  3. BMW Discussion
  4. BMW v8 engine coffee table project
m60v8projectenginecoffee tablemsextyvtech
140 Posts 20 Posters 3.0k Views 1 Watching
    Doorman
    Sweet!!
      CMart said:
      I made one in college - here are my takeaways:
      Good idea using aluminum, I did not.
      Yours is going to turn out much nicer than mine as it looks like you already have more work in it.
      Start looking for glass now. Random piece, old table, etc on craigslist. MUCH cheaper than having a custom piece made.
      Keep up the good work.
      thanks for the tips.
      sure as shit i was driving home from work today and there was some junk on the side of the road and there was a metal frame of sorts that i grabbed if I end up with a frame under the glass too. will definitely keep an eye out for some glass.
      and yeah i figure the overall weight of the engine part of the table should be just around of 100lbs, which is manageable. i cant imagine what a cast iron lump with crank/pistons weighs.
      also, are those shotgun shells?
      • CMartC
        CMartC
        CMart
        Yep shotgun shells. When you rotated the crank/cam it actually raised up and down the shells in the holes.
        Excursion 7.3
        E30 LS1
          This is amazing! Nice work to the both of you. I made a couple end tables out of a brake rotor for base and crankshaft as stem before, but unfortunately don't have pics. Can't wait to see the end result on this one tho.
          • StriggityStrackS
            StriggityStrackS
            StriggityStrack
            Yours looks amazing! I had this piece when I lived in Milwaukee. I turned it into a wine holder when I moved in with my girl and surprisingly she loves it. It is definitely a conversation starter.
            post-3673-0-63113400-1443744501thumb.jp
            • StriggityStrackS
              StriggityStrackS
              StriggityStrack
              I cant wait to see the finished product.
                I love the unfinished style, it goes with the look of your room.  its good the girl liked it! (i am getting opposition)
                  the other head is finished!
                  started on the cams.  they are pretty dull and the lobes started rusting when the parts car sat around awhile.  took about 1hr/cam to get every lobe polished up.
                  before
                  one lobe 100% finished. coke/metal polish + 000 steel wool + elbow grease
                  taped up ready for paint. will be gloss black.
                    intake and exhaust cams for 1-4 done
                      more parts painted
                      i'm getting way ahead of myself, but this project may involve a custom set of headers. laser cut/cnc/wood/pvc/copper pipe who knows?!
                        well the original plan was to create a block out of wood and metal brackets since I didnt keep my block from the parts car. miraculously, i found a b40 block with broken bellhousing mount on ebay that was a local seller.  after negotiating, i was able to do a trade+cash for my old auto transmission.
                        he was even available the same day so i went and snagged it last night
                        bonuses: its already been stripped and is super clean. also, it has a bunch of the covers/parts: valley pan, rear coolant cover, front idler sprocket, rear main seal.
                        i'm fairly sure, but hopefully the b30 heads and the b40 block have aligning holes for the head bolts.
                          some college football (go wisconsin!) and v8 table saturday...thats the good stuff.
                          cam sprockets polished up, ready to be sent off to get plated.
                          Timing chain tensioners and oil separator tube cleaned and polished
                          So here you can see the giant chuck of the block 'ears' missing. someone definitely dropped the block on that corner when it was delivered to the guy i bought it from. here i've also started drilling holes for reshaping the area.
                          Basic shape cut out
                          Surface contoured to match the original machining and sanded smooth.
                          I actually really like the shape it created, it emphasizes the 'V' more on the back of the engine. I might just hack off the starter side to match.
                          also got the other bank of cams done. here they are installed with new hardware
                            throttle body done!
                            i actually have a before photo, since when I took it apart i figured i'd never get it back together right without a reference.
                            before:
                            i fully disassembled, cleaned, and painted the housing. also got some new hardware, and a little polishing of the throttle plate.
                              Nice!
                                been busy so not much to update. however, the pile of stuff I sent off to be professional plated came back.
                                i had the cam sprockets, timing chain idler sprocket, and the head bolt spacers (which I will be using for the head bolts and intake manifold bolts) all yellow zinc plated. i love all the variations of color you get with zinc plating. yellows, reds, green, blues.
                                idler sprocket (reassembled on the idler.)
                                cam sprockets
                                head bolt spacers
                                  Wow! Where did you get that done?
                                    a place that was recommended to me when I refinished a set of style 5s and need the hardware zinc plated: Del's Plating Works in Houston, TX.  They do really good work, and take small jobs, although the minimum order is like $55 + shipping, so it was like $70 to have this stuff done.
                                      Starting to look like earls build thread
                                        Just read through Earl's build.  compliment accepted! I always want to fix my cars with that level of detail and cleanliness, but then i remember I'll drive it in the snow one time and all that effort will be for nothing.
                                          more stuff is in, time to start building again
                                          the glass top pieces:
                                          another pile of hardware.
                                          from left to right: intake manifold nuts, copper exhaust manifold nuts, exhaust manifold studs, valley pan bolts.
                                          did some 'machining'
