  4. 1991 318is M62B44 Build
268 Posts 27 Posters 4.3k Views 1 Watching
    What did you get for a flaring tool? I will be needing one at some point.
    Sent from my potato phone
    • CMartC
      CMartC
      CMart
      http://www.amazon.com/OTC-4504-Stinger-Bubble-Flaring/dp/B0015PMZMU/ref=sr_1_1?ie=UTF8&qid=1426778201&sr=8-1&keywords=iso+bubble
      From what I read, its hard to find ISO flares at parts stores to rent and when you can the dies are worn from improper/too much use.
      I got that along with a cutter and bender.
      I'll lend it out once I am done with it to anyone who needs it.
      Excursion 7.3
      E30 LS1
        That's pretty cheap, good find. Reviews look good.
        • CMartC
          CMartC
          CMart
          Yeah with how much of a pain brake lines are I figured buying was cheaper than renting in the long run.
          Excursion 7.3
          E30 LS1
          • CMartC
            CMartC
            CMart
            Making some progress on the booster relocation and waiting on some aluminum parts to get back from my welder.
            Since I have not been able to find a good wiring diagram I have some general electronics questions.
            From what I am gathering I need to take the main relay and fuel pump relay from the E39. Would these be located on the body harness or engine harness? There are a relays on the body harness and I am hoping those are it.
            If they are fact are do I just need to tap into the E30 ignition wires so I can power them when I IG1, IG2, start, etc they are powered? Basically just wire them into the E30 key, and then into the fuel pump and the starter?
            Any good write ups on general engine swaps and electronics for this?
            Excursion 7.3
            E30 LS1
            • CMartC
              CMartC
              CMart
              Got the booster bracket back from the welder last week. Put in some hours this weekend and got the booster bracket mounted and all of the linkage setup. "Hardest part of the swap" is now done. Next comes what will be the hardest for me which is the wiring.
              Excursion 7.3
              E30 LS1
              • CMartC
                CMartC
                CMart
                Bad/boring picture, but...
                Excursion 7.3
                E30 LS1
                  Yes! Then what,   exhaust?
                  • CMartC
                    CMartC
                    CMart
                    Bad angle, but manifolds are already on there. Just need to weld up some down pipes and fit the old E39 exhaust. Decided to go straight pipe and forget the sleeper thing.
                    Ohh and the booster is from an older car and I am using that for mach up. I have one in much better condition that I will be using.
                    Excursion 7.3
                    E30 LS1
                      How about an electronic cutout?
                      • CMartC
                        CMartC
                        CMart
                        Thought about it - maybe down the road.
                        I drove the car with the exhaust I am recycling and it wasn't crazy loud, but it will definitely confuse some people coming out of an E30.
                        Excursion 7.3
                        E30 LS1
                        • CMartC
                          CMartC
                          CMart
                          Driveshaft is back from Machine Service in Waukesha. They did a great job for 1/6 the cost of buying the 'E30 M62' one from garagastic.
                          All that is really left is the exhaust, brake/clutch/coolant plumbing, and wiring.
                          Excursion 7.3
                          E30 LS1
                          • CMartC
                            CMartC
                            CMart
                            Bought a C101 from R3V and my goal is to have the brakes refitted and exhaust made by the time it arrives on Monday. Then its on to wiring.
                            Still need to make a list of last minute small things I need to buy, but its getting closer...
                            Excursion 7.3
                            E30 LS1
                              This build deserves its own get-together so we can take turns doing burnouts with it.
                                In 4 exhaust pics
                                • CMartC
                                  CMartC
                                  CMart
                                  It's funny when I picture this car being done I don't picture it at the track (which is my new goal for the car), I picture myself in a parking lot with the throttle down choking on white smoke.
                                  We'll have a BYOT (bring your own tires) party
                                  CYoung said:
                                  In 4 exhaust pics
                                  It's been a bitch so far. I need a lift or a hand to make any real progress, but I cleared my schedule for tonight to see what I can get done. All I have at this point is the exhaust manifolds made and my old E39 exhaust I plan on frankensteining. Driver side down pipe is proving to be a real pain in the ass.
                                  Excursion 7.3
                                  E30 LS1
                                    Run zoomies through the hood. Jk.
                                    Hopefully we can both finish our cars and do burnouts
                                      I feeel ya! I've built a few exhaust at my current shop now, and I have gravel for most of my garage floor LOL.
                                      Between that, and having broke my back when I was younger, and still having a couple herniated disc's, life is real hard without a lift! haha.
                                        Run zoomies through the hood. Jk. Hopefully we can both finish our cars and do burnouts
                                        I'm in for burnouts. And my car is actually done lol.
                                        • CMartC
                                          CMartC
                                          CMart
                                          Yeah I am getting excited. If I can get at least my downpipes finished by this weekend I will be happy.
                                          Anyone in the Milwaukee area that is decent at wiring is welcome to come help with unlimited beers provided.
                                          Excursion 7.3
                                          E30 LS1
