  4. e34 Touring
e34 Touring
269 Posts 26 Posters 4.5k Views 1 Watching
    nicely done! Glad it all went in without too many hickups. I am looking to join the touring club too once my lease it up on the jetta.
      I like the wooden stands you made too.
      Dave,  pancake-engined-potato-carriages dont count in this context.
        Got the wiring done, everything worked exactly like the information I found online from other people doing the e34 5 speed swap, which was an added bonus.  the 12 pin harness plug that they all spoke about was missing in my shifter area, but after pulling the entire shift console, I found it buried underneath (pain in the ass, but worth it)
        all the console stuff pulled (i miss my e30, in which this would have have taken 2 minutes)
        to trick the check control that the trans computer is there, you just have to ground out the gray pin in front (#10) on this 12 pin harness plug. you can pull pin #5 from the blue range switch plug that is no longer used from the auto trans shifter.
        to get the reverse lights to work, here is the adapter that I made. i have the entire body harness from my parts car, so i can pull all kinds of nice factory plugs and already crimped pins.
        my custom factory pin puller (take an metal extending antenna apart from an old radio, e30, etc)
        i also switched out my HVAC panel with a fully working one while i was at it, and moved my ASC switch up by the fog light switch.
        and the shift console all back together! used the weight zhp knob (feels great) and thats the m5 shift surround, which has great dividers so your crap doesn't slide around like the standard one.
        the open blank is for a usb charging port from george graves on r3v: http://www.r3vlimited.com/board/showthread.php?t=357376 just waiting for it to arrive.
          Zhp knobs are the bees knees
            yes they are.
            well i've put on about 400 miles since the install and have a bit of sad news - between sticky tires, stock suspension, and heavy chassis, I can't just spin the tires from a stop. the b30 has plenty of oomph, acceleration feels at least as fast as my m20 car, which could light them up no problem. until I change some things, no 11s for me. she still is fun as hell though!
            mitch, i still plan on keeping my promise though!
              Even more reason to get a B40 in there! That M5 shift console looks great.
                for sure! someday... and thanks!
                • CMartC
                  CMartC
                  CMart
                  Awesome job and car.
                  What does that clip/wire do that is on the inside of the trans?
                  Excursion 7.3
                  E30 LS1
                    new pivot pin, clip and throw out bearing.
                    are you referring to the above picture? the clip holds the release fork lever against the pin on that side. the lever hinges from that point as the clutch slave piston pushes the other side of the lever toward the engine.  most of the force on that end of the fork is forcing the lever against the pin behind it, so its just a measly clip to hold it steady.
                    • CMartC
                      CMartC
                      CMart
                      Yeah, I don't remember seeing one on my trans when I pulled it last.
                      I don't want to pull it all apart again, but I am sure its there for a reason...
                      Excursion 7.3
                      E30 LS1
                        Yeah you may have an issue. At a minimum you may get a lot if rattling. Not sure if the lever can find its way out of alignment but that could leave you with a blown slave cylinder and shifting issues.
                        • CMartC
                          CMartC
                          CMart
                          The bad news - I spent all night taking the motor out and taking the trans off.
                          The good news - the clip is there - and I can sleep well knowing that.
                          Excursion 7.3
                          E30 LS1
                            that sucks. at least you have more practice!
                            that's one reason I take pictures as I go. lets me look back at things I might have missed. i missed some clips on the new pedal bracket and my picture was able to show me what they are (since I already threw away the old one << )
                              Nice seeing you and this great looking car at the Mobil the other day. Looks and sounds fantastic, even without a muffler :cool:
                                thanks! great running into you, too. if you ever need a hand with project stuff I am literally down the street.
                                  Saw your car at the Brew City show, exhaust (or lack of one) sounds awesome!
                                    thanks. I saw a couple of cars with wibimmer stickers, but no one standing around them. no white e30 coupe, what were you driving?
                                      Sorry I didnt get the chance to say hi! I was in my white e36 m3, I hit a deer pretty hard in the e30 this past Friday :(
                                        ah shit that sucks!  was it the white m3 with the modena interior? i want that interior in my car!  i was sad because I wanted better pictures and the window was only cracked.
                                          Yeah, hopefully it'll be back on the road by next summer. And yup that's mine! Sorry I was hiding it haha, I haven't had the chance to clean it much since I bought it so I was embarrassed...
                                          That's actually pretty awesome picture by the way!
