  4. 1999 M3 daily driver running log
264 Posts 28 Posters 5.0k Views 4 Watching
    the hard part is differences between units. unless someone has done your specific unit, or you are an electrical engineer, its pretty much a crap shoot.  I imagine Chris's e34 doesn't have a CD43.  For my e30, I had to buy a tape deck (there are like 50 versions) that someone had already figured out that model. I couldn't get my slightly different unit to work with the same DIY.
    I was lucky enough that the unit I have (C43) had that really good DIY, I believe the C43 can be adapted to quite a few cars as it is a standard size and they usually go for fairly cheap compared to a CD43.
      Picked up a set of wheels that I am super stoked about:
      18x8 et35 BBS RE 847
      They were used as winter wheels so the paint is bubbling a bit in a few places but the rest of my car is the same story so it doesn't bother me, down the road a light refinish and they will be good as new.
        Nice score!
          Nice! What did you end up paying for those? Craigslist find?
            Got them off the Milwaukee craigslist from a guy in Pewaukee. Ended up buying them for less than the cost of a single new one so I'm really happy with that!
              Driver's side caliper seized up on me and got so bad I had to park the car last Thursday until the brake parts I had ordered the day prior showed up. When they arrived in the middle of the week, I was hoping to rebuild the calipers and get back on the road. I got everything apart and attempted to use the pressure of the braking system to push out the caliper but I soon realized they weren't worth rebuilding even though they looked alright on the outside:
              I bought a pair of calipers (remanufactered ones from WBR) and was able to get everything installed this weekend.
              24555529773a7e8a2e952b.jpg'
              I replaced the rotors, pads, calipers, pad wear sensor, upgraded the lines to UUC braided stainless ones, and flushed the system with Ate Type 200 fluid.
              I will note that I was a bit disappointed in UUC's lines, as the fitting that meets the hardline was too small and was able to pass through the mount on the body. I had to drill out a washer to fit snugly over the line to get it to secure in place properly.
              You can see the washer just underneath the white bracket in the middle.
                Wait a second
                What's with the name change?
                You must have been....
                bored.
                [emoji1300]
                  I was super bored... and since I'll probably be driving the M3 instead of the e30 for a while it seemed appropriate
                    Did this today:
                    Wrapped them in Continental ExtremeContact DW's, really impressed with this tire so far! Also put on a 5-speed ZHP knob and it definitely helped smooth out the shifts.
                    I am having some minor vanos rattle and it's driving me crazy... so I ordered the Beisan systems single vanos seals and anti rattle kits, as well as all the related gaskets and the upper timing chain tensioner. Hoping to get to that job next weekend
                      Doorman
                      Looks sweet!!!
                      Sometimes I think I want an e36......
                      • The Full BananaT
                        The Full BananaT
                        The Full Banana
                        That looks great!
                          Thanks guys!
                          This evening finally got around to installing my AKG delrin clutch and brake pedal bushings.
                          The clutch pedal had quite a bit of slop and was bent to the left pretty badly. The brake pedal was more or less fine but I did it anyway because I was in there already. Now they are both really solid, and the clutch pedal is just about back to where it is supposed to be. I cleaned up and re-lubed everything as I re-assembled it too. The effort needed to push the clutch is a lot less than before so that is an added bonus.
                            This makes me want to buy another e36!
                              those BBS wheels look amazing on the car, nice choice!
                                Did this today:
                                Saw your post on r/BMW. Wheels look great on the car.
                                  I wasn't happy with the thread engagement on the stock lug bolts so I installed a Motorsport Hardware 57mm stud conversion. Excuse the super dirty car haha
                                    I've got Motorsport Hardware studs on both of my e36's and they're great=)
                                      I've gotten a lot done on the car in the last few weeks thanks to a bit of a scare related to a few metal shavings...
                                      I rebuilt the vanos using the Beisan Systems seals and anti-rattle kit
                                      Didn't get any pictures of the actual vanos unit rebuild, but it went smoothly and reinstalling everything was easy as I had all the proper tools.
                                      Next, I dropped the oil pan in order to safety wire the oil pump nut and install a Z3 2.8 oil pickup tube. The oil pump nut was nice and tight but I took it off anyway to reinstall a drilled nut with safety wire and loctite. Also put in a magnetic drain plug from Turner to keep an eye on any shavings in the engine and keep them out of the oil pickup. The magnet is super strong so it should catch just about everything that falls down there.
                                      While I was in there, I also installed new motor mounts and front sway bar bushings. Reinstalling the subframe and steering rack was a struggle by myself but I managed to get it done, definitely don't want to do that job again any time soon. After all this work the car feels 100 times better than before. I have so much more torque in the low end so the car isn't so finicky off the line, and the vanos rattle is basically gone. Also, having the peace of mind of a secure oil pump nut and reinforced pickup tube makes it a lot more enjoyable to drive.
                                      I have my electric fan wired to a manual switch as I like to have control over it, but I could never tell when it was on thanks to my exhaust. I found some LED's that are color matched to the BMW interior amber lighting and wired one as an indicator light for my fan. I wired it with a 690ohm load resistor in parallel with the control side of the fan relay and it works like a charm. I'm planning on painting the mounting bezel black once I have some paint available but for now it works great. Pardon the dirty interior..
                                      Next thing on the list is rebuilding the power steering pump and replacing the power steering lines as they are getting pretty crusty and leaking at the reservoir. I will be taking a road trip from Milwaukee to eastern North Carolina around the 4th of July, so I am hoping to knock out quite a few maintenance items and repairs before then.
                                        Where did you buy the led's?
                                          http://www.bimmerforums.com/forum/showthread.php?2025442
                                          I found them here, but bought them through the eBay link in post #4.
