  3. BMW Discussion
  4. How do you feel about the new M3 being a turbo 6?
20 Posts 7 Posters 214 Views 1 Watching
  • e92boostE
    e92boostE
    e92boost
    Na not even close!! The standard one series are much lighter, With simple bolt ons and a tune those things are ridiculous fast.. YouTube it lol smash e92 M3s and even with gallardos
    Ben H.
    • Ryan...R
      Ryan...R
      Ryan...
      wow, I'll have to check that out once I get back home where the internet is quick enough to load youtube vids lol
      • L
        L
        LaCrosseJake
        Actually the 1M is lighter than the 135i by 77lbs @ 3296lbs.. I don't find that overly heavy, considering the e92 M3 is right around 500lbs more.
        And what do you mean the 1M has the same chassis as the e92 M3? It shares similar (possibly the same) control arms and trailing arms, but I wouldn't say it shares the same chassis.
        • e92boostE
          e92boostE
          e92boost
          Ah idk man I heard it's a M chasis with the 1M body on it... That's wider to fit it.. I'll find the link. Because the 135i lacks in the handling department. Maybe Im wrong. I'll post a video link later
          Ben H.
          • F
            F
            FRNTHVY
            Which engine versions did you use for the numbers below (E30 - 2.3 or 2.5, E36 - US motor or Euro, E46 standard S54 or CSL)?
            Sam
            i think bmw should just go back to a 6cyl such as the 330hp s54 and get the chassis weight back under 3000 lbs.
            here is the power to weight ratios of all m3s over the years:
            e30m3: 14 lbs per hp
            e36m3: 13 lbs per hp
            e46m3: 10 lbs per hp
            e92m3: 9 lbs per hp
            if the next m3 is 330hp and 3000 lbs it achieves the same power ratio as the e92! but instead they will make it 400+ hp and increase the weight by another 200 lbs again. did you know that the current e92 m3 weighs more than the e34 m5?
            unfortunately, the ///M cars are become less about being sports cars and more about having gadgets, driving themselves, and being comfortable.
              i used the base US versions for those numbers. 190hp e30 m3, 240hp e36 m3, etc.
              • F
                F
                FRNTHVY
                That's what I figured. I imagine the euro E36M has the best HP to weight combo.
                • Ryan...R
                  Ryan...R
                  Ryan...
                  It probably does, but I still imagine the e46 M3 was the better car in the handling department. I'd like to see a dyno from the euro M3 motor and the e46 M3 motor to see the power curve on each..
                  • e92boostE
                    e92boostE
                    e92boost
                    Tri turbo 3.3 V6 rumor lmao?! That's redic
                    Ben H.
                    • Ryan...R
                      Ryan...R
                      Ryan...
                      Good lord...... :(
