  4. The E46 M3 Journal
The E46 M3 Journal
e46m3
    DIS/INPA links for reference:
    Modify Vagcom Cable
    Connection Problems DIS to Car
      I don't know what I'm doing but it is talking to the car!!!
        Got the INPA up and running. Does this mean I need to bleed my clutch? Help!
        • T
          T
          tsweers89
          Alright if your not going to do anything with this just use AAA and tow it down to me. I will get is started for you no problem.
            I see that you got it running. What was preventing it from starting?
              Used the INPA software to bleed the clutch and gearbox shifter. Ran the programs and it went into R & 1. Got excited then went to start it and it fired up on the 2nd crank!!!!!
                i bet that was a glorious sound!
                  Good job! I can imagine how frustrating that was!
                    Straight headers! My wife said the whole house was shaking.
                      I was trying to get the computer to connect to the car for 1 hour only to find out the USB plug was in the wrong port.
                        Nice job man! must feel great to have the extra experience and know-how of swapping the engine on that thing under your belt to make any future repairs and diagnostics a bit easier.
                          Doorman
                          Bravo brotha!!
                            Thanks guys!!
                            Have to put in an order at the old Concours for some small stuff. Plastic connectors, washer fluid o-ring and some nuts.
                            I ran 5 liters of some cheap 5w-30 through it for start up. I have some bmw 10w60 oil & filter ready to go.
                            So excited!
                              Well shoot... after installing the driveshaft it hit the fan.
                              I didn't know that I had to adjust the pressure plate when I installed a new clutch.
                              Now it is grinding gears when I try to out it into R. It goes into 1 now and then.
                              Taking it to the dealership to finish the job.
                              Gotta pull the trans.
                              • CMartC
                                CMartC
                                CMart
                                Nooooo
                                You came so far, finish that shit.
                                Excursion 7.3
                                E30 LS1
                                • T
                                  T
                                  tsweers89
                                  Wait so you installed a new clutch and pressure plate or clutch disc? If you did a whole new clutch and pressure plate you need to run through the clutch break in procedure and clutch wear point test plan as well. If you did just a clutch disc then they clutch plate would need to be reset as with all e46s its a self adjusting clutch so you need to special tool to turb back the springs when isntalling. Eitherway unfortunately this is what happens in the enthusiast world when guys think they can work on it all themselves on vehicles/systems they know nothing about. Hate to see it but I see it often.
                                  • T
                                    T
                                    tsweers89
                                    Funny as I have to do this right now.
                                    • CMartC
                                      CMartC
                                      CMart
                                      You own a mechanic shop right?
                                      You really need to work on your delivery/interpersonal skills.
                                      Excursion 7.3
                                      E30 LS1
                                      • T
                                        T
                                        tsweers89
                                        I speak the truth whether you want to hear it or not. This wasn't a call out to him individually, saying he cant work on cars right. This was to the bmw community as a whole. Its one thing to work on e30s and e36s but once you get into a technical system like smg or such you need to know whay your doing as you can cause serious damage if you dont. Hell if he would have drove it for awhile he could have done serious damage to the transmission.
                                        • CMartC
                                          CMartC
                                          CMart
                                          Here is your statement:
                                          Here is what you could have said:
                                          Wait so you installed a new clutch and pressure plate or clutch disc? If you did a whole new clutch and pressure plate you need to run through the clutch break in procedure and clutch wear point test plan as well. If you did just a clutch disc then they clutch plate would need to be reset as with all e46s its a self adjusting clutch so you need to special tool to turb back the springs when isntalling. Eitherway unfortunately this is what happens due to bmw over engineering their cars and requiring tools and software not available to most people. Hate to see it but I see it often.
                                          Say what you want, but if want more business don't treat people (potential customers) like morons, whether you think they are or not. I for one wouldn't come to your shop or recommend you regardless of your pricing, quality, or turn around.
                                          Excursion 7.3
                                          E30 LS1
