  4. e34 Touring
e34 Touring
269 Posts 26 Posters 4.5k Views 1 Watching
    You can buy BMW coolant at Oreilly's.  It's Pentosin NF.
      All the n5x guys with catless downpipes are causing acid rain so I would advise against using that for your radiator.
      Thumbs up for whatever motivates you to bang this stuff out.
        I had no idea there was so much dislike for coolant lol.
        What's next on the to do list Dan?
          Use the BMW blue coolant. When it leaks you can just pretend it's washer fluid and ignore future repairs.
            Curious what the B40 intake will do to the power band, nice work as always Dan!
              drove it 80 miles today, no leaks and runs like a top. it definitely moved the power band and i love it already. a little less low-end (the low-end only helps people who never rev it up with their automatics) but the power doesnt fall off till 5500-6000 which is perfect since redline is 6500.
                the next project lurks in the closet...
                  Way to put a damper on things
                    that joke was shockingly good
                      Magical things happen when spring is in the air
                        Way to rebound after the rain and still want to work on your car
                          Doorman
                          White plastic round thinga-majig mod?
                            when i took off my stock intake manifold, i heard a rattle inside so i had to investigate.
                            found out that the early m60b30 intake manifold has individual velocity stacks inside, just like the early m60b40 manifold. BMW later did away with them and did a simple curved mouth integrated into the manifold molding, obviously to reduce cost. the later b30 manifold i pulled off the parts car did not have the stacks.
                              Cool!
                                took advantage of the perfect day today as much as I could, and prepped the car for the suspension refresh. hopefully i can get to it next weekend.
                                for the touring, basically the entire rear interior has to come out. rear door seals, c-pillar trim, all rear carpeting panels, jack storage tray, rear seat bottom and bolsters, etc.. its an easy job but lots of effort to just to get to the rear strut mounts.
                                found this greasy gunk between the carpet panel and the sound deadening. no idea how it got there, there's not a single thing around there that could have leaked it. mystery. ???
                                here are all the goodies. went with vogtland 40/20 springs, koni sport adjustables, new strut mounts/spring pads/bump stops all around. car will be also be getting rear dog-bone links and a manual trans fluid change. i dont think the zf likes the royal purple.
                                also had time to modify my LKM finally. for the e34, this module handles all the check controls for the lights. i have had the 'LOW BEAM' warning since i did the bixenon retrofits headlights. the module is just checking for voltage draw, so you just jump the headlight and foglight pins to a ground and it bypasses the check. some guy in japan figured this all out, but i made an easier to use diagram than the verbal instructions out there. its possible that 'Chip A' could be low beam and 'Chip B' could be fogs,  it was hard to tell from what i read online, so i did both in case and my headlight warning is gone.
                                  Bypass all the check panel warnings
                                  Ignorance is bliss
                                    My zf absolutely hated royal purple. Went with redline mtl, made a world of difference.
                                      If royal purple wasnt purple then nobody would buy it.
                                        what symptoms did you have?
                                        i went with RP because i had no idea how abused or worm the trans was, and it would barely go into gear on the parts car (not running). it sounded like a good option, and had good reviews, for hard shifting/high mileage boxes.  however, that didnt end up being the case, as it was just the shift linkage was all f*d up and the trans is fine. the symptoms i'm having that i think are from the RP: 1) sometimes randomly after stopping at light, its hard to get it back into first  2)the syncros (i think) make noise all the time, it sounds like a mini forumla 1 car inside in there, even though the syncros work fine.  3) when its cold, its like shifting in molasses.  4)i can't shift fast. if i throw it from 1st to 2nd as fast as i can, it crunches a little. not like gear grinding, i can just feel it in my hand.  maybe this particular model of zf trans is just crappy and that's normal?  i've never had another car do that.
                                          Extremely hard shifting when cold, especially when it was 45 degrees or colder outside.
