my 330i
Nice! Looks good!
Ordered spacers for the front earlier this week and they have arrived today! Put them on and this is how they fit now. The rear still needs work. But I don't have the time at the moment for that.
So my car has been put away for winter already. I have the starting of my to do list.
2015-16 winter to do:
Refinish wheels
Cooling system
Disa valve
Brake booster
Timing chain tensioner/guides
Exhaust
Redo air management wiring
Rewrap head liner and a, b, and c pillars
Roof pdr
Order new compressors
Hard line setup
If time is available:
Differential
There is a few more thing as well but I can't think of them at the moment though.
Over the past summer my car was sitting outside in a hail storm and had hail damage on the roof, hood, and trunk lid. And I got these with most of the insurance money. Can't wait to put them on.
Is that a csl trunk? It's hard to tell in the picture.
I could use a hail storm right about now
Haha. It was a bit of messing around with the insurance company to get a check for me.
Yes it is!
Since my last post I got some more work done. I installed the M3 steering wheel, re-setup the management board for my air ride, rebuilt the disa valve with the German auto solutions kit, stained the wood for my trunk setup (finally), and installed a new csf aluminum radiator. I recently ordered the E60 shift lever, uuc dssr, and mishimoto aluminum expansion tank. I have a few more things to order but I should have plenty of time to drive it before I make the trip down for The Euro District.
Why an e60 shift lever?
I was originally looking at getting a z4 lever. I did a little reading about them and people were saying that is was notchy feeling going into gears and that you would have to bend the shear rod on sedans so the lever doesn't hit the dash. I didn't want to bend a new dssr to not like how it shifted. And the e60 shift lever has a shorter throw than the stock 330i lever
Well the winter has come and gone. I got what I could done on this thing but not all was completed.
For those that seen the mishimoto expansion tank I warn that there are fitment issues with it. The top radiator hose being one that I encountered. The other issue I had was an installer rookie mistake.
But here's a couple pictures of it now.
Does anyone know what size socket is used for the rear axles on an e46? It's a 12pt nut that's larger than a 32mm. Rather not play the trial and error method.
36mm
36mm
Thank you Pat!
I dropped the rear end out of the car a month and a half ago with intent of putting new bushings in, put in toe correction brackets, swapping the diff to an open 3.38, and welding in reinforcement plates. Turns out when my brother started to weld the plates in he noticed a crack on the driver side rear mount.
Got everything fixed and plates welded on now.
Seeing how I can get things powder coated matte black for free at work. I sent the trailing arms, subframe, upper control arms, and the subframe crossmember through the paint line. I ordered revshift poly subframe, trailing arm, and diff bushings. The rest of the bushings I purchased oe replacement parts.
Put the rear end back in this past Sunday night. It's pretty much all back together besides some interior bits and such.
Also I picked up some wheels from Jory. Some 17" oz fittistars. They will be rebuilt and refinished before they go on.
Rad! What are the specs on those Fitti's?
The original specs are 17x10 et65ish. They were for a corvette the hub bore is in the 60's. I had a buddy bore them out to 72.56 so now I just need to rebuild/refinish them
