  4. My life in the slow lane: Turning a z71 4x4 335I into something respectable.
335isingle turboxdriven54port injectiontwin turbovrsftialfuel-itcomp turboz71still not fast4x4does anyone eve
86 Posts 15 Posters 1.7k Views 2 Watching
  • Chris WelterC
    Chris WelterC
    Chris Welter
    It was at this point (turbo mocked in and ready to tighten) that I remembered I didnt have an oil cooler from the factory.  No big deal though, went and found a blown engine and bought the housing off it.  However here is where the controversy starts, I installed a low temp therostat.  Now the thermostat isnt the issue, its the cooler mounting people have issues with.  I mounted my mishimoto behind the grille (drivers kidney).  Some people say it blocks the radiator (it kinda does) and its an issue, however I havent seen any problems with it as of yet and as an added bonus if I throw my JB4 in MAX COOL mode I can pull the oil temp down from 230 after a good hard long couple pulls to 180 in under 5 minutes.  With that being installed I'll toss up the pic of the turbo mounted as the car was pretty much finished minus the programming part.
    2009 335XI: JB4, DCI, Tein Springs, Custom exhaust, Single Turbo, Port Injection, VRSF 7", ...
    2002 Suburban: DD and toy hauler.
    1996 Jeep Grand Cherokee: Come buy this I dont want it anymore!
      The size of that turbo tells me you are trying for 700+hp, is that an accurate assessment?
      And
      Dont
      Stop
      Posting
      • Chris WelterC
        Chris WelterC
        Chris Welter
        As it stands I've run the car up to 26psi on the turbo (blew out an 02 sensor and havent replaced it yet).  I can say even when working out the bugs this thing is an absolute terror stoplight to stoplight.  Fun fact: this turbo kit has only been installed on 3 xdrives, one in canada, some guy in arkansas, and me so thats reassuring 😛
        This year i'm ironing out the rest of the bugs, adding the new manifold and 4 bar map sensor and anti-lag kit.  Going for the xdrive 1/4 record, i mean pick your battles right? 😆
        But seriously, it will break a record, or Im gonna break it trying.  4L80E swap is supposed to arrive this year, so if the driveline breaks i'm going that route.
          Great build. Like Snap said... don't stop posting!
          Are you still auto? If so, I don't think it will last very long. And apparently the Level 10 upgrade hasn't been working too well for the high horsepower folks.
          I'd love to see what that thing puts down on the dyno.
          • Chris WelterC
            Chris WelterC
            Chris Welter
            And
            Dont
            Stop
            Posting
            That would be a valid assessment.   Didnt really think it out at the time, but it sure is a lot of fun!  😁  I mean, imagine a FBO car, plus a bunch more power and literally 0 tire slip off the line on the street.  Literally feels like a slingsot is hurling you forward.  If the car breaks i'm upping the driveline and I could see a precision 68-70 gen2 in my future with a built engine.
            • Chris WelterC
              Chris WelterC
              Chris Welter
              It is still an automatic.  I'm not overly worried since the 4L80E swap will be out soon, but i've done my research.  I have a friend over by chicago that is running the RB's and has close to 600 launches on his xdrive without a single slip.  Rumor mill has it there is something different with the programming, but only time will tell if that is true or not.  Havent seen a slip yet myself either so my fingers are crossed.  Dyno will come once I get it back running right (this spring) and get a trailer to haul it to chicago.
              • Chris WelterC
                Chris WelterC
                Chris Welter
                pic where you can see oil cooler lines.  Ignore the headlight washer cover, it was being a pain for the first couple weeks after I got it together.  Fixed now though.
                  Awesome car - it's gotta be a riot to drive!!!
                    Yes! The launch in this thing is incredible. And the sound is just wild with the screamer pipes. And the best part is that people next to you at a stoplight haven't the slightest idea.
                      +1 on the Engine support bar. Mines been hanging for a few months now
                        Curious on the 4l80e swap details. Awesome build! Keep up the posts.
                        • Chris WelterC
                          Chris WelterC
                          Chris Welter
                          The 4l80e swap is being done by a relatively small company.  Supposedly there is a Ford 8.8 rear end swap involved as well.  I've tried to get more info from them but all I got was the basics so here it goes....  The kit should use a 4l80e (you supply it) but will come with everything you need to get it running.  I guess the way the system will function is the car will be reprogrammed to think it's a RWD manual (eliminate s all talking to the other controllers) and a 4l80e standalone controller is used.  I believe the kit also adds steering wheel paddles to send shift signals to the trans.  The rear end kit comes with all the custom mounts and dss axles/ custom driveshaft to make that work.  I have been told the xdrive won't work as the tunnel is too small to hold the trans and fit a driveshaft going forward.  So that also leaves me 2 options..  cut front axles and remove the pumpkin ect, or get a $500 rwd front subframe and switch the front end over while removing the xdrive parts.  I would like to do the latter option as it involves no ghetto axles.  But if it breaks my hands are tied.  The other good part about the latter would be the ability to install M3 control arms and suspension bits.  I know my rear end will be getting the m3 arms ect..  I was told the reason for the 8.8 was because gearing options and cheap parts availability while keeping the bmw suspension as it is.  Combine all this with motiv's closed deck motor and all the tuning advancements made and I think we will see the first 1000+whp N54 this year.  As well as the first 8-9second 335i.
                          • i_love_carsI
                            i_love_carsI
                            i_love_cars
                            awesome thread, awesome car, IMO, despite the automatic transmission. I think you made the right decision here. Honestly on a car like this with a 7k redline and for what the gear ratios are, if you have a big single turbo and are going to end up making 700+ hp, having a manual transmission just becomes useless, truly. And if you don't care about rowing gears, then who cares. I think your plan of upgrading the transmission to the 4L80e is perfect.
                            My favorite part of this was reading about people who say that an xDrive 335 is garbage. I personally prefer RWD but honestly, but mainly for track and tossability. How can you argue with a car that's driven on the street, having like 500-700 whp, and having AWD to put it down to the pavement? That's still badass, lol. And it'll put every dumbass Subaru bro kid in their place, to boot.
                            When you break into 10's I'll take a ride.
                            as an aside, with all these cars in our group being up north, I may need to make some rounds this summer lol. I do some software contracting on the side for a company based in Appleton/neenah area and I'm due for a visit and some drinks with the guys I work with. While I'm up there I want to see some of these vehicles. I'm guess the closest in proximity there would be you and Jake.
                            2007 Z4MR
                            2003 E39 M5
                            2002 E46 M3
                            2021 X5 40i
                              Wait-Wait-Wait.... Where are you located Chris?!?!?  I'm in Oshkosh - I had just assumed you were in MKE area? (Don't ask me why - just had assumed as much)
                                I can sense a sleepover in the works
                                • Chris WelterC
                                  Chris WelterC
                                  Chris Welter
                                  Dubuque IA.. Well really East Dubuque IL.. but I claim platteville area for anyone I talk to in wisconsin.  I would more than be happy to stop out and meet some new friends!
                                    I started the Bimmer craze at the Hormel plant in Dubuque. Went from just me to half a dozen for a while.
                                    • Chris WelterC
                                      Chris WelterC
                                      Chris Welter
                                      Pretty much just me now...
                                      Sent from my HTC6525LVW using Tapatalk
                                        Go help Thad put his vert together, I only built the engine 3 years ago.. it's never been fired yet after a full rebuild. The suspense is killing me.
                                        • Chris WelterC
                                          Chris WelterC
                                          Chris Welter
                                          I try to buy it from him every time I see him..lol
