  4. 1991 318is M62B44 Build
268 Posts 27 Posters 4.3k Views 1 Watching
  • CMartC
    CMartC
    CMart
    Making some progress on the booster relocation and waiting on some aluminum parts to get back from my welder.
    Since I have not been able to find a good wiring diagram I have some general electronics questions.
    From what I am gathering I need to take the main relay and fuel pump relay from the E39. Would these be located on the body harness or engine harness? There are a relays on the body harness and I am hoping those are it.
    If they are fact are do I just need to tap into the E30 ignition wires so I can power them when I IG1, IG2, start, etc they are powered? Basically just wire them into the E30 key, and then into the fuel pump and the starter?
    Any good write ups on general engine swaps and electronics for this?
    Excursion 7.3
    E30 LS1
    • CMartC
      CMartC
      CMart
      Got the booster bracket back from the welder last week. Put in some hours this weekend and got the booster bracket mounted and all of the linkage setup. "Hardest part of the swap" is now done. Next comes what will be the hardest for me which is the wiring.
      Excursion 7.3
      E30 LS1
      • CMartC
        CMartC
        CMart
        Bad/boring picture, but...
        Excursion 7.3
        E30 LS1
          Yes! Then what,   exhaust?
          • CMartC
            CMartC
            CMart
            Bad angle, but manifolds are already on there. Just need to weld up some down pipes and fit the old E39 exhaust. Decided to go straight pipe and forget the sleeper thing.
            Ohh and the booster is from an older car and I am using that for mach up. I have one in much better condition that I will be using.
            Excursion 7.3
            E30 LS1
              How about an electronic cutout?
              • CMartC
                CMartC
                CMart
                Thought about it - maybe down the road.
                I drove the car with the exhaust I am recycling and it wasn't crazy loud, but it will definitely confuse some people coming out of an E30.
                Excursion 7.3
                E30 LS1
                • CMartC
                  CMartC
                  CMart
                  Driveshaft is back from Machine Service in Waukesha. They did a great job for 1/6 the cost of buying the 'E30 M62' one from garagastic.
                  All that is really left is the exhaust, brake/clutch/coolant plumbing, and wiring.
                  Excursion 7.3
                  E30 LS1
                  • CMartC
                    CMartC
                    CMart
                    Bought a C101 from R3V and my goal is to have the brakes refitted and exhaust made by the time it arrives on Monday. Then its on to wiring.
                    Still need to make a list of last minute small things I need to buy, but its getting closer...
                    Excursion 7.3
                    E30 LS1
                      This build deserves its own get-together so we can take turns doing burnouts with it.
                        In 4 exhaust pics
                        • CMartC
                          CMartC
                          CMart
                          It's funny when I picture this car being done I don't picture it at the track (which is my new goal for the car), I picture myself in a parking lot with the throttle down choking on white smoke.
                          We'll have a BYOT (bring your own tires) party
                          CYoung said:
                          In 4 exhaust pics
                          It's been a bitch so far. I need a lift or a hand to make any real progress, but I cleared my schedule for tonight to see what I can get done. All I have at this point is the exhaust manifolds made and my old E39 exhaust I plan on frankensteining. Driver side down pipe is proving to be a real pain in the ass.
                          Excursion 7.3
                          E30 LS1
                            Run zoomies through the hood. Jk.
                            Hopefully we can both finish our cars and do burnouts
                              I feeel ya! I've built a few exhaust at my current shop now, and I have gravel for most of my garage floor LOL.
                              Between that, and having broke my back when I was younger, and still having a couple herniated disc's, life is real hard without a lift! haha.
                                Run zoomies through the hood. Jk. Hopefully we can both finish our cars and do burnouts
                                I'm in for burnouts. And my car is actually done lol.
                                • CMartC
                                  CMartC
                                  CMart
                                  Yeah I am getting excited. If I can get at least my downpipes finished by this weekend I will be happy.
                                  Anyone in the Milwaukee area that is decent at wiring is welcome to come help with unlimited beers provided.
                                  Excursion 7.3
                                  E30 LS1
                                  • CMartC
                                    CMartC
                                    CMart
                                    Which one of these do I need to tap into for the fuel pump?
                                    I assume is the fuel pump and one transfers fuel from one side of the tank to the other?
                                    Excursion 7.3
                                    E30 LS1
                                      I think there's three lines off the tank. Fuel send/return and the third is a breather line that runs up to a charcoal canister and then to a purge valve to the intake. The connector on the furthest left of the pic looks pretty similar to the coolant level sensor, I'd imagine it's gas level (?) the middle connector is probably for the fuel pump. Don't quote me, just guessing
                                        Yeah it's 3 connectors but I'd have to go look at the e30 Tomorrow.
                                        • CMartC
                                          CMartC
                                          CMart
                                          So the pump wires are on top?
                                          Excursion 7.3
                                          E30 LS1
