, but I'm out 4 weeks of time. Thinking on just throwing money at a GC setup.......
      #customerdisservice
      its hard to go wrong with an e30 - GC/BC/ACDC they are all TNT
        #customerdisservice
          Well ended up going with fortune auto coil overs. The 500 series. Ordered from AJ at endless, his prices were pretty good actually
          After some talks with snap, I settled on 8k front, 12k rear. He did some maths and what not and reminded me about my upgraded sway bars and such. He also has experience driving a car with his hr setup and also johns car with the 10k/12k setup and he pushed me towards a happy medium
            Woot=) Let's hope they arrive at your house this time
              8k/10k you mean, right?
                Yes i did mean that
                  Double checked my order to make sure haha. It is most certainly 8k/10k
                    you will be SO much happier with the fortune auto's. Blessing in disguise man! Night and day difference from BC.
                      Skid plate was very very close to the oil pan, I blame the chineseum core support. Made some spacers out of 1/8" flat stock to give some room between pan and plate
                      Then this
                      Now there's daylight (about a finger space)
                      Also noticed the steering linkage would bind a tad after putting everything back in so I filed the edge down barely.
                      Also did New VC gaskets and used some RTV to keep the oil where it belongs. "Reinstalled" my harness covers as well
                        #KaiserRollsMotorsports
                        Sell skid plate spacers, retire by 30
                        Banks HATE this one simple trick
                          Hahahah
                            Rear subframe went in last night
                            Only pic I took because I'm bad about that
                              what is the block you use between the jack stand and the car? i use wood block and destroy a couple every time i lift the car and its getting old.
                                Hockey pucks would probably work well
                                  Jackstands pads @ harbor freight.
                                  Super nice to use. A tad squishy but very strong & don't hurt your car.
                                  Think they are like $8 for two 452eec599b9882705fae1a4a2b960c3d.jpg87b23c78101fdd0b61674d9a2fe60720.jpg
                                  Way more pics than necessary
                                    +1 for hockey puck to avoid metal-metal with a jack under the diff or frame rails.
                                    For jack stands Harbor Freight has those red covers that work OK on their 3/6 ton stands.
                                    http://www.harborfreight.com/2-piece-rubber-pads-for-jack-stand-95952.html
                                    A couple of layers of duct tape is another option to avoid metal on metal contact.
                                      Too slow again....
                                        For the jack itself I use folded up rags taped to it so it doesn't scuff
                                          Thanks, will have to get a pair of those!
