    FINALLY got word from Bimmerheads that my fuel rail should be shipping early next week!!!  Also got all my blue linkage parts back from having the anodizing stripped - and redone in black.  And of course the hardware a done in more zinc...
      Looks pretty fancy
        Man, all of that zinc hardware looks tasty!
            the black is much improved over the blue.
              A bit of adjusting to do - but it's coming together nicely!!!
                Funny thing is, your injector selection is probably based on color more than size [emoji16]
                That would be my priority on something this beautiful. Cant be having 24# pink tops crashing the party
                  6 weeks later - it has arrived!
                  Drew up the fuel rail brackets, vacuum block bracket, and a modified linkage bracket (original one hits the fuel rail).  Should have them punched out by Friday at work - then I can keep chugging along!
                    Well.... This is pretty much how it should look once buttoned up:
                    Other then some fuel lines, vacuum lines under the manifold, and a vent line off the valve cover.
                    • The Full BananaT
                      The Full BananaT
                      The Full Banana
                      This looks wonderful. Really nice job getting everything cleaned up and refinished appropriately to suit those ITBs!
                        Updates m8
                          Updates m8
                          Not coming  together nearly as quickly as I'd like.  😒
                          Lots of parts ordered and arriving (still waiting on stack filters and some fuel fittings though).  Ordered and have installed most of the new pedal bushings since all the originals were literally falling apart - again though... Waiting on 1 last fitting to get that done.
                          The last 2 weeks have been busy with family stuff and starting my new position - so really need to crank out some god work nights this weekend and early next week if I'm going to make the picnic.
                            Random pics:
                              hope you do, all the other projects are dropping like flies for the picnic
                                It's looking like I'll make it unless I run into unforeseen issues.  All my parts are here or will be here by Mon/Tues... Big question will be the tuning.  Can I get it started and running well enough to drive to MKE in a very short period of time.
                                  I am here for you
                                    I am here for you
                                      Not a bad day in the garage!  Old cracked oil pan removed - new oil pan installed.  Also finished running brake lines so I can bleed tomorrow night.  Getting closer!
                                        With the help of Ben and Brian last night.... It ran!
                                        Acouple things I need to get fixed (self induced issues) - but it's close.
                                          Sounded pretty healthy in your snapchat! I really hope you can make it to the e30 picnic. It'd definitely be one of the better cars there.
