Free coding in Madison area
**I'm based in Madison, WI and I'm willing to travel to Milwaukee and Chicago area if there is a group interest.
I may not be checking this board or PM very often so please contact me at -> [email protected]**
Visit my site for coding samples. http://www.bmwminicoding.com
**The following options can be coded for E and F Series
Doors & Mirrors**
• Close Windows & Roof / Convertible top with the Key FOB.
• Eject Key FOB and Unlock doors when the ignition is turned off
• Disable Auto Dimming mirrors
• Close Side View Mirrors with the key FOBiDrive
• Disable iDrive [Accept] Warnings
• Disable Rear camera warning – Never solely rely on camera
• Video in Motion for CIC
• Weather Band Radio for CIC
• Fuel Stop Suggestion in Route Guidance for CIC
• Lock/unlock beep options in iDrive for CCC
• Day time Running Light option in iDrive for CCC
• Traffic Information for CCC
• 2012 Navigation Maps Update for CCCWiper Operation
• Wiper completes the cycle when ignition is turned off
• Disable Headlamp WasherRain Sensor
• Close Sunroof when the rain is detected (Rain Sensor should be turned on)Instrument Cluster
• Digital Speed in cluster (True car or Speedometer)
• Disable Door Chime when the key FOB is in the slot.
• Enable Efficient Dynamics Gear Shift Indicator (6 Speed Manual Transmission) 2007.3+
• Instrument Cluster Lighting always On (Day & Night)
• Red Clown Nose Blinking when locked (no alarm installed – only E46& E83)
• Instant MPG (Only for ///M)
• Fuel Tank Warning at 1/8 tank rather than 1/4 tank
• Frost Warning (Chimes when below 37'F - only E46)Lights
• Double Blink Hazard lights
• Side Marker/ Turn Signal Lights / Corner LED off with head lights
• Disable windows safety feature (One touch window rolls up when door is open)
• BFD (Brake Force Distribution) Lights on with regular breaking – Very bright break lights
• Increase Brightness for Angle eyes
• Fog Lights stays on with high beam or high beam flash
• Fog lights always on with headlights (low beam, Auto)
• Fog lights on with AE DRL
• Fog Lights for Corner Lights (Fog lights will turn on for low speed turning)
• Welcome Lights on (Turn on fog, Angel Eye, low beam, rear license plate lights when unlocking the car)
• Follow Me Home Lights (Turn on low beam and break lights when trunk release button pressed once - FRM3)
• Angel Eye on full power when low/high beam turned on (No Angel Eye dimming) – Not for LED halos.
• Angel Eye as DRL instead of head lights
• Rear Tail Lights ON with DRL
• Delete Bulb Errors (Disable Cold/Warm Test after Retrofit)
• Adjust the Auto Light Sensitivity (Head lights will not turn on when it is sunny)Trunk
• Close the trunk (tailgate) with the key FOB and button inside the cabinSeat Belts
• Remove Seat Belt Chime for Driver and PassengerOthers
• Retrofit CodingF Series vehicles are supported
*Possibility to code specific option may vary depend on the model. I'm not liable for any and all possible damage and worry not though! In 50+ that I've coded I have not had a single coding-related error.
This is awesome. Even though I dont have a later model bimmer, I think this stuff is cool as hell. Bump!
Wish some of this was available for my E28 =[ I would definitely get the windows up/sunroof close when locking the door. Among a few others.
Can you make my car stop dinging really fast when my left turn blinker is on? No bulbs are out or anything, it just blinks/dings really fast.. It's annoying! Rawr. :3
Just bumping this thread to see if anyone is interested.
Please contact me at [email protected] for complete list of options.
Yeah.. Some of them are really awesome... Windows up with the key FOB is the most wanted option.
Did that to myself to my 2006 E90.....love it. You can put them down also with the FOB.
Wish some of this was available for my E28 =[ I would definitely get the windows up/sunroof close when locking the door. Among a few others.Can you make my car stop dinging really fast when my left turn blinker is on? No bulbs are out or anything, it just blinks/dings really fast.. It's annoying! Rawr. :3
Could be the bulb or connection. Give them a wiggle with the hazard switch on. Check the bulb on both front and rear of that side.
Can you program the vin on a e46 ABS module?
got that fixed alonggg time ago. lmao
Please contact me to update your CIC navigation with 2013 maps. I will provide the FSC activation code with maps.
