  3. Services Offered/Wanted
  4. Suggestions for fixing rear subframe
15 Posts 7 Posters 176 Views 2 Watching
    Is this car your daily or do you already have the subframe removed and ready to be reinforced?
      I think he is talking about the chassis sheet metal being torn out.
      Any pictures?
      • S
        S
        shaneomac1602
        Yes I'm talking about the sheet metal on the chassis itself. It'll need the reinforcement plate kit welded in from the trunk side to repair.
        • CMartC
          CMartC
          CMart
          Do you already have the reinforcement kit or does that need to be fabricated?
          I have a welder and could help if you were close to Milwaukee.
          Excursion 7.3
          E30 LS1
            I have a set of OEM reinforcement plates if you are interested.
            • S
              S
              shaneomac1602
              I just have to pick up a set of plates. I'm in Racine, so not too far.
              • CMartC
                CMartC
                CMart
                Car drivable?
                If you do the prep work I'll do what I can to help you out.
                Excursion 7.3
                E30 LS1
                • T
                  T
                  tsweers89
                  $1050 is an awesome price if they are doing the labor of removing the subframe and such. Lowest I've seen from a good bodyshop is $2k
                  • S
                    S
                    shaneomac1602
                    Yeah I still daily drive the car now. I just take it easy. $1,050 was from a shop in Greenfield just south of Southridge Mall. I can't remember the name of the shop right now. They said they could do a 2 day turn around on it. I'm just trying to keep cost down with my daughter due in about 3-4 weeks. I most likely won't consider this project until spring, but just trying to gather info now
                      If it is tore now it'll start snowballing fairly quickly from what I've seen
                      • S
                        S
                        shaneomac1602
                        I will just be driving it until I get my Subaru forester back from the shop. Then it'll get parked while I work on it.
                        • T
                          T
                          tsweers89
                          To me being a e36 it's not worth it to even fix honestly. I'd put full coverage on it wait till spring, claim on insurance which they will for surely total it and take what you can get. Otherwise scrape it. If it was a low mileage m3 then that would be another story.
                          • S
                            S
                            shaneomac1602
                            Insurance won't pay you just because your car is broken. I think I'd lose more money by selling for cheap or junkie it than it would to fix it. It's a very clean and rust free black on black manual.
                            • vng704V
                              vng704V
                              vng704
                              I know I'm late to the thead but if you haven't got it done yet, contact Jake Rawson from Rawsomotion. He might be able to give you a better deal considering I had my subframe mounts reinforced, some bushings, and some other things done for under a grand.
