  4. 1991 318is M62B44 Build
268 Posts 27 Posters 4.3k Views 1 Watching
  • CMartC
    CMartC
    CMart
    Brakes system is done.
    Engine and trans are back in.
    Headers were ceramic coated and installed.
    Cant decide if I should do the coils now so I only have to bleed once or down the road. Other than the height change will installing the new coils/knuckles change the steering to the point where I'll need an immediate alignment?
    Excursion 7.3
    E30 LS1
      You should be fine if you want to wait for an alignment, not much is going to change a whole lot. I've always believed you should actually wait a little until everything settles anyways.
      • CMartC
        CMartC
        CMart
        A ton more progress last night. Did a test fit of the headlights and hood and luckily my dimensions spot on.
        All the routing (gas, coolant, PS, oil, clutch) is officially done, which was a huge headache. Waiting to make a mount for the PS reservoir after I do some more thinking on it. Overall much much cleaner than it last was and I am very happy with the outcome.
        Really don't have much left before she is road worthy again and I start working the bugs out. Now if only this weather would cooperate...
        Excursion 7.3
        E30 LS1
        • CMartC
          CMartC
          CMart
          No progress on the car, but I did score a sick deal on a 6 piston front 4 piston rear wildwood 310mm big brake kit for the M3. Huge upgrade over the single piston OEM setup.
          Excursion 7.3
          E30 LS1
          • CMartC
            CMartC
            CMart
            Just went to install the BBK onto the coilovers and found the guy who sold me the BBK lied and they didn't get the corrado rotor center opened up to fit on the e30 hub.. Not too happy about it, but before I throw a few back, and turn my E30 into a redneck lathe, does anyone have or know of someone with a lathe? Will literally take 10 minutes...
            Excursion 7.3
            E30 LS1
              Corrado discs? I thought you said for the m3 but that makes no sense
              • CMartC
                CMartC
                CMart
                Whoa bad coincidence.
                I realized I hadn't started a LSM3 thread so I just noted that was a good score.
                Totally unrelated I have coilovers and BBK (RX7) for the 318/M62. Everyone runs corrado rotors with that kit, but the hub of the disc needs bored out. I went to install it and the disc isn't sitting flush with the face of the hub so I need someone to lathe them out so I can get them ready to install.
                Excursion 7.3
                E30 LS1
                • CMartC
                  CMartC
                  CMart
                  Car is running like a top.
                  Need 15 minutes of the girlfriend's time to bleed the brakes and then she is road ready. Hopefully I can get some better videos this time.
                  Excursion 7.3
                  E30 LS1
                  • CMartC
                    CMartC
                    CMart
                    Does anyone know where I can get the rotor hubs bored out? Just need a basic lathe.
                    Excursion 7.3
                    E30 LS1
                      Dan the Exhaust Man has a lathe. He is in Richfield.
                      • CMartC
                        CMartC
                        CMart
                        Contact info? I can't seem to find him on the google machine.
                        Excursion 7.3
                        E30 LS1
                        • CMartC
                          CMartC
                          CMart
                          Edit - Figured out my issue. Blower motor is now working which means proper bleeding which means closer to being on the road.
                          Excursion 7.3
                          E30 LS1
                          • CMartC
                            CMartC
                            CMart
                            Got quite a bit done today.
                            Started getting the interior back in which is cool to see.
                            I setup the OBDII port and its working with my phone, which is really cool to see. Only M62 swap I know of that has kept the OBDII functionality.
                            I've got a few more wires to chase down. RPMs aren't working and neither is my coolant temp gauge. The RPM is confusing me so I have some work to do around that, but I am thinking ground.
                            Things are getting close though.
                            Excursion 7.3
                            E30 LS1
                            • CMartC
                              CMartC
                              CMart
                              Also, does anyone work at a BMW dealership that can get me a radio code?
                              Excursion 7.3
                              E30 LS1
                                Just call Umansky and they can do it over the phone with your serial number. Also what was the solution to the blower issue?
                                • CMartC
                                  CMartC
                                  CMart
                                  I had a wire that I either did not understand or was mislabeled. I grounded it and heard a click, which was the relay for the windows, power mirrors, and blower.
                                  Excursion 7.3
                                  E30 LS1
                                  • CMartC
                                    CMartC
                                    CMart
                                    Car is back to running. Everything is tight, all gauges working except coolant which I am tracking through OBDII, and the RPM is working, but not accurate because the garagistic module isn't working. All of the interior expect the passenger seat and glove box since I am still working on some wiring.
                                    I do have a wicked belt squeal that goes away if I spray some chain lube on it. Not quite sure why its there, brand new belt and it didn't do it last time I drove it. I am assuming its belt related not pulley since it goes away with spray. Any ideas?
                                    Excursion 7.3
                                    E30 LS1
                                      Tension on the belt still as it should be?
                                      And not surprised about anything garagistic not working as it should
                                        Check to see if a pulley needs to be shimmed in or out to bring it into alignment with the others
                                        • CMartC
                                          CMartC
                                          CMart
                                          Will do thanks. Not happy about having to take the radiator back out though... Finally got it all bled.
                                          And yeah I've been very unimpressed with them. They did respond saying it was a known issue so I'm hoping they get me a replacement even though I bought it months ago.
                                          Excursion 7.3
                                          E30 LS1
