  4. 1991 318is M62B44 Build
268 Posts 27 Posters 4.3k Views 1 Watching
    Run zoomies through the hood. Jk. Hopefully we can both finish our cars and do burnouts
    I'm in for burnouts. And my car is actually done lol.
    • CMartC
      CMartC
      CMart
      Yeah I am getting excited. If I can get at least my downpipes finished by this weekend I will be happy.
      Anyone in the Milwaukee area that is decent at wiring is welcome to come help with unlimited beers provided.
      Excursion 7.3
      E30 LS1
      • CMartC
        CMartC
        CMart
        Which one of these do I need to tap into for the fuel pump?
        I assume is the fuel pump and one transfers fuel from one side of the tank to the other?
        Excursion 7.3
        E30 LS1
          I think there's three lines off the tank. Fuel send/return and the third is a breather line that runs up to a charcoal canister and then to a purge valve to the intake. The connector on the furthest left of the pic looks pretty similar to the coolant level sensor, I'd imagine it's gas level (?) the middle connector is probably for the fuel pump. Don't quote me, just guessing
            Yeah it's 3 connectors but I'd have to go look at the e30 Tomorrow.
            • CMartC
              CMartC
              CMart
              So the pump wires are on top?
              Excursion 7.3
              E30 LS1
              • CMartC
                CMartC
                CMart
                Down pipes and gutted cats are in. I need to way to trick the secondary O2 sensors so I don't have a CE light on all the time. I am thinking I can tap into the primary and run a resistor or buy those O2 spacers that trick them into thinking the cats are there and working.
                Mach up - Thought it looked pretty cool.
                Waiting on my C101 and then I can start the wiring. Still need to tweak and reinforce the remote booster and run all the plumbing.
                Excursion 7.3
                E30 LS1
                  What DNA radiator are you running? Looks to be thicker than an e30/e36 one
                    I ended up not getting to my shop this weekend. Any diagrams on r3v or in the bentley?
                    • CMartC
                      CMartC
                      CMart
                      It is supposed to be for an E30. I wish it was wider, but I will wait to see what my coolant temps are and change if needed.
                      Haven't looked any further into the wiring. I got as much done on the exhaust as I can until my hangers show up. Pretty happy with everything thus far.
                      Excursion 7.3
                      E30 LS1
                        Just make the o2 spacers with spark plug antifoulers. I know plenty of people that have made them with great success and for about $4.
                        • CMartC
                          CMartC
                          CMart
                          Do M62s use the secondary O2s for air/fuel or just to see if the cats are working?
                          Excursion 7.3
                          E30 LS1
                            Just to check cat function
                            • Dominic540D
                              Dominic540D
                              Dominic540
                              If it is a TUB engine, they are used for air/fuel I believe. The early models do not use them for anything other than cat monitoring, as Snap said.
                              • CMartC
                                CMartC
                                CMart
                                Not TUB. Thank god.
                                Excursion 7.3
                                E30 LS1
                                  CMart said:
                                  Not TUB. Thank god.
                                  Showers ftw
                                    TU = totally useless.
                                    just set the cams to 'hot' and leave them alone BMW, this isn't risotto.
                                    • CMartC
                                      CMartC
                                      CMart
                                      A lot of my exhaust was just tacked up so I finished as much as I could before running out of argon yesterday. Started the wiring and just picked up some more argon to hopefully finish the full exhaust this weekend.
                                      Bad news is I seem to have a rear main seal leak or a transmission seal leak.
                                      Excursion 7.3
                                      E30 LS1
                                        Mine was leak free for about 2 weeks. Came out to the garage and I saw a tiny drop under the car.
                                        Instant sadness
                                        • CMartC
                                          CMartC
                                          CMart
                                          Pulled an all nighter Friday and got the motor harness all hooked up and some more work on the exhaust.
                                          I have most of the wires identified and know where they need to go and think I have the EWS figured out as well.
                                          Probably 10 hours from firing, but still have a lot of driveability stuff to do (finish brakes, clutch line, cooling, etc)
                                          Excursion 7.3
                                          E30 LS1
