  4. e34 Touring
e34 Touring
269 Posts 26 Posters 4.5k Views 1 Watching
    wow! congrats!
    The pedal box was the biggest PITA on my manual swap, but I had my engine out of the car. Great work! It must be so much more enjoyable to drive.
      Very nice!!
      Why no rear Delrin bushing in the back of the carrier ?
        wow! congrats!
        thanks! so far much better. haven't given her the beans yet, the internet told me to drive easy for a little while with the new clutch. true?
        Very nice!! Why no rear Delrin bushing in the back of the carrier ?
        well, it was like $50 for the new OEM rear carrier, then you have to burn out the rubber bushing with a torch and press separate delrin one in. then you have to grind the tabs off the carrier to get it to fit.  i just hated the idea of burning and cutting up brand new parts.
          Understandable on the hacking of new parts lol. I put the Delrin one in mine. It wasn't too bad and I didn't have to cut anything
            True about taking it easy on the clutch for a bit. my self control only allotted me 2 miles before my first launch YMMV
              resisting is very very hard.
                As long as you don't do clutch dumps or kick the bejesus out of it. I don't think you'll destroy it. (That's me reassuring myself that I can drive my car without a care in the world)
                  Awesome work, rid the world of another automatic car!!
                    nicely done! Glad it all went in without too many hickups. I am looking to join the touring club too once my lease it up on the jetta.
                      I like the wooden stands you made too.
                      Dave,  pancake-engined-potato-carriages dont count in this context.
                        Got the wiring done, everything worked exactly like the information I found online from other people doing the e34 5 speed swap, which was an added bonus.  the 12 pin harness plug that they all spoke about was missing in my shifter area, but after pulling the entire shift console, I found it buried underneath (pain in the ass, but worth it)
                        all the console stuff pulled (i miss my e30, in which this would have have taken 2 minutes)
                        to trick the check control that the trans computer is there, you just have to ground out the gray pin in front (#10) on this 12 pin harness plug. you can pull pin #5 from the blue range switch plug that is no longer used from the auto trans shifter.
                        to get the reverse lights to work, here is the adapter that I made. i have the entire body harness from my parts car, so i can pull all kinds of nice factory plugs and already crimped pins.
                        my custom factory pin puller (take an metal extending antenna apart from an old radio, e30, etc)
                        i also switched out my HVAC panel with a fully working one while i was at it, and moved my ASC switch up by the fog light switch.
                        and the shift console all back together! used the weight zhp knob (feels great) and thats the m5 shift surround, which has great dividers so your crap doesn't slide around like the standard one.
                        the open blank is for a usb charging port from george graves on r3v: http://www.r3vlimited.com/board/showthread.php?t=357376 just waiting for it to arrive.
                          Zhp knobs are the bees knees
                            yes they are.
                            well i've put on about 400 miles since the install and have a bit of sad news - between sticky tires, stock suspension, and heavy chassis, I can't just spin the tires from a stop. the b30 has plenty of oomph, acceleration feels at least as fast as my m20 car, which could light them up no problem. until I change some things, no 11s for me. she still is fun as hell though!
                            mitch, i still plan on keeping my promise though!
                              Even more reason to get a B40 in there! That M5 shift console looks great.
                                for sure! someday... and thanks!
                                • CMartC
                                  CMartC
                                  CMart
                                  Awesome job and car.
                                  What does that clip/wire do that is on the inside of the trans?
                                  Excursion 7.3
                                  E30 LS1
                                    new pivot pin, clip and throw out bearing.
                                    are you referring to the above picture? the clip holds the release fork lever against the pin on that side. the lever hinges from that point as the clutch slave piston pushes the other side of the lever toward the engine.  most of the force on that end of the fork is forcing the lever against the pin behind it, so its just a measly clip to hold it steady.
                                    • CMartC
                                      CMartC
                                      CMart
                                      Yeah, I don't remember seeing one on my trans when I pulled it last.
                                      I don't want to pull it all apart again, but I am sure its there for a reason...
                                      Excursion 7.3
                                      E30 LS1
                                        Yeah you may have an issue. At a minimum you may get a lot if rattling. Not sure if the lever can find its way out of alignment but that could leave you with a blown slave cylinder and shifting issues.
                                        • CMartC
                                          CMartC
                                          CMart
                                          The bad news - I spent all night taking the motor out and taking the trans off.
                                          The good news - the clip is there - and I can sleep well knowing that.
                                          Excursion 7.3
                                          E30 LS1
