  4. '88 E30
'88 E30
    To be fair, earls idea is pretty slick and the next time there is a worldwide macho allen shortage I will try to remember it
      It is a nifty idea. But I'm probably in the same boat as I don't have a bolt that exact size
        So went to Sears and some other places. Nobody had an Allen that large. So I just bought a bolt and a few nuts. Gonna use the earl method.
          A hex socket set would probably have the right size, you can buy the gear wrench set at Sears or Advance Auto.
            Looked for those as well. No luck.
            Bolt & nuts worked fine
            Fluids in and plugs are tioght
              I used a short bolt with a nut and welded them together. On the e36 you can't fit anything longer between the dif and spare tire well when in the car.
                New trans fluid is in. Went with redline MTL. also made a list which I immediately regretted. Pretty much ran out of cardboard.
                  Patiently waiting for coilovers to show up........
                    Coilovers are due to ship in about a week.
                    In the meantime I've been looking at buying new wheels/rubber. I have it narrowed down to 15x8 so I can run the bfg rivals 205/50/15. They seem to run bigger. Pics of them on 8s actually look relatively square which I'm happy about. Or the hankook rs-3 in 225/45/15. Both will fit and be relatively square and cost pretty much the same .
                    Trying to narrow down some wheels. They need to be 15x8, light, affordable and look okay. I'd also rather not run spacers but will if I have to
                    So far:
                    15x8
                    14.6 lbs
                    20mm offset
                    $109 each
                    15x8
                    20mm offset
                    13lbs
                    $138 each
                    15x8
                    20mm offset
                    13.5lbs
                    $109 each
                    Here's what the bfgs look like on 8s for example on the left dc22294ae529eda796649a31a2a41b4c.jpg
                    I will be selling my 15x7 k1s
                    I know they will probably work fine for me but I want something different and really want an 8" wheel for the future tire size changes
                      both those tires looked stretched to me....
                        That's why I said relatively square................................................
                          Tread width is 6.9" on a 205. 8" wheel. 100% not square, but relatively square compared to some of the crap that people run
                          This is why I'll probably go with a 225/45/15 rival. 7.9" tread width on an 8" wheel
                            I do prefer a slight "stretch"
                            I think the pictures above that you posted look fine to me.
                            I run a 225/45/16 on a 16x8, getatmebro
                            A friend has 225's on a 7" wheel and it looks a touch ballooned for my liking, for his car anyway.
                            I like starting new lines for every sentence.
                            Why do you live so far away
                              The Kosei K8R are the clear winner for me. Other two are nice, but meh. I had K1s on my Miata and always wished they were wider. Debated buying those same C1s to replace them, but I'm glad I didn't. I love the way the K1s look.
                              Both tires look stretched in that picture. I would definitely get the 225 at minimum.
                                It's a toss up between the k5r and the k8r for me right now. 225 is for sure going on them
                                  Oops, I meant K8R, not the K5R.
                                  K8R is way better.
                                    I've been asking a bunch of people. K8r has been the consensus. I like the k8r simply because the k5r looks similar to what I already have
                                      I say C1 since I think the other two look awful...
                                        I'll eventually be running 225/45 RS3s on my car with 15x9s. I vote for the K8R wheels out of the 3 choices.
                                          Lesser of 3 evils earl?
