  4. '88 E30
'88 E30
savebigmoney
1.1k Posts 36 Posters 12.0k Views 2 Watching
    Finished up the fan wiring last night.
    Toggle switch with red LED when fan is on
    Rats nest with 2, 20amp fuses (switch is a 25amp) I popped one of these on accident while testing the fan, so I'm glad I have them.
    Wires routed with some adhesive clips. Relay kinda tucked in the fender so it is easy to get to.
    Made some labels because I wanted to use all black 14g wire so it didn't look like streamers under the hood
    Aaaaaaaand. Mounted. Had to redo the two leads on the fan, I messed up power/ground. So my pusher acted as a puller--all good now!
    Also ordered some new carpet for this thing last night. I got sick of looking at shitty floors.
    Any one have any experience with dyeing the parcel shelf?? I want mine to be black. Is it worth the hassle? Or just easier to find a black one?
      where did you get heat shrink labeler?! thats awesome.
        They are like regular label maker cartridges. But it prints it on shrink tube. They worked pretty well
          Went out an bought some duplicolor vinyl and carpet paint I'm an aerosol can. Worked awesome and was easy to use. I now have a black parcel shelf.
          Valence is also mounted-ish.
          Driveline stuff gets here today (Thursday). the car might move under its own power by the weekend...
            Only thing left is bleed slave. Split driveshaft, install CSB. Install driveshaft. Do burnouts
              I drove it last night at about 2am
              Car makes top end noise. Like bad m20 top end noise (couldn't hear it when I started it with open headers)
              I'm probably going to be buying a daily driver within the next month or so. The e30 will get to sit. Kinda sucks getting literally everything back together only to find out the motor sounds like it has marbles in it.
              Only thing I can think of is vanos, timing chain guides, lifter tick
              Now might be a good time to send the head out...
                My M42 had serious lifter tick the first time I started it up, even after idling for 5 or 10 minutes. I was really depressed that something was fucked.Took it up and down the block a few times and it was 95% gone. Seems like the lifters need a couple good beat-run to get pumped up. You may have the same problem...
                  That is pretty reassuring. I'm ditching the current oil- just wanted to use it for the first hour or so then put 15w-50 in it. The motor sat for 4/5 months without running and just had some "storage oil" in it.
                  I only ran it for about 5/7 minutes. I did drive a bit. Barely creeped around. Probably never got over 2500 rpm
                  I need to get my temp sensor working on the cluster/install an aftermarket one. So I know if I'm safe
                    Went out and drove it tonight.
                    Ticking is gone (there is still 20years of top end noise, but nothing even close to worrying)
                    Got the gas leak by the tank fixed tonight as well.
                    The VANOS could probably be replaced. There's some noise there, nothing toooooo terrible, but still annoying.
                    Other than getting a working coolant temp gauge & breaking in the clutch, this thing hauls decent ass.
                    I'm being fairly easy on it, and it scoots pretty good. (Granted I haven't driven a vehicle in the last 5 months lol)
                    Once clutch is broken in. I promise burnouts. Because really that's all that matters
                      This is really good to hear!
                        Car rips!!! Granted it's not turbo'd or anything crazy, it still scoots way better than the m50!!! It runs very well (for now lol)
                          First wash of the year. There was like a 1/4 inch of dust on it
                            Congrats! That car is going to be a blast.
                            I gave mine a quick wash at the pay-n-spray when I first got it running, but I could still read where I had written "Spray bombs 4 life" in dust on the windshield. Finally got the "air leak" before my fuel pump fixed (actually cavitation... neat), so today I took it home and gave it a proper wash. Sure feels good to have a legitimate car again instead of a pile of parts. thumbup.gif
                              Thanks man!!
                              I've been driving around with my ears wide open. Every rattle/noise has perked my attention. Just being a bit nervous haha.
                                My m50 clatters bad for the first few minutes after it sits all winter. Hold it around 3k rpms until the lifters get all the air out and its good to go. The Nissan on the other hand clatters if it sits for a week...
                                Sent from my PC36100 using Tapatalk 2
                                  awesome that you got it going!  lets have a man date and go do burnouts after our clutches break in.
                                    A man after my own heart lolol
                                      Good to know. I was super disappointed at first. Now it sounds good
                                        My new aftermarket carpet came in today! It needs to sit for a dayish so it can relax from shipping. It kinda sucks ill have to cut it up a bit but oh well..
                                        I'll probably just make one slice down the center (maybe like a foot and a half long) so I can slide it over the hydro, then cut out a circle for the shifter.
                                        Probably will have to trim near the heater core and some trimming along the sides of the car as well.
                                        Still unsure about what to do for gas pedal...maybe detach linkage and cut a slit in the carpet, slide carpet over pedal, then reattach. one step closer to a complete interior!!
                                          Got the carpet in. As suspected, it was a pain in the ass. Had to do a decent amount of cutting and trimming to get it to fit. Other than that it all went decently smooth. I finally have a full black interior again, non of that tan BS (just need to find the ash trays to fill the consoles) then the interior will be complete. Also want to try and make the pedal area look more neat
                                          Car got quite a bit quieter with carpets which is exactly what I was hoping for (can't hear the solid trans mounts too much now) **shittypicsoritdidnthappen-I'll get some better ones in the daylight
                                          Also put the e30 m20 coolant temp sensor in the head. I'm a dumbass and forgot to swap out the s50 one with a brown m20 sensor to make the cluster work when the engine was out of the car.
                                          Luckily my hand fit under the intake far enough so I could swap them out. Didn't loose too much coolant at all and now the cluster works!
                                          This is where the temp gauge climbed to and stayed.
                                          I drove very normally in town, gauge didn't move
                                          Drove it hard, gauge didn't move
                                          Freeway speed, gauge didn't move
                                          Idling for 5 mins, gauge stayed
                                          I also did all the above running my electric fan on and off (gauge stayed) also did the above with heat on and off at full blast (gauge didn't move)
                                          At first it made me nervous that it wasn't dead center but hell, it's a 25 year old sensor on a 25 year old cluster
                                          I currently don't have any of the radiator shrouding in that directs air from behind the bumper into the radiator. Wonder if that would help at all, I think I still have them laying around
