  3. BMW Discussion
  4. BMW v8 engine coffee table project
m60v8projectenginecoffee tablemsextyvtech
140 Posts 20 Posters 3.0k Views 1 Watching
    Whoa, this is getting cooler and cooler
      Super awesome man! Keep it up!
      • CMartC
        CMartC
        CMart
        I've got some extra exhaust manis you may be able to cut and make them l look like shortys.
        Excursion 7.3
        E30 LS1
          the stock stamped steel ones? they are pretty ugly, some of them are even T-shaped leaving the head. have any pictures, anyways? i'm curious if m62 looks much different than m60.
          • CMartC
            CMartC
            CMart
            They look like these:
            Free if you want them.
            Excursion 7.3
            E30 LS1
              thanks for the offer, but I'm going to pass. i mostly hate that left/right are not symmetrical, but those stamping edges, wow it makes them look so cheap. what are those called, "hemming" or something like that?
              • CMartC
                CMartC
                CMart
                No worries.
                They are getting scrapped so I figured I would offer.
                I was thinking you may be able to use the flanges and weld a similar pipe onto them.
                I believe they are dual walled for heat transfer or something?
                Excursion 7.3
                E30 LS1
                  ah i see. unfortunately I cannot weld or machine anything, so i'm limited on customizing stuff like that. yeah they are definitely dual-walled, thats why they stamped them instead of just welding or casting.
                    got the main bearing caps painted and the related hardware cleaned/polished.
                    also, my 1.75" 6061 aluminum tube came in for the 'headers'
                      more work done on headers:
                      finished the flanges
                      wood filler used to get the grain/imperfections hidden before painting. before on top, after on bottom.
                      to cut the tubes, I don't have a miter saw, or a table saw, or a band saw, so i made a little jig for my circular. fyi, diablo circular saw blades are the shit. i've been cutting soft woods, hard woods, and aluminum on the same blade for YEARS and its still sharp.
                      rough cut done
                      tubes filed, fitting and glued into the flanges. all that's left is to make some 'simulated' welds and then paint.
                      also started on the injectors. they were a bit crusty, and i want to use them to bring a little color to the whole motor, so they will be painted BMW blue.
                        In for "simulated welds" im envisioning some sort of putty molded into the gap
                          yup, been experimenting with what material will work best. and studying 'weld porn'. silicon sealant is too sticky for shaping. wood filler/wall putty is too gritty. going to modeling clay next.
                          don't think I'll get quite this perfection, but its what I'm shooting for, if possible:
                            Im imagining JB weld putty + a shaping tool like a 3/8" round rod to knead it into the gap in steps which would simulate a fillet weld..... In my head at least
                                i searched for a long time to see if someone had done this full scale and couldn't find anything. where did you find that?
                                and thanks for sharing, that is a great place to start. the only thing different will be working in a corner, versus a flat surface.
                                  Doorman
                                  Painters caulk (the cheaper the better) is not runny like silicon. If you cut the tip right you can stop/start your bead and it would look damn close to a weld.
                                  • CMartC
                                    CMartC
                                    CMart
                                    Something flexible with that half moon pattern you could press on would be perfect. Almost like a large zip tie that has a rigid back.
                                    Excursion 7.3
                                    E30 LS1
                                      not a bad idea if I could find such a thing. makes me think of trying to cut the clay into half-moon or disc pieces (like using cookie cutter) and pressing them in place instead of making a bead then shaping it with a tool.
                                        You can easily make a tool to do the pattern as well. Cut the half moon shape into any flexible plastic thing. A spatula, bondo spreader, etc.
                                          so, i tried a few techniques and the best turned out to be rolling the clay into same-sized balls (ha) and then pressing them individually into place. it was the only way that really worked with the fact that it was a T weld on a curved surface. i also tried to leave the edges over-exaggerated in case shrinking or paint layers hides it later on.
                                          air dry clay
                                          pressing the pieces into place one at a time
                                          some finished tubes
