  4. Build Thread?
Build Thread?
    So I welded the diff in the 325e a bit ago, and got that back in the car, as well as some fresh oil.
    I was very excited to take it out in the "big" storm we were supposed to get. I filled the tank and tossed 2 sandbags into the trunk for good measure.
    I am dumbfounded by how well it handled the snow. I could roll to a dead stop in snow that was past the tire sidewall, slowly release the clutch, and start moving forward like it was no big deal. I love it.
    This is far better in the snow than the e46, and can handle much more snow than the e46 as well.
    IMG20160202155702926HDR
    IMG20160202155631649HDR
      Why does your intake face forward? Just wondering. PS I want this thing lol
        so awesome. how did you raise it? also, it would look killer with a roof rack for the shovel, spare, gas can etc. yakima makes an 'axe bracket' that would be perfect for the shovel.
          I have been thinking about welding something up for a roof rack, and then just welding it to the car. Low cost is key with this car.
          The rear is using e36 springs and shocks, no sway bar (this was critical to getting it high enough)
          The front is on vert springs, and should have strut spacers soon. Spacers will bring the front up another 1.25"
          One of the front springs is still stock, and the pictures make it obvious. Drivers side is still stock. Darn ball joints didn't want to separate with out destruction.
          I need to get a pile of parts for the front suspension, e46 control arms, longer tie rod ends, and new struts.
            yakima raingutter towers go for like $50 on craigs, iron pipe (which comes in the correct diameter) from home depot for the crossbars costs nothing, then just weld your custom rack to that.
              I've got a pair of Yakima cross bars that I'd be willing to donate to the cause if you decide to go that route.
                Finally ordered the bottom end parts for the M52.
                Should be getting the motor for the "nicer" car back together soon!
                  It is nicer. But it will never be cooler ;)
                    Ouch
                      buuurn (pun intended)
                        There is finally a motor in my car.
                        Brake fluid res. is in the way.
                        Yup
                          How? lol
                            I was using an IX master cylinder and the stock IX brake fluid res. The throttle boot for the e36 has the IAC hose running into the underside of it, right where the fluid res. is.
                            e21/2002 res. incoming.
                              That should give you a frame of reference. (older picture)
                                e34 m60 cars have a remove res setup too if parts would be cheaper?
                                  How have I never seen this issue before on an m50 swap? I always just see the booster being close to the plenum.
                                    That's an odd booster for a swap???
                                    I believe I have a Porsche one on my car
                                      IX Booster isn't quite as common, probably why you haven't seen it too frequently.
                                      Parts were pretty cheap, for the res., grommets, and fittings for the master it was about $40 shipped.
                                        Probably not as common because it clearly has some clearance issues Clarence
                                        • JeffJ
                                          JeffJ
                                          Jeff
                                          Not worried about the motor torquing into the bottle?
                                          1976 530i e12
                                          1990 325ix e30
                                          1992 325i e36
                                          1995 740il e38
                                          2001 330xi e46
                                          ^More to come :)
