  4. V8 Swapped E30
V8 Swapped E30
107 Posts 18 Posters 2.3k Views 2 Watching
  • johnprusinskiJ
    johnprusinskiJ
    johnprusinski
    Yes, I'm deleting all of the heater vents. I'll be putting gauges in the middle vents and on the driver's side vent. The passenger side vent is just getting blocked off.
    • CMartC
      CMartC
      CMart
      That makes things easier. I was hoping you found a way to relocate the atmosphere controls. I would love to use that space for something better.
      Excursion 7.3
      E30 LS1
      • johnprusinskiJ
        johnprusinskiJ
        johnprusinski
        I took everything out including the heatercore so no heat. I think it would be hard to move the climate controls.
        • johnprusinskiJ
          johnprusinskiJ
          johnprusinski
          I'm still making progress on the dash plates.
            Flame suit: [ON] OFF
            (R3v)
            • johnprusinskiJ
              johnprusinskiJ
              johnprusinski
              They tore me apart. I don't understand why? The pedals are designed to attach to the masters right above your feet. It's not illegal to have them in the cab either.
                They just figure you would want them out of sight and your current location would be better suited for switches of gages. For me it would seem better to try and mount them under the dash right above the pedals to have the shortest lines going down to the pedal. You dont need much room above them because you can fill them with fluid using a bottle pump=)
                • CMartC
                  CMartC
                  CMart
                  Yeah r3v was not happy about this.
                  In my worthless opinion it falls in the 'rice' category. If you hid them under the dash or put them through to the engine bay nobody would have said anything.
                  You custom mounted them to your dash like a aluminum spoiler on a civic.
                  But this is why everyone builds cars and not two turn out the same. My car pissed a lot of people off too.
                  Excursion 7.3
                  E30 LS1
                    I assume people on r3v were expecting something like this more....
                      If it was in an S52 swapped car r3v would probably drool
                        *Gauge's
                          I always say gauges but for some reason everything that has to deal with them at work is gages. I calibrated all pressure and vacuum gauges in the plant and I hate how it is always spelled gages.
                            Go, no-go earl
                              lol
                                yeah it just seems like other, more important, things should go there. like craig said, it seems like you are trying to show them off, even though we know you arent.
                                second, brake fluid can get super hot/boiling under hard use. isn't it also flammable? I wouldn't want that by my face.
                                  I wouldn't do it that way but I like the way it looks.  You do you man!
                                  • johnprusinskiJ
                                    johnprusinskiJ
                                    johnprusinski
                                    I was going to put gauges there, but I already decided that I'm going to use a digital display for my cluster so I won't need most of my gauges. I mainly put my resivoirs there, because they don't fit right on the masters and to keep an eye on it if it gets too hot and the fact that I won't have to go under the dash to fill the resivoirs. I don't want to cut the dash like in the pictures because I don't want to completely destroy my dash and I'm unsure about how much space I have in the bay yet. I might make a change in the future, but all I can do is see.
                                      • andyhundleyA
                                        andyhundleyA
                                        andyhundley
                                        I have an extra cracked dash in my garage to experiment with if you want it.
                                          Bottle pump solves all isses=)
