<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How do you feel about the new M3 being a turbo 6?]]></title><description><![CDATA[<p dir="auto">Link to Car and Driver article here: <a href="http://www.caranddriver.com/news/car/10q2/2013_bmw_3-series_rendered-car_news" rel="nofollow ugc">http://www.caranddriver.com/news/car/10q2/2013_bmw_3-series_rendered-car_news</a></p>
<p dir="auto">The article talks mostly about the newer, more efficient lineup of BMWs coming out in the future, but the part that stuck out to me the most was this:</p>
<p dir="auto">"But downsizing is the rage, and while there will still be an inline-six, the majority of 3-series models will be powered by turbocharged four-cylinder engines. <strong>The M3 may lose its V-8 and return to a six-cylinder engine, which is likely to be turbocharged"</strong></p>
<p dir="auto">I like that BMW has offered turbo options in some of the current cars, especially the 135i and 335i. But in my opinion, the M3 should NOT go FI. Part of what makes them so incredible is the fact that they're based around high revving, NA motors, specifically the I6. I feel like going FI is just a cheap way to beat the Audi competition. While I was initially not a fan of the new V8, its hard to not appreciate the 800000000 redline. I think BMW should either improve the NA V8, or develop the most kick-ass I6 ever built <img src="/assets/uploads/files/emoticons_default_smile.png" alt=":)" class=" img-fluid img-markdown" width="20" height="20" /></p>
<p dir="auto">Discuss!</p>
]]></description><link>https://wibimmers.com/topic/61/how-do-you-feel-about-the-new-m3-being-a-turbo-6</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 03:59:57 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/61.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 27 Mar 2011 16:43:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How do you feel about the new M3 being a turbo 6? on Thu, 21 Apr 2011 12:17:30 GMT]]></title><description><![CDATA[<p dir="auto">Good lord...... <img src="/assets/uploads/files/emoticons_default_sad.png" alt=":(" class=" img-fluid img-markdown" width="20" height="20" /></p>
]]></description><link>https://wibimmers.com/post/677</link><guid isPermaLink="true">https://wibimmers.com/post/677</guid><dc:creator><![CDATA[Ryan...]]></dc:creator><pubDate>Thu, 21 Apr 2011 12:17:30 GMT</pubDate></item><item><title><![CDATA[Reply to How do you feel about the new M3 being a turbo 6? on Thu, 21 Apr 2011 05:48:53 GMT]]></title><description><![CDATA[<p dir="auto">Tri turbo 3.3 V6 rumor lmao?! That's redic</p>
]]></description><link>https://wibimmers.com/post/676</link><guid isPermaLink="true">https://wibimmers.com/post/676</guid><dc:creator><![CDATA[e92boost]]></dc:creator><pubDate>Thu, 21 Apr 2011 05:48:53 GMT</pubDate></item><item><title><![CDATA[Reply to How do you feel about the new M3 being a turbo 6? on Fri, 08 Apr 2011 20:17:59 GMT]]></title><description><![CDATA[<p dir="auto">It probably does, but I still imagine the e46 M3 was the better car in the handling department. I'd like to see a dyno from the euro M3 motor and the e46 M3 motor to see the power curve on each..</p>
]]></description><link>https://wibimmers.com/post/581</link><guid isPermaLink="true">https://wibimmers.com/post/581</guid><dc:creator><![CDATA[Ryan...]]></dc:creator><pubDate>Fri, 08 Apr 2011 20:17:59 GMT</pubDate></item><item><title><![CDATA[Reply to How do you feel about the new M3 being a turbo 6? on Fri, 08 Apr 2011 01:19:39 GMT]]></title><description><![CDATA[<p dir="auto">That's what I figured. I imagine the euro E36M has the best HP to weight combo.</p>
]]></description><link>https://wibimmers.com/post/575</link><guid isPermaLink="true">https://wibimmers.com/post/575</guid><dc:creator><![CDATA[FRNTHVY]]></dc:creator><pubDate>Fri, 08 Apr 2011 01:19:39 GMT</pubDate></item><item><title><![CDATA[Reply to How do you feel about the new M3 being a turbo 6? on Thu, 07 Apr 2011 22:27:40 GMT]]></title><description><![CDATA[<p dir="auto">i used the base US versions for those numbers. 190hp e30 m3, 240hp e36 m3, etc.</p>
]]></description><link>https://wibimmers.com/post/574</link><guid isPermaLink="true">https://wibimmers.com/post/574</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Thu, 07 Apr 2011 22:27:40 GMT</pubDate></item><item><title><![CDATA[Reply to How do you feel about the new M3 being a turbo 6? on Thu, 07 Apr 2011 14:20:12 GMT]]></title><description><![CDATA[<p dir="auto">Which engine versions did you use for the numbers below (E30 - 2.3 or 2.5, E36 - US motor or Euro, E46 standard S54 or CSL)?</p>
<p dir="auto">Sam</p>
<p dir="auto"><strong>straight6pwr said:</strong></p>
<p dir="auto">i think bmw should just go back to a 6cyl such as the 330hp s54 and get the chassis weight back under 3000 lbs.</p>
<p dir="auto">here is the power to weight ratios of all m3s over the years:</p>
<p dir="auto">e30m3: 14 lbs per hp</p>
<p dir="auto">e36m3: 13 lbs per hp</p>
<p dir="auto">e46m3: 10 lbs per hp</p>
<p dir="auto">e92m3: 9 lbs per hp</p>
<p dir="auto">if the next m3 is 330hp and 3000 lbs it achieves the same power ratio as the e92! but instead they will make it 400+ hp and increase the weight by another 200 lbs again. did you know that the current e92 m3 weighs more than the e34 m5?</p>
<p dir="auto">unfortunately, the ///M cars are become less about being sports cars and more about having gadgets, driving themselves, and being comfortable.</p>
]]></description><link>https://wibimmers.com/post/573</link><guid isPermaLink="true">https://wibimmers.com/post/573</guid><dc:creator><![CDATA[FRNTHVY]]></dc:creator><pubDate>Thu, 07 Apr 2011 14:20:12 GMT</pubDate></item><item><title><![CDATA[Reply to How do you feel about the new M3 being a turbo 6? on Wed, 30 Mar 2011 19:21:16 GMT]]></title><description><![CDATA[<p dir="auto">Ah idk man I heard it's a M chasis with the 1M body on it... That's wider to fit it.. I'll find the link. Because the 135i lacks in the handling department. Maybe Im wrong. I'll post a video link later</p>
]]></description><link>https://wibimmers.com/post/514</link><guid isPermaLink="true">https://wibimmers.com/post/514</guid><dc:creator><![CDATA[e92boost]]></dc:creator><pubDate>Wed, 30 Mar 2011 19:21:16 GMT</pubDate></item><item><title><![CDATA[Reply to How do you feel about the new M3 being a turbo 6? on Wed, 30 Mar 2011 07:49:55 GMT]]></title><description><![CDATA[<p dir="auto">Actually the 1M is lighter than the 135i by 77lbs @ 3296lbs.. I don't find that overly heavy, considering the e92 M3 is right around 500lbs more.</p>
<p dir="auto">And what do you mean the 1M has the same chassis as the e92 M3? It shares similar (possibly the same) control arms and trailing arms, but I wouldn't say it shares the same chassis.</p>
]]></description><link>https://wibimmers.com/post/513</link><guid isPermaLink="true">https://wibimmers.com/post/513</guid><dc:creator><![CDATA[LaCrosseJake]]></dc:creator><pubDate>Wed, 30 Mar 2011 07:49:55 GMT</pubDate></item><item><title><![CDATA[Reply to How do you feel about the new M3 being a turbo 6? on Tue, 29 Mar 2011 22:24:50 GMT]]></title><description><![CDATA[<p dir="auto">wow, I'll have to check that out once I get back home where the internet is quick enough to load youtube vids lol</p>
]]></description><link>https://wibimmers.com/post/511</link><guid isPermaLink="true">https://wibimmers.com/post/511</guid><dc:creator><![CDATA[Ryan...]]></dc:creator><pubDate>Tue, 29 Mar 2011 22:24:50 GMT</pubDate></item><item><title><![CDATA[Reply to How do you feel about the new M3 being a turbo 6? on Tue, 29 Mar 2011 19:34:39 GMT]]></title><description><![CDATA[<p dir="auto">Na not even close!! The standard one series are much lighter, With simple bolt ons and a tune those things are ridiculous fast.. YouTube it lol smash e92 M3s and even with gallardos</p>
]]></description><link>https://wibimmers.com/post/510</link><guid isPermaLink="true">https://wibimmers.com/post/510</guid><dc:creator><![CDATA[e92boost]]></dc:creator><pubDate>Tue, 29 Mar 2011 19:34:39 GMT</pubDate></item><item><title><![CDATA[Reply to How do you feel about the new M3 being a turbo 6? on Tue, 29 Mar 2011 07:19:12 GMT]]></title><description><![CDATA[<p dir="auto">I was under the impression the 1M was lighter than a standard 1 series??? I could very well be wrong, I haven't looked into really..</p>
]]></description><link>https://wibimmers.com/post/508</link><guid isPermaLink="true">https://wibimmers.com/post/508</guid><dc:creator><![CDATA[Ryan...]]></dc:creator><pubDate>Tue, 29 Mar 2011 07:19:12 GMT</pubDate></item><item><title><![CDATA[Reply to How do you feel about the new M3 being a turbo 6? on Tue, 29 Mar 2011 04:30:43 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">That is, until the 1M came out, I think in the hands of a true enthusiast you'd have yourself an amazing little car. Lighter, better suspension/brakes, and a minor boost in power and you've got yourself a future version of the e30 M3 <img src="/assets/uploads/files/emoticons_default_smile.png" alt=":)" class=" img-fluid img-markdown" width="20" height="20" /></p>
<p dir="auto">Jake, if they go to a V6 I will cry myself to sleep <img src="/assets/uploads/files/emoticons_default_sad.png" alt=":(" class=" img-fluid img-markdown" width="20" height="20" /></p>
<p dir="auto">1 series M is a e92 M3 chassis with a N54 engine with a tune and a wide 135i body...dont get to happy! lol ( there are alot of cool things about it and it will be in my driveway in 2 years)lol heavy, the horse power bump is nice for the n54 but still.. its heavy...</p>
<p dir="auto">and unless that V6 is gonna be some thing to killllllll the competition ill hate it. even if it was amazing. i hate it. M3 + V6.. sounds fucking horrible.. excuse my french</p>
]]></description><link>https://wibimmers.com/post/505</link><guid isPermaLink="true">https://wibimmers.com/post/505</guid><dc:creator><![CDATA[e92boost]]></dc:creator><pubDate>Tue, 29 Mar 2011 04:30:43 GMT</pubDate></item><item><title><![CDATA[Reply to How do you feel about the new M3 being a turbo 6? on Tue, 29 Mar 2011 03:32:01 GMT]]></title><description><![CDATA[<p dir="auto">Charles, I agree with you statement about the 1M, that's the car I'm most excited about in all of BMW's lineup. After the e46 M3 I kind of stopped caring about BMW because I know I'll never own one newer than the lat year of the e46 M3. That is, until the 1M came out, I think in the hands of a true enthusiast you'd have yourself an amazing little car. Lighter, better suspension/brakes, and a minor boost in power and you've got yourself a future version of the e30 M3 <img src="/assets/uploads/files/emoticons_default_smile.png" alt=":)" class=" img-fluid img-markdown" width="20" height="20" /></p>
]]></description><link>https://wibimmers.com/post/503</link><guid isPermaLink="true">https://wibimmers.com/post/503</guid><dc:creator><![CDATA[Ryan...]]></dc:creator><pubDate>Tue, 29 Mar 2011 03:32:01 GMT</pubDate></item><item><title><![CDATA[Reply to How do you feel about the new M3 being a turbo 6? on Tue, 29 Mar 2011 02:36:24 GMT]]></title><description><![CDATA[<p dir="auto">I'm more worried about the rumors that it's going to be a <strong>V</strong>6. <img src="/assets/uploads/files/emoticons_default_sad.png" alt=":(" class=" img-fluid img-markdown" width="20" height="20" /></p>
<p dir="auto">I can understand turbocharging, it had to happen eventually.</p>
<p dir="auto">I feel if this V6 rumor is true, BMW officials must know something about 2012 that we don't. I mean the next generation M3 is due in 2013!</p>
<p dir="auto">God I hate German humor...</p>
]]></description><link>https://wibimmers.com/post/501</link><guid isPermaLink="true">https://wibimmers.com/post/501</guid><dc:creator><![CDATA[LaCrosseJake]]></dc:creator><pubDate>Tue, 29 Mar 2011 02:36:24 GMT</pubDate></item><item><title><![CDATA[Reply to How do you feel about the new M3 being a turbo 6? on Tue, 29 Mar 2011 01:50:22 GMT]]></title><description><![CDATA[<p dir="auto">Having a few 4cyl's back in the 3 series lineup wouldn't be the worst thing, but for the M3, I wish it could stay NA, but unfortunately, BMW, Audi, and Merc are forever locked into a horsepower battle, and when one goes up, the others must follow. Better power/weight just isn't something that the average consumer would understand, so I think a less powerful (but lighter and quicker) m3 is out of the question (with the exception of a spec. ed. CSL?). All hope may lie in the 1M.</p>
]]></description><link>https://wibimmers.com/post/500</link><guid isPermaLink="true">https://wibimmers.com/post/500</guid><dc:creator><![CDATA[Charles Dickens]]></dc:creator><pubDate>Tue, 29 Mar 2011 01:50:22 GMT</pubDate></item><item><title><![CDATA[Reply to How do you feel about the new M3 being a turbo 6? on Mon, 28 Mar 2011 18:19:43 GMT]]></title><description><![CDATA[<p dir="auto">Thanks, I wasn't sure if I had done something wrong <img src="/assets/uploads/files/emoticons_default_smile.png" alt=":)" class=" img-fluid img-markdown" width="20" height="20" /></p>
]]></description><link>https://wibimmers.com/post/498</link><guid isPermaLink="true">https://wibimmers.com/post/498</guid><dc:creator><![CDATA[Ryan...]]></dc:creator><pubDate>Mon, 28 Mar 2011 18:19:43 GMT</pubDate></item><item><title><![CDATA[Reply to How do you feel about the new M3 being a turbo 6? on Mon, 28 Mar 2011 15:46:12 GMT]]></title><description><![CDATA[<p dir="auto">Not sure why this was locked, reopened!</p>
]]></description><link>https://wibimmers.com/post/497</link><guid isPermaLink="true">https://wibimmers.com/post/497</guid><dc:creator><![CDATA[alexw]]></dc:creator><pubDate>Mon, 28 Mar 2011 15:46:12 GMT</pubDate></item><item><title><![CDATA[Reply to How do you feel about the new M3 being a turbo 6? on Sun, 27 Mar 2011 17:35:37 GMT]]></title><description><![CDATA[<p dir="auto">i think bmw should just go back to a 6cyl such as the 330hp s54 and get the chassis weight back under 3000 lbs.</p>
]]></description><link>https://wibimmers.com/post/474</link><guid isPermaLink="true">https://wibimmers.com/post/474</guid><dc:creator><![CDATA[straight6pwr]]></dc:creator><pubDate>Sun, 27 Mar 2011 17:35:37 GMT</pubDate></item><item><title><![CDATA[Reply to How do you feel about the new M3 being a turbo 6? on Sun, 27 Mar 2011 16:52:11 GMT]]></title><description><![CDATA[<p dir="auto">to be honest... i think the e9x M3's were a total fail to heavy to slow to much gadgets... i mean my neighbors new mustang GT equals it quarter mile, o-60 and around the track.. (nothing wrong with mustangs but not my cup of tea) BMW must do something different, FI is the thing of the future for BMW, the turbo diesels are here and four cylinder turbos are on its way to the states.. V8 turbo for the new M5 and X5M X6M.... Its coming to us wether we like it or not. I think BMW did lose its touch on the M cars. Idk this is gonna be a huge argument for a long time. My chipped 335i beats e92 M3s... and the 1 series M has a tuned N54 engine, so idk it might be interesting to see what route BMW is going to go with their new M....</p>
]]></description><link>https://wibimmers.com/post/471</link><guid isPermaLink="true">https://wibimmers.com/post/471</guid><dc:creator><![CDATA[e92boost]]></dc:creator><pubDate>Sun, 27 Mar 2011 16:52:11 GMT</pubDate></item></channel></rss>
