  3. BMW Discussion
  4. New car?? Help.
New car?? Help.
18 Posts 6 Posters 168 Views 1 Watching
  • LFE36M3L
    LFE36M3L
    LFE36M3
    Thanks i had not looked at the 328i but i will have to check in to that more im really just looking in to a 3 series of some kind if it happens to be a fast/fun drive thats just a plus.
    • LFE36M3L
      LFE36M3L
      LFE36M3
      2000, 323i with 85k, 1 owner. Any thoughts or opinions? It is just a DD to get me to work and the store. Any big problems i should look for when i go to look at it, (typical cooling problems excluded)
      Thanks
        It it's auto, you'd probably want one that's had the transmission updated with the new reverse drum. Check the rear subframe and make sure there's no cracks on the body around where it mounts. Overall, they are great cars.
        • LFE36M3L
          LFE36M3L
          LFE36M3
          Thanks!
          • LFE36M3L
            LFE36M3L
            LFE36M3
            Going to look at a car tonight 2003 330i 98k miles. Any thoughts? I know to look at sub frame and cooling. Any other big things? Thanks
              The subframe issue should be pretty apparent once you drive it.  It sounds like somebody is slamming a bowling ball in the trunk on shifts or a hard take off.  Struts and shocks are probably original and should be replaced so that's something to keep in mind with that mileage.  The DISA valve near the intake mani tends to rattle on these and can cause serious damage if not repaired so at idle I would listen for that rattle.
              edit: The DISA valve is an easy fix but if you have to replace the whole thing it is around $200.  Typically you can clean them or buy the repair kit for them.
              • LFE36M3L
                LFE36M3L
                LFE36M3
                Ok thanks i will check for that
                • LFE36M3L
                  LFE36M3L
                  LFE36M3
                  Looking at a 330xi can anyone tell me how to tell if its a awd other then the trunk badge. It has 330xi, but the vin plate in the door has 330iA-4/16 10/03 build date.
                  Any way to tell other then the trunk badge would be awesome. Thanks
                    It depends on what level you are:
                    Novice level: look under car for front drive axles
                    Expert level: bounce it off the limiter and launch it
                    • LFE36M3L
                      LFE36M3L
                      LFE36M3
                      Lol well i dont know how the seller would feel if i was launching there car but looking for the drive axels would be a good idea.... i should have thought of that lol
