  4. E39 wheel question
E39 wheel question
37 Posts 9 Posters 576 Views 1 Watching
    suspenceful said:
    but the previous owner could've got them bored out... not sure why though.
    exactly!  why the hell would they even bother with wheels that fit the e39 like crap. terrible high offset, 17x7 size, etc. However, the fact that they even bothered would also lead me to conclude that they are dumb enough to try and grind the bore out themselves...
      It almost looks like there is a seam in the hub section of the rotor (red arrow). Also, I thought the hub section looked super thick, which would potentially address the high offset issue. The two red lines you see are the exact same length. Obviously the perspective isn't perfect, but it is close. There is no reason the hub should be as thick as the rotor surface is.
      Just take the wheels off and see if there are any markings or stampings on the back. Take a picture of the mounting surface on both the hub and wheel when you have it off.
      ...now I'm curious, lol.
        The hub offset is very high, as noted by this picture. That is the front rotor, and I believe the pictures posted were of his rear. pun intended?
        The detective work here is real...
          funny how all this time we take trying to help wouldnt be necessary if the OP would take 5 min and dismount a wheel to look...
            We are all at work, what else would we have to do 😉
            • Delias95D
              Delias95D
              Delias95
              Okay I was lucky enough to have zach help me out on some wheels. There where no rings or spacers.   Also found that one wheel was an 18in idk what style. So was previous owner was not smart!!!! Idk how they fit but they did lol.  Now I'm this cold I opened up driver side door and it wouldn't close finally closed now it won't open fml I'm too big to crawl in and out this car lol... Any tips on this one...?
              • Delias95D
                Delias95D
                Delias95
                Wheels swapped now no rings or spacers idk how thy for but they did.  My post above this shows where I am a now with thiscar
                • Delias95D
                  Delias95D
                  Delias95
                  I did dismount and mounted te proper wheels. No spacers no rings.
                    So what wheels are on it now? E39 wheels with the proper hub bore?
                      The latch is either freezing or the handle assembly is taking a crap on you.  You can buy a new assembly from the dealer that is keyed for your car but it's not cheap.  I believe when I had it done on my e36 325is maybe 5 years ago I bough it from Concours because they were the cheapest.  I want to say it was around $200.
                        so did you look at the wheels? are they OEM bmw or aftermarket? (what markings are on the back?) Any signs of machine work to the wheels? Any grinding on the hubs? Take a picuture? we want to know!
                          i have had multiple times when my e30 doors would not stay shut went it was crazy cold. I rode holding the door with my hand (and once anchored it with a bungee) until it warmed up enough inside the car and then the door would shut. the latch was fine in function otherwise so I chalked it up to moisture freezing things up so blasted the internals with a silicone lube i believe.
                          in general, all old BMWs i have experience with (e30s, e34, e36s) have had issues with freezing locks/latches. bad luck maybe. i dont know maybe other people have the same issues with other brands too?
                            ^^^I would lean toward this.  This was a pretty common occurrence on my 95 e36 but I don't remember it being an issue in my 97.  The 95 was also in a lot rougher shape than my 97 was.
                              In general, all old BMWs i have experience with (e30s, e34, e36s) have had issues with freezing locks/latches. bad luck maybe. i dont know maybe other people have the same issues with other brands too?
                              My previous e34, now Earls e34, had heated lock cylinders. It was pretty slick.
                                So did both of my e36's, it meant nothing to the door jam lol.
                                • Delias95D
                                  Delias95D
                                  Delias95
                                  Correct
                                    That it does. You pull the door handle and hold it up for a few seconds. It then thaws the cylinder out=P
                                    • Delias95D
                                      Delias95D
                                      Delias95
                                      I will take pics and info after work it didn't look dremeled but idk?? You guys tell me when I snap a few pics !!
                                      • Delias95D
                                        Delias95D
                                        Delias95
                                         It's The latch is either freezing or the handle assembly is taking a crap on you.  You can buy a new assembly from the dealer that is keyed for your car but it's not cheap.  I believe when I had it done on my e36 325is maybe 5 years ago I bough it from Concours because they were the cheapest.  I want to say it was around $200.
                                        I hope it's frozen or else the e39 is sitting over winter! I don't want to pull the door panel off while the car is stuck shut!! And in te cold lol
                                          i tried this on my e34 (which should have the feature) and it didnt do shit.  hold handle for a few seconds, let go and it should start warming up? how long till it should be done? i can't even get the key into the lock its so froze up after the rain/sleet/deep freeze cycle the other day.
