  4. 1991 318is M62B44 Build
268 Posts 27 Posters 4.3k Views 1 Watching
    I've had custom lines done at Hartland Service. Excellent job, done right while I waited, and very good prices.
    • CMartC
      CMartC
      CMart
      Just called them. They seem great - looking forward to throwing some business their way.
      Excursion 7.3
      E30 LS1
        They're awesome. A few friends and I have been using them for years. They actually custom made me braided stainless brake lines for much less than you could buy them anywhere. I need to see them soon to have power steering lines made as well.
        • CMartC
          CMartC
          CMart
          Well I was able to get creative with some extra lines.
          Power steering is hooked up and the oil filter is relocated.
          Before picture - notice how cramped (the oil filter) that would be with the brake booster relocation
          And now:
          Now I am going to redo all the brake lines (in the mail), install the coils and BBK while I am at it.
          I got the wiring moved into the interior so that is progress, but it still needs to be cleaned up. Whole interior back in. I'll probably take the motor/trans out to redo the brake lines and clean everything up while its out.
          Then throw some miles to work any potential gremlins out, put it up for sale, and start work on the LS M3.
          Excursion 7.3
          E30 LS1
          • CMartC
            CMartC
            CMart
            Here is a better picture of the only place the remote oil filter fit with everything attached.
            Much better here now and still easy to access for oil changes.
            I'll probably wait until next week to pull the motor so more updates to come then.
            Excursion 7.3
            E30 LS1
              Awesome work!
              • CMartC
                CMartC
                CMart
                Motor is back out to redo the brake lines.
                Looking forward to getting the motor back in, it will be much cleaner than the last setup. I also painted the remote booster reinforcement plate.
                Excursion 7.3
                E30 LS1
                • CMartC
                  CMartC
                  CMart
                  Brakes system is done.
                  Engine and trans are back in.
                  Headers were ceramic coated and installed.
                  Cant decide if I should do the coils now so I only have to bleed once or down the road. Other than the height change will installing the new coils/knuckles change the steering to the point where I'll need an immediate alignment?
                  Excursion 7.3
                  E30 LS1
                    You should be fine if you want to wait for an alignment, not much is going to change a whole lot. I've always believed you should actually wait a little until everything settles anyways.
                    • CMartC
                      CMartC
                      CMart
                      A ton more progress last night. Did a test fit of the headlights and hood and luckily my dimensions spot on.
                      All the routing (gas, coolant, PS, oil, clutch) is officially done, which was a huge headache. Waiting to make a mount for the PS reservoir after I do some more thinking on it. Overall much much cleaner than it last was and I am very happy with the outcome.
                      Really don't have much left before she is road worthy again and I start working the bugs out. Now if only this weather would cooperate...
                      Excursion 7.3
                      E30 LS1
                      • CMartC
                        CMartC
                        CMart
                        No progress on the car, but I did score a sick deal on a 6 piston front 4 piston rear wildwood 310mm big brake kit for the M3. Huge upgrade over the single piston OEM setup.
                        Excursion 7.3
                        E30 LS1
                        • CMartC
                          CMartC
                          CMart
                          Just went to install the BBK onto the coilovers and found the guy who sold me the BBK lied and they didn't get the corrado rotor center opened up to fit on the e30 hub.. Not too happy about it, but before I throw a few back, and turn my E30 into a redneck lathe, does anyone have or know of someone with a lathe? Will literally take 10 minutes...
                          Excursion 7.3
                          E30 LS1
                            Corrado discs? I thought you said for the m3 but that makes no sense
                            • CMartC
                              CMartC
                              CMart
                              Whoa bad coincidence.
                              I realized I hadn't started a LSM3 thread so I just noted that was a good score.
                              Totally unrelated I have coilovers and BBK (RX7) for the 318/M62. Everyone runs corrado rotors with that kit, but the hub of the disc needs bored out. I went to install it and the disc isn't sitting flush with the face of the hub so I need someone to lathe them out so I can get them ready to install.
                              Excursion 7.3
                              E30 LS1
                              • CMartC
                                CMartC
                                CMart
                                Car is running like a top.
                                Need 15 minutes of the girlfriend's time to bleed the brakes and then she is road ready. Hopefully I can get some better videos this time.
                                Excursion 7.3
                                E30 LS1
                                • CMartC
                                  CMartC
                                  CMart
                                  Does anyone know where I can get the rotor hubs bored out? Just need a basic lathe.
                                  Excursion 7.3
                                  E30 LS1
                                    Dan the Exhaust Man has a lathe. He is in Richfield.
                                    • CMartC
                                      CMartC
                                      CMart
                                      Contact info? I can't seem to find him on the google machine.
                                      Excursion 7.3
                                      E30 LS1
                                      • CMartC
                                        CMartC
                                        CMart
                                        Edit - Figured out my issue. Blower motor is now working which means proper bleeding which means closer to being on the road.
                                        Excursion 7.3
                                        E30 LS1
                                        • CMartC
                                          CMartC
                                          CMart
                                          Got quite a bit done today.
                                          Started getting the interior back in which is cool to see.
                                          I setup the OBDII port and its working with my phone, which is really cool to see. Only M62 swap I know of that has kept the OBDII functionality.
                                          I've got a few more wires to chase down. RPMs aren't working and neither is my coolant temp gauge. The RPM is confusing me so I have some work to do around that, but I am thinking ground.
                                          Things are getting close though.
                                          Excursion 7.3
                                          E30 LS1
