  4. So, why exactly is my M3 sagging?
10 Posts 8 Posters 0 Views 1 Watching
  • faja92F
    faja92F
    faja92
    So the front passenger side of my M3 I'm working on has heavy devy sag. As in wheel well is touching the wheel. SO tell me since I've never worked on any suspension ever, is it a just a failed spring? or......
    let me know
    Thanks ahead of time
      Is the spring broken? Shock tower mounts in one peice?
        Earl used to own the front passenger side of that car and lowered it
        Or a broken spring,
        Or borked chassis/control arm
        • faja92F
          faja92F
          faja92
          lol, if Earl owned this vehicle, it wouldn't be riddled with such half-ass work. From preliminary glances, the shock tower mounts seem fine. I'll be pulling the wheel off this week and doing a good examination...
          I'll come back with what I find. Any advice on replacement/swap? If it is just a shot spring, can I swap just the front pair? or can I get away with just a single?
          • faja92F
            faja92F
            faja92
            This video actually has helped catch me up on a bunch of knowhow, or at least general what's what. I don't feel clueless at least.
              My 99 M3 broke a front coil spring and was sagging about half an inch on that side. I'd put my money on a broken spring
                I have stock m3 front springs is you need one=)
                  Did you or a previous owner like the larger portly women?  Extra abuse on that side?
                  • StriggityStrackS
                    StriggityStrackS
                    StriggityStrack
                    My M3 had one broken coil and I honestly didn't even notice until I swapped suspension. It must be a common thing for these cars.
                    • 6670charger6
                      6670charger6
                      6670charger
                      I had an E34 wagon in Germany that someone had put after market springs into the front of. When I bought the car, BOTH front springs were snapped and the front end sagged badly. If you have aftermarket springs in the car, I'd check there first. Seems like some of the aftermarket bits aren't nearly the quality they should be.
                      Appleton, WI
