  4. E39 wheel question
E39 wheel question
37 Posts 9 Posters 576 Views 1 Watching
  • Delias95D
    Delias95D
    Delias95
    Okay I have a e39 (97 528i)  I just bought it a few days ago and to my surprise I realized I am running 3 17 (style 256) and 1 18in BMW wheel not sure the style. Any how I read that e39 have a 75.1 centric bore and most other series have a 72 or around that. I believe the style 256 are series 1 wheels which would have  a smaller centric bore correct?  Also I believe the one 18in wheel is also a 3 series which would be a smaller bore as well. So my question is how are these on my car? I snapped a few pictures to show that they seem to be fitting well any explanation would be great I don't want to damage anything . I can't upload pics but if you can help me I can txt or email them..
      You would have to an adapter ring or they're not oe wheels.  You are right, the 1 series wheels are 72.5.
      • Delias95D
        Delias95D
        Delias95
        So either there not oe or have to have an adaptor ? I posted some pics to see if you or anyone else can let me know if it looks like I have adaptors and that these are fitting properly! Thanks for the fast response!
          In order to figure out proper wheel fitment, you need to make sure the offset is correct.  If the offset is negative enough, you may be able to use a hubcentric spacer adapter.  A couple companies make them.
            E39 wheels have a 74.1 hub bore while all other BMWs have 72.5, making wheel options very limited. Those wheels look like they're off an E90 and won't work.
            • Delias95D
              Delias95D
              Delias95
              This is where I am confused I bought the car with these wheels on it . I understand the hub centric sizes ect. But this car somehow has these wheels and I posted pics above of the figment
              • Delias95D
                Delias95D
                Delias95
                I don't want to run them. They are on the car and I'm tryin to figure how these are being ran on it
                  Those aren't 1 series wheels, Style 264s are 18" wheels. The pictures you took are of Style 137s from an E46 (17x7" ET47 with a 72.6mm hub bore). I have no idea how they're being ran, unless there is an adapter in there. Take the wheels off and find out. Otherwise the hubs could've been swapped, although the I'm not sure why that would be the case.
                  Find out if there is an adapter in there and then get all matching wheels/tires. Different sizes in the rear are bad for your diff. Front isn't as bad but I wouldn't recommend it.
                    In the first picture there seems to be about a 25mm spacer. The next picture looks to be taken at such an angle where that is hidden behind the wheel. If there is a spacer, this definitely would all make sense.
                      Those are not style 137s.....i just looked through all BMWs wheels, and this style is not any of them.
                      EDIT: suspenseful found them, style 256s.
                      2nd: i see no spacer. when looking into the hub like that with the bmw cap removed, you'd see the wheel, then the spacer, then the hub. not the case here. it looks like the wheel's centerbore is fitting nicely around the hub.
                        Or someone who got creative with a grinder/dremel to the wheels hub bore.
                        They most certainly are not a style 137, the profiles on the spoke makes that very apparent.
                        They are not a 264 either.
                        The great wheel mystery!
                          First off, I misread your first post. I thought you said they were Style 264s, but you clearly said Style 256s.
                          You are definitely correct, they are Style 256s from a 1-series, which have a 72.6mm hub bore.
                          http://www.bmwstylewheels.com/bmw/256
                          Someone got creative mounting your wheels, or they are an aftermarket replica. It's easy enough to take a wheel off and find out what's behind it or going on in the hub bore of the wheel. I doubt it, but the previous owner could've got them bored out... not sure why though.
                          Got pictures of the 18" wheel? That might give another clue to the hub bore situation.
                            exactly!  why the hell would they even bother with wheels that fit the e39 like crap. terrible high offset, 17x7 size, etc. However, the fact that they even bothered would also lead me to conclude that they are dumb enough to try and grind the bore out themselves...
                              It almost looks like there is a seam in the hub section of the rotor (red arrow). Also, I thought the hub section looked super thick, which would potentially address the high offset issue. The two red lines you see are the exact same length. Obviously the perspective isn't perfect, but it is close. There is no reason the hub should be as thick as the rotor surface is.
                              Just take the wheels off and see if there are any markings or stampings on the back. Take a picture of the mounting surface on both the hub and wheel when you have it off.
                              ...now I'm curious, lol.
                                The hub offset is very high, as noted by this picture. That is the front rotor, and I believe the pictures posted were of his rear. pun intended?
                                The detective work here is real...
                                  funny how all this time we take trying to help wouldnt be necessary if the OP would take 5 min and dismount a wheel to look...
                                    We are all at work, what else would we have to do 😉
                                    • Delias95D
                                      Delias95D
                                      Delias95
                                      Okay I was lucky enough to have zach help me out on some wheels. There where no rings or spacers.   Also found that one wheel was an 18in idk what style. So was previous owner was not smart!!!! Idk how they fit but they did lol.  Now I'm this cold I opened up driver side door and it wouldn't close finally closed now it won't open fml I'm too big to crawl in and out this car lol... Any tips on this one...?
                                      • Delias95D
                                        Delias95D
                                        Delias95
                                        Wheels swapped now no rings or spacers idk how thy for but they did.  My post above this shows where I am a now with thiscar
                                        • Delias95D
                                          Delias95D
                                          Delias95
                                          I did dismount and mounted te proper wheels. No spacers no rings.
