  4. The E46 M3 Journal
The E46 M3 Journal
536 Posts 34 Posters 0 Views 1 Watching
    Is a traditional 6spd a huge endeavor to swap? Im sure the dealer will get this all sorted out quickly but just curious if the swap is more hassle than its worth/better off buying a non-smg
      All I would need is a bell housing, a third pedal and shifter linkage. Probably some other odds and ends. The gearbox on the smg is the same as a 6 speed.
      Want to keep the smg so the wife can drive it.
        Teach the wife some clutch kicking!!
          All I would need is a bell housing, a third pedal and shifter linkage. Probably some other odds and ends. The gearbox on the smg is the same as a 6 speed.Want to keep the smg so the wife can drive it.
          She was in New York City for 9 years right after high school without a car. She has been practicing her skills on the 2001 Cherokee. We're taking the ultimate driving experience slowly.
            DIS/INPA links for reference:
            Modify Vagcom Cable
            Connection Problems DIS to Car
              I don't know what I'm doing but it is talking to the car!!!
                Got the INPA up and running. Does this mean I need to bleed my clutch? Help!
                • T
                  T
                  tsweers89
                  Alright if your not going to do anything with this just use AAA and tow it down to me. I will get is started for you no problem.
                    I see that you got it running. What was preventing it from starting?
                      Used the INPA software to bleed the clutch and gearbox shifter. Ran the programs and it went into R & 1. Got excited then went to start it and it fired up on the 2nd crank!!!!!
                        i bet that was a glorious sound!
                          Good job! I can imagine how frustrating that was!
                            Straight headers! My wife said the whole house was shaking.
                              I was trying to get the computer to connect to the car for 1 hour only to find out the USB plug was in the wrong port.
                                Nice job man! must feel great to have the extra experience and know-how of swapping the engine on that thing under your belt to make any future repairs and diagnostics a bit easier.
                                  Doorman
                                  Bravo brotha!!
                                    Thanks guys!!
                                    Have to put in an order at the old Concours for some small stuff. Plastic connectors, washer fluid o-ring and some nuts.
                                    I ran 5 liters of some cheap 5w-30 through it for start up. I have some bmw 10w60 oil & filter ready to go.
                                    So excited!
                                      Well shoot... after installing the driveshaft it hit the fan.
                                      I didn't know that I had to adjust the pressure plate when I installed a new clutch.
                                      Now it is grinding gears when I try to out it into R. It goes into 1 now and then.
                                      Taking it to the dealership to finish the job.
                                      Gotta pull the trans.
                                      • CMartC
                                        CMartC
                                        CMart
                                        Nooooo
                                        You came so far, finish that shit.
                                        Excursion 7.3
                                        E30 LS1
                                        • T
                                          T
                                          tsweers89
                                          Wait so you installed a new clutch and pressure plate or clutch disc? If you did a whole new clutch and pressure plate you need to run through the clutch break in procedure and clutch wear point test plan as well. If you did just a clutch disc then they clutch plate would need to be reset as with all e46s its a self adjusting clutch so you need to special tool to turb back the springs when isntalling. Eitherway unfortunately this is what happens in the enthusiast world when guys think they can work on it all themselves on vehicles/systems they know nothing about. Hate to see it but I see it often.
