Tech me on m20 performance mods
Yep sorry about that I should get my letters straight---meant to say new or refurbished AFM (from Gregs///M ) not a MAF conversion.
Also for the true cheap m20 fix make sure your throttle cable is adjusted correctly so that foot to the floor is actually WOT. Retaining nut can come loose on the cable. Guy in our group ran a race weekend wondering why his power was down. Turned out the cable had loosened. Picked up 10 hp on the dyno when discovered. Go figure.
Steering linkage in the way for any bottom mount turbo manifold. You can squeek 175rwhp out of a m20 n/a with a ton of bolt ons and megasquirt.
Well that's a bummer. Was going to give you a call as I think for the money a sarge 1 kit would have been the way to go
I vote turbo! with that budget you could have an incredibly reliable setup, and even 300whp would be pretty insane in a 2002, and 300whp can be VERY reliable on an m20 on pump gas. very simple and at that power level nearly instant spool with the right parts.
Problem being there is no bolt on kits for the 2002 which would make things more difficult and since it's only 2 of us at the shop we don't have enough man power to do a full on custom build and still keep up with the other customer work since we only work weekends
A properly designed ITB setup will net some real, tangible horsepower gains. Packaging could be an issue though, as the runners tend to be pretty long when they're done correctly. The looks and the sound thoungh.... :eyesrollingbackintheheadfrothingatthemouthsmiley
If the customer is a goofball and doesnt mind coming in periodicly for a re-tune and linkage adjustment then ITBs could be lucrative, otherwise it could be a hassle to the customer to not have it running consistently due to the finnicky nature of Alpha-N tuning.
The money spent on ITBs could certainly go towards the higher CR pistons and larger cam that will be needed.
The Metric Mechanic pistons have valve reliefs that make the M20 a non-interference engine, even while increasing the compression ratio which would be a huge selling point if I were a customer.
Very true on the ITB's. I'm still weighing my options. He saw a s50 2002 online and wanted to do that but after looking it seems like there is so much fabrication involved when doing that which I can not offer. Boy I wish this was a e30 at least. I don't think it's worth sticking $6k into it for a 2.9L stoker and ported head for at most 190whp.
24v swaps are boring. Get creative!
Oh wait, this is reality, not my personal fantasy land. Sorry.
Would get some good reactions when you popped the hood, and the transaxle would keep the weight distribution where you want it.
Someday, when I have a nice shop and a crap-load of money and free time...
