  4. Calypsorot '90 325i Coupe
85 Posts 19 Posters 0 Views 1 Watching
    Winter is here and is so motivation to get this going! Have been slowly working on getting the motor out which I planned on today. Decided to drop the trans and motor down under the car to avoid dealing with the starter. Everything is unbolted and ready to drop except we're hung up on the steering knuckle. Kaiser will send pics of what he had to do to get his subframe out. So yeah until next weekend...
      I'll have to remember to take that photo. But in the mean time this should be your new sig93c162fea356749612460be4156dd726.jpg
        Pics or it didn't happen. Here's the linkage Chris.
        You should be able to figure out how I took them apart ;)
          It probably doesn't help too much because I don't have a rubber steering dampener thing. Just aluminum sleeves
            unfortunetly this was true. The rubber flex disc had crimped studs going through it. Ended up undoing the slip joint under the kneel panel and pulled it out.
            So we dropped the subframe, pulled that, then dropped the motor on the floor. Raised the car up as high as the 3ton jack went and slid the motor out from underneath with just enough clearance.
            Discconnected the trans and removed the clutch and flywheel. I've never mounted a engine on a stand before but the stock bell housing bolts weren't long enough to fit through the mounts unless I have it set up wrong. Suggestions?
            image.thumb.jpeg.c6845214bdd69dc07b249d5
              I went and bought some bolts from Ace that matched the thread pitch of the trans bolts and used those. Make sure they are rated accordingly ;)
              Edit. I was able to use 2 of my existing bolts (maybe because 24v)
                That's the plan tomorrow. Working split shifts all week so I'll be at the shop most likely tearing things apart.
                  I went and bought some bolts from Ace that matched the thread pitch of the trans bolts and used those. Make sure they are rated accordingly [emoji6]
                  This is what I did as well. Nice work Chris!
                    Bought some M8/M10/M12 bolts from the hardware store and got this mounted up. I guess too long on the length but just ran the through and it all worked out. Matt and I then started picking parts off.
                    image.thumb.jpeg.4d5ddb852cb96a70898e647
                    Removed the head to find the intake valve had broke in cyl 3 as guessed.
                    image.thumb.jpeg.48f11e4a99161b189d6a6ac
                    Still in there! Basically a hole through the center of the piston.
                    image.thumb.jpeg.699049b2e0083734331672b
                    Plan from here on out is to start parts shopping/planning a budget to see how extensive the build could be. Gonna strip all the accessories/parts off the junk motor to get things cleaned up and powder coated while we wait on the new motor.
                      Wow!  That's pretty awesome!
                        #11valveproblems
                        Wouldnt have happened on an M50, you should swap it.
                          how quickly a motor can become a paperweight
                            Update time!
                            So I'm taking a job for the summer where I'll be out of state and so we decided instead of rebuilding the car as planed that we would just put the new motor in and get the car driving instead of sitting in the shop till next winter.
                            Picked up the motor Monday afternoon and we installed it last night. Bought the motor and trans from Jdesign's vert with ~140k. It's really clean but of course leaks a little oil like any m20.
                            It was an all night affair getting the motor in as I wasn't organized as we changed directions of the build plan 180*, mostly just had to find/remember what hardware went where. Ended up doing the reverse of how we removed the old motor: slid motor/trans under, lifted, then installed front sub frame.
                            image.thumb.jpeg.3b55e71bd9b4de604070e02
                            A big thanks to Jason for getting the motor to us earlier than planned and being a huge help on installing the motor too.
                            The car cranks but no fuel at the moment, fuel pump isn't priming so next step is to diagnose that. Matt ordered a csb and garagistic 80a rear subframe bushings as the only other maintenance items needed.
                              So it will be at the e30 picnic?
                                That's the goal! I probably won't be there though.
                                    WHAT ABOUT CARS AND COFFEE!?!?!?!?
                                      It's looks just like the M20 that I pulled out of my 325 when I got it! I know that update was awhile ago, but guess who didn't see it until now.
                                        I've been going every week Patrick! Sadly I'll miss all the lake mills though.
                                          image.thumb.jpeg.205168690f4aff7d23a2b83
                                          Pat and Jameson stopped by while Matt and I worked on the car this afternoon, I'm somewhere in that pic. Got the old harness out and swapped on a different one but still no priming even of the fuel pump. So now the fun begins, hopefully I can kill two birds with one stone when I figured this out to help with the e28's basically the same issues.
                                          bentley procedure isn't helpful so I'm gonna run through this tomorrow. http://www.e30zone.net/e30zonewiki/index.php/Engines_Troubleshoot
